This content has been marked as final.
Show 3 replies
1. Re: Tricky Footage Rotation Edit
Harm Millaard Apr 25, 2011 4:58 AM (in response to the101waves)Why not simply rotate the TV on playback?
2. Re: Tricky Footage Rotation Edit
Colin Brougham Apr 25, 2011 6:11 AM (in response to the101waves)Either cut out the portion where the camera rotates--you can use the Razor tool or Sequence > Razor Tracks--and use the Motion > Rotation intrinsic effect to correct the sideways portion, or you can animate the rotation. You will probably want to/have to use Position and Scale to get the rotated segment to fit in the Program Monitor.
3. Re: Tricky Footage Rotation Edit
JSS1138 Apr 25, 2011 1:32 PM (in response to the101waves)Keyframe the Rotation effect.
