• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Flash Builder 4.5 Mobile Login Form needs 2 clicks???
New Here ,
Apr 25, 2011 Apr 25, 2011
I have been working on developing an application  for the android market thta firstly requires the users to login to a  account. I have put the code together below, along with a data link to a  database in order to check the credentials. However the application  does not switch to the second view on the first click of the "Login"  button however it seems to take 2 or more clicks sometimes. I presume as  it is fetching data from a database that it takes time to be verifies,  could someeone tell me how to solve this and maybe implement a  BusyIndicator along with it?
<![CDATA[
               protected function login_btn_clickHandler(event:MouseEvent):void
                    var match:Boolean;
                    getEmployeesByNameResult.token = employeeService.getEmployeesByName(usr_nme_txtbox.text, pass_txtbox.text);
                    if (getEmployeesByNameResult.lastResult != null)
                         navigator.pushView(HomeView, getEmployeesByNameResult.lastResult.id);
<s:Button id="login_btn" width="100%" label="Login"
                                click="login_btn_clickHandler(event)"/>
Views
1.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Aug 13, 2012 Aug 13, 2012
LATEST
(While original poster might have found the solution or given up, I guess it's a good idea to leave the question answered)
The service is asynchronous. You cannot check right after calling, instead you need to use a handler for reading the result.
Votes
Translate
Translate
Report
Report
