• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Getting the book onto ADE
New Here ,
Apr 25, 2011 Apr 25, 2011
Just bought EBook and downloaded ADE.  Now what do I do?   Am not at techno whiz.  How do I get the book from the publisher to the ADE.  When I enter the ADE program, nearly entirely black screen and no button responds.  Thanks.
Views
808
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Apr 27, 2011 Apr 27, 2011
When I downloaded my first book from my library website it showed up in my ADE, I then plugged my Nook into my computer and then opened up my computer and clicked on removable file F which is where your nook or ereader it plugged into your computer at. I then went back to ADE and dragged the book in my nook, then unplugged my nook and found the book in my library under my files. I hope that helps! Its all so confusing!
Votes
Translate
Translate
Report
Report
New Here ,
May 05, 2011 May 05, 2011
What do you mean "it showed up in ADE"?  My library book showed up as a download in my computer, but had only 2 kb.  It is not there.  ADE will not activate in my computer.
Votes
Translate
Translate
Report
Report
Engaged ,
I'm not sure WHERE on your computer you see the downloaded library book.
So, let me presume a couple of things here, and try to give you an answer.
First, I presume you're operating a Windows PC. Next, I'll 'assume' (you
know what THAT means!) that you can use the Windows Explorer utility to find
files. Let's start there.
First, find the library book on your computer's hard drive with Windows
Explorer, and make a note of the folder it's in.
Next, open ADE and get to Library view, where you can see the avatars of the
ebooks you have in it in the right hand panel. Now, get the drop-down list
from the Library tab (next to the word 'Library' on the left hand top side
of the display panel) and click on the 'Add Item' tab. This will take you
to a screen that will let you browse for the location of the ebook (or
document) you want to add to the Library. Click on the title, and ADE will
import it, and show it on the right hand of the Library panel display. BTW:
ebooks don't take up a lot of storage, so 2kb isn't necessarily the wrong
size for the file.
Once the ebook is added to your library, you can copy it onto your ereader
by dragging and dropping it on the left hand panel. I will 'assume'
(there's that word again!) that you understand the process of hooking up
your ereader and then opening ADE so that ADE will recognize the ereader.
It's just a sequence you have to follow due to the technology we use these
days.
Hope this helps!
Votes
Translate
Translate
Report
Report
New Here ,
Thank you for your help.  Another friend sent me to someone's blog where there is a simple solution for getting the book from the library into the Noon.  Here is what she sent me  "http://beingruth.com/tutorial-library-books-nook-overdrive/
This site really helped me and has photos of the computer screen so I could find what to click on and where to drag it.
Votes
Translate
Translate
Report
Report
Engaged ,
May 06, 2011 May 06, 2011
You're welcome.
The tutorial that your friend referred to is related to the use of a
different ebook management system called Overdrive. You'll have to check
with your library and make sure that it uses Overdrive for its ebook
deliveries. Many libraries skip this step and go directly to ADE.
I can see where the ebook can get 'lost' in the process of downloading in
Step 2. The illustration is using Firefox as a web browser, not Internet
Explorer (IE), so if you were to pick 'Save' instead of 'Open', you would
have to pick a location to put the ebook.
Isn't software fun? NOT!!!
If your library doesn't use Overdrive for its book checkout, then the
process will be different: your library will let you choose to download the
ebook into ADE, and Step 2 will give you the option of 'Open' or 'Save'. If
you choose 'Open', then the ebook will show up in the 'Reading' panel of
ADE. If you choose 'Save', the ebook will go directly to ADE's Library.
The rest of the process remains the same.
Votes
Translate
Translate
Report
Report
New Here ,
Not sure who this exchange is intended for, but please remove me from the list.
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
Wasn't for you, but if you belong to the ADE Forum, you'll get ALL of the
Forum messages and their responses.
Votes
Translate
Translate
Report
Report
