2 Replies Latest reply on Apr 26, 2011 11:47 AM by brifilone
    Moving a layer in Photoshop CS5 using Applescript
    brifilone Level 1
      I have a layer in a document called "logo" and i want to duplicate it to every open document and then move it to a specific spot in each document
      I got the duplicating thing happening but cant seem to move the bounds of the layer (says it is read only and cannot be changed)
      here is what I have written
      tell application "Adobe Photoshop CS5"
      activate
      set theDocs to count of documents
      repeat with i from 1 to theDocs
      duplicate art layer "logo" of current document to document i
      end repeat
      set current document to document i
      tell document i
      set bounds of art layer "logo" to {0.456666666667, 6.38, 2.88, 6.77}
      --Adobe Photoshop CS5 got an error: Property is read/only and cannot be changed
      end tell
      end repeat
      end tell
      This doesn't error but also doesn't move the logo at all
      activate
      end repeat
      tell document i
      set properties of art layer "logo" to {bounds:{0.456666666667, 6.38, 2.88, 6.77}}
      end tell
      end repeat
      end tell
      anyone know what the language is to move the layer around?
        • 1. Re: Moving a layer in Photoshop CS5 using Applescript
          Muppet Mark-QAl63s Level 4
          In any language the way to move a layer x,y is to use translate… You will need to do the math from current x,y to required x,y given a distance… A read only property is just that regardless of language… Here is a quick example of how I did this kind of thing using Applescript… I still do the same method now but use the ESTK instead…
          tell application "Adobe Photoshop CS2"
          activate
          -- Store the app settings
          set User_Rulers to ruler units of settings
          set User_Dialogs to display dialogs
          set ruler units of settings to pixel units
          set display dialogs to never
          set Doc_Ref to the current document
          tell Doc_Ref
          -- Store the image res so we can put it back
          set Original_Res to resolution
          -- Change to work at 72 dpi
          resize image resolution 72 resample method none
          -- Move horizontal 1 inch
          translate layer 1 delta x 72 as pixels
          -- Move vertical 1 inch
          translate layer 1 delta y 72 as pixels
          -- Read the bounds propety
          set Layer_Bounds to bounds of layer 1
          log Layer_Bounds
          -- Move the layer using bounds to top/left
          translate layer 1 delta x -(item 1 of Layer_Bounds) as pixels
          translate layer 1 delta y -(item 2 of Layer_Bounds) as pixels
          -- Put back the image res
          resize image resolution Original_Res resample method none
          end tell
          -- Put back the app settings
          set ruler units of settings to User_Rulers
          set display dialogs to User_Dialogs
          end tell
          You should get the general idea of how this works from this. It should move the first layer across 1 inch, down i inch then put it top/left. It assumes you have a layer that is not a background layer nor is it locked in any way…
          • 2. Re: Moving a layer in Photoshop CS5 using Applescript
            brifilone Level 1
            Thanks I couldn't get that translate language right before now I see how it's used.
