1 Reply Latest reply on May 3, 2011 2:32 AM by kishor papnai
    Will only work with component button
    sus3135
      There is probably a simple answer to this, but I'm not seeing it. Got a drop down menu - Flash 8 - AS2. The problem is that it works like a charm if the MainMenu_btn is a Component - but if I make my own button it doesn't work.
      Menu is created with this code.  Button is created in Flash - "Insert - New Symbol - Button.
      Can anyone tell me why?
      _global.style.setStyle("themeColor", "haloGray");
      import mx.controls.Menu;
      MainMenu_btn.useHandCursor = true;
      var cmMainMenu:Menu = Menu.createMenu();
      cmMainMenu.addMenuItem({label: "Welcome", instanceName:"miIWelcome"});
      cmMainMenu.addMenuItem({label: "Introduction", instanceName:"miNavigation"});
      cmMainMenu.addMenuItem({label: "Exit", instanceName: "Exit"})
      // Add a change-listener to Menu to detect which menu item is selected
      var changeListener = new Object();
      changeListener.change = function(evt_obj:Object) {
      // Code for when the user makes a specific selection
      var item_obj:Object = evt_obj.menuItem;
      if( item_obj.attributes.label=="Welcome" ){
      loadMovie("data/exported0.swf","emptyClip");
      else if (item_obj.attributes.label == "Introduction") {
      loadMovie("Introduction.swf","emptyClip");
      cmMainMenu.addEventListener("change", changeListener);
      //Add a button that displays the menu when the button is clicked
      var listener = new Object();
      listener.click = function(evtObj) {
      var button = evtObj.target;
      //get reference to the button
      // Display the menu at the bottom of the button
      _root.cmMainMenu.show(button.x, button.y+button.height);
      MainMenu_btn.addEventListener("click", listener);
      stop();
        • 1. Re: Will only work with component button
          kishor papnai
          for customized button you will have to write code like this.
          writting event is the difference here in component and customized button.
          _global.style.setStyle("themeColor","haloGray");
          cmMainMenu.addMenuItem({label:"Welcome", instanceName:"miIWelcome"});
          cmMainMenu.addMenuItem({label:"Introduction", instanceName:"miNavigation"});
          cmMainMenu.addMenuItem({label:"Exit", instanceName:"Exit"});
              if (item_obj.attributes.label == "Welcome") {
                  loadMovie("data/exported0.swf", "emptyClip");
              } else if (item_obj.attributes.label == "Introduction") {
                  loadMovie("Introduction.swf", "emptyClip");
          cmMainMenu.addEventListener("change",changeListener);
          MainMenu_btn.onRelease = function(e) {
              var button = MainMenu_btn;
              _root.cmMainMenu.show(button._x,button._y+button._height);
          stop();
