2 Replies Latest reply on Apr 25, 2011 7:26 PM by THC Inc.
    UI refresh issue with external events
    THC Inc.
      I'm having a weird UI update issue. An event gets fired from an ActiveScript class that sets a Label on the UI side to a value. Even though the trace shows the value being changed, the UI is not updated to reflect the new value
      I have an ActiveScript Class that does some socket IO and occasionally dispatches an event using the global event dispatcher (defined below)
      private function ProcessData(Data:String):void{
      this.socketStatus = Data;
      trace("ProcessData", Data); //this is definitely called
      eventDispatcher.dispatchEvent(new Event(ONINFO));
      I have a global event handler to handle events for the above file
      package
           import flash.events.IEventDispatcher;
           public function get eventDispatcher():IEventDispatcher
                return _eventDispatcher;
      import flash.events.EventDispatcher;
      var _eventDispatcher:IEventDispatcher = new EventDispatcher();
      Now in the UI (Status.mxml) the code is
      protected function view1_viewActivateHandler(event:Event):void
           if (!GlobalVars.socketProcess)
                GlobalVars.socketProcess = new SocketProcess();
                eventDispatcher.addEventListener(SocketProcess.ONINFO, SocketInfo, true);
      protected function SocketInfo(event:Event):void {
      trace("SocketInfo", GlobalVars.socketProcess.socketStatus); //this is definitely triggered by the event
      lblSocketStatus.text = "Status: " + GlobalVars.socketProcess.socketStatus;
      trace(lblSocketStatus.text); //this properly outputs the value set above
      Now, I have a button on the UI that fires the SocketInfo event and the button does Update the UI. Am I missing something, I've tried everything I can think of, no outside call seems to make the UI update to reflect the text change of the Label.
      Tom
