2 Replies Latest reply on Apr 27, 2011 2:47 AM by Karl_Sigiscar_1971
    How to put a huge image inside a small canvas?
    Kumar Pratik Level 1
      Hi All,
      I wanted to put a huge image inside a small canvas in a datagrid column. I am able to put image inside the canvas but somehow image is not looking very good, although it is completely visible. Is there any properties or any other way through which i can achieve this?
      Here is the code which I am using:
      <mx:DataGridColumn headerText="Image Name" >
      <mx:itemRenderer>
      <mx:Component>
      <mx:Canvas>
      <mx:Image height="100%" width="100%" id="showimg" source="{data.imgname}"
      scaleContent="true" maintainAspectRatio="true"/>
      </mx:Canvas>
      </mx:Component>
      </mx:itemRenderer>
      </mx:DataGridColumn>
        • 1. Re: How to put a huge image inside a small canvas?
          Shravan P
          Specify the width and height properties to the image, not in percentage. If you want to set that image in a canvas, specify the width and height values for canvas.
          You can embed image without using canvas, here is a example, check it out:
          <mx:Application
          xmlns:mx="http://www.adobe.com/2006/mxml" >
          <mx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          Bindable]
          private var initDG:ArrayCollection = new ArrayCollection([
          {Artist:
          'Pavement', Album:'Brighten the Corners',
          Price:11.99, Cover:
          'image.JPG'}
          </mx:Script>
          <mx:DataGrid id="myGrid" dataProvider="{initDG}" rowHeight="100">
          <mx:columns>
          <mx:DataGridColumn dataField="Artist"/>
          <mx:DataGridColumn dataField="Album"/>
          <mx:DataGridColumn dataField="Cover"
          itemRenderer="
          mx.controls.Image" width="50" />
          <mx:DataGridColumn dataField="Price"/>
          </mx:columns>
          </mx:DataGrid>
          </mx:Application>
          • 2. Re: How to put a huge image inside a small canvas?
            Karl_Sigiscar_1971 Level 3
            You need to activate smoothing (bilinear filtering) which in Flash Professional is done via a checkbox.
            In Flex:
            If you target Flash Player 9, use the Smooth Image component:
            http://cookbooks.adobe.com/post_Smooth_Image-4001.html
            If you target Flash Player 10, the Image control has a new property smooth. Just set it to true.
