4 Replies Latest reply on Apr 26, 2011 8:57 PM by Dhrupadh
    Unable to get started with RTMFP
    Dhrupadh
      I am just getting started with RTMFP for communicating between two instances of flash players.
      I tried this code:
      var x:NetConnection = new NetConnection();
      x.addEventListener(NetStatusEvent.NET_STATUS,handleStatus);
      x.connect("rtmfp://p2p.rtmfp.net/","MY_DEV_KEY");
      private function handleStatus(event:NetStatusEvent):void
           Alert.show("fingerPrint is " + x.nearID);
      But after the first three lines of code execute, I dont see any response.
      I tried running this code using both Flash Builder and FB plugin for Eclipse with flash player version 10.2.159.1 installed.
      I also tried running this app:
      http://flashrealtime.com/tuts/p2p-in-flash/p2p-flash-demo/
      But seems like it is not working either.
      Please help.
        • 1. Re: Unable to get started with RTMFP
          Michael Thornburgh Adobe Employee
          what results do you get if you go to
            http://cc.rtmfp.net/
          • 2. Re: Unable to get started with RTMFP
            nated
            try this instead:
            x.connect("rtmfp://p2p.rtmfp.net/"+"MY_DEV_KEY");
            That should get you going for starters I believe.
            Dhrupadh wrote:
            I tried this code:
            Please help.
            • 3. Re: Unable to get started with RTMFP
              >> try this instead:
              that won't make any difference.  and in fact the
                 x.connect("rtmfp://p2p.rtmfp.net", "MY_DEV_KEY");
              form is preferred now (see the announcement at the top of the forum).
              if cc.rtmfp.net works and gives a result, then you probably have a programming error.  if cc.rtmfp.net doesn't work (doesn't connect), then most likely you have a firewall that completely blocks UDP.
              • 4. Re: Unable to get started with RTMFP
                Dhrupadh Level 1
                Yes it was a firewall issue. When i go to the site http://cc.rtmfp.net/, I get a connecting... message that just appears to be connecting to eternity.
                I tried using a private internet connection and it works fine.
                Thanks for your help.
