2 Replies Latest reply on Apr 26, 2011 10:00 AM by EricJ32
    Using an <a click=""> in RichEditableText
    EricJ32 Level 1
      I need to have a RichEditableText control which has a link in the middle of the text. On clicking this link, a function is called, rather than a traditional href.
      Originally, this looked like:
      <s:RichEditableText width="100%"
      selectable="false"
      editable="false">
      <s:span>This is my text and if I </s:span>
      <s:a click="linkClickHandler(event)">click here</s:a>
      <s:span> then it runs a local method</s:span>
      </s:RichEditableText>
      with the function as:
      protected function linkClickHandler(event:FlowElementMouseEvent):void
         Alert.show("clicked");
      However, now I need to load the text at runtime. For normal text, I can use the TextFlowUtil.importFromString() method to convert it, but this doesn't work with the clickable anchor.
      Can anyone shed some light on how I should do this?
        • 1. Re: Using an <a click=""> in RichEditableText
          FTQuest Level 3
          You can put your text in xml, download it at runtime, and then everything would work in the same way; i.e. using FlowElementMouseEvent.CLICK.
          <TextFlow version="2.0.0" xmlns="http://ns.adobe.com/textLayout/2008" >
          <p>
          Lorem ipsum dolor sit amet, consectetur adipiscing elit.
              <a href='event:yourCustomClick'>Quisque tempus</a>, eros ac dignissim interdum, elit sem euismod velit, eget laoreet urna metus nec enim.
          </p>
          </TextFlow>
          HTH,
          FTQuest
          • 2. Re: Using an <a click=""> in RichEditableText
            EricJ32 Level 1
            Thanks, that pointed me in the right direction. My problem was that the method wasn't being called. I didn't need to put it into an XML file; the resource file I was using was fine, along with a TextFlowUtil.importFromString call.
            For completion's sake, here's my solution:
            The trick was to add an event listener on creationComplete for the particular click event:
            private function creationComplete(event:FlexEvent):void
                 richText.textFlow.addEventListener("myCustomClick", customClickHandler);
            private function customClickHandler(event:FlowElementMouseEvent):void
                 Alert.show("hi");
            <s:RichEditableText selectable="false" editable="false" textFlow="{textWithLink}" />
            where "textWithLink" looked like:
            <span>This is my custom text with a </span> <a href="event:myCustomClick">clickable link</a>
