0 Replies Latest reply on Apr 26, 2011 6:41 AM by Mete Atamel
    [svn:fx-trunk] 21141: Bug: 2780176 - Logging and logging out multiple times in LCDS can cause duplicate session detected errors .
    Mete Atamel Level 1
      Revision: 21141
      Revision: 21141
      Author:   matamel@adobe.com
      Date:     2011-04-26 06:40:39 -0700 (Tue, 26 Apr 2011)
      Log Message:
      Bug: 2780176 - Logging and logging out multiple times in LCDS can cause duplicate session detected errors.
      QA: Yes
      Doc: No
      Checkintests: Pass
      Details: When a logout was followed by an immediate login, sometimes the server would throw duplicate session detected errors. This was because when logout happened, a fire-and-forget disconnect message was sent to the server that established a new session, and if the subsequent login happened before disconnect ACK returned from the server, that would establish another session and hence the error. The fix is to insert a slight delay between disconnect and ResultEvent dispatching. This way, disconnect has a chance to return before a login is performed.
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/ChannelSet.as
