2 Replies Latest reply on Apr 27, 2011 5:35 AM by PaddyMc2010
    ColorTransform Question
    PaddyMc2010
      Hi All,
      Quick and im sure very easy question, i am new to flex and coding in general.  I have 3 Images that i want to use as a kind of rollover toolbar.
      I want to use the color transform to highlight as they go along the images.  Using the code below this will do exactly what i want when passing the ImageID Search and looks good.  However i need this to be more generic, so i can pass in ImageID into the functions and add the arguments to the mx image mouse over etc.  However when i do this it dosnt like a string to be passed and and generic object will not work either. Can anyone advise how i might be able to go about doing this and passing the appropiate args into my function?
      <mx:Image
      id="Search"
      errorString="S
      earch"
      source="
      @Embed('images/toolbar/find.png')"
      click="searchOnClick()"
      mouseOver="onImageMouseOver()"
      mouseOut="onImageMouseOut()"
      public
      var myColorTransform:ColorTransform;
      private function onImageMouseOver():void
      myColorTransform =
      new ColorTransform(1,1,1,1,50,50,50);
      Search.transform.colorTransform = myColorTransform;
      private function onImageMouseOut():void
      myColorTransform =
      new ColorTransform();
        • 1. Re: ColorTransform Question
          ipauland Level 1
          This should give you a leg up: don't forget to pass the event object and use it to know what object is being targetted.
          Haven't tested it.
          Paul
          <mx:Image
          id="Search"
          errorString="S
          earch"
          source="
          mouseOver="onImageMouseOver(event)"
          mouseOut="onImageMouseOut(event)"
          private function onImageMouseOver(e:MouseEvent):void
          myColorTransform =
          e.currentTarget.transform.colorTransform = myColorTransform;
          private function onImageMouseOut(e:MouseEvent):void
          myColorTransform =
          • 2. Re: ColorTransform Question
            PaddyMc2010 Level 1
            Paul,
            Its easy when you know how, You are right on the money and it works a treat, i was trying to pass the actual object and not the event.
            Thanks a bunch this is great.
            Paddy
