4 Replies Latest reply on Apr 27, 2011 8:18 AM by mattcom
    ArrayCollection filterFunction
    mattcom
      Does anyone know how to make a copy of the ArrayCollection as an instance of the filtered one.
      For example if I have myArrayCollection and I filter it with a filterFunction and say have 100 returned results
      myArrayCollection.filterFunction = myFilterFunction;
      myArrayCollection.refresh();
      trace(myArrayCollection.length.toString()) // 100;
      but if I do this:
      myACcopy = myArrayCollection
      myACcopy.filterFunction = myFilterFunction2;
      myACcopy.refresh();
      trace(myACcopy.length.toString()) // 15
      trace(myArrayCollection.length.toString()) // 15;
      You see, when I filter the copy of the AC and refresh it, somehow it replaces the values of myArrayCollection, and I don't want that.  I want myArrayCollection to still have 100 results.
      Any suggestions?
                private function countNode2(field:String, value:String):int
                      var tempArr:ArrayCollection = new ArrayCollection();
                      tempArr = HMData;
                      myFilterField = field;
                      myFilterValue = value;
                      tempArr.filterFunction = filterCount;
                      tempArr.refresh();
                      return tempArr.length;
        • 1. Re: ArrayCollection filterFunction
          saisri2k2 Level 4
          http://jodieorourke.com/view.php?id=105&blog=news
          you are not cloning the array collection, From what I see, you are playing with the same reference of the array collection.
          • 2. Re: ArrayCollection filterFunction
            ScalaEnthusiast
            The filterfunction just creates a filtered view of your collection - it doesn't actually remove anything. If you want to see the full collection again, you need to set the filterfunction to null and call refresh() on the collection.
            If you need a totally separate identical collection to modify, see the post referenced in the other answer to your question. Doing the copy could get expensive so make sure that is what you actually "need" to do and not just filter the view of the one collection.
            • 3. Re: ArrayCollection filterFunction
              mattcom Level 1
              Thank you for your answers, unfortunately I've tried the suggested way through the link
              original HMData.length = 500
              HMData.filterFunction  = ...
              HMData.refresh()
              filtered HMData.length = 200
              var tempArr:ArrayCollection = new ArrayCollection(HMData.source);
              tempArr.length = 500;
              unfortunately it ignores the previous filtering on HMData.
              I also tried
              var tempArr:ArrayCollection = ObjectUtil.copy(HMData as Object) as ArrayCollection;
              tempArr.length = 500 there as well.
              • 4. Re: ArrayCollection filterFunction
                mattcom Level 1
                Ok, I figured out the answer. It's:
                tempArr.source = HMData.toArray();
                now after I run the filter on tempArr it's length differs from HMData as desired.
                                tempArr.refresh();
                            private function filterCount(item:Object):Boolean
                                if(item[myFilterField] == myFilterValue)
                                    return true;
                                } else {
                                    return false;
