4 Replies Latest reply on Nov 29, 2011 6:11 AM by Han Dao
    retrieve adobe id
    jscotti
      Is there a way to retrieve the three digit identification number that is assigned as a job is logged. It is visible in the AdminUI, but I'm not sure if there is a way to retieve this data so it can be used on the form as a unique id for the form.
        • 1. Re: retrieve adobe id
          $Nith$ Level 4
          Process Id : Represents an unique Identification of each Process Instance. This number will be generated after the process invocation
          Task Id: Represents each unique Task. One or more tasks can be created for each Long-Lived Process. Note that thi unmber will be generated even before a process is invoked. E.g If an user clicks on a process card from Start Process tab, a Task will be created with a unique Task Id. However, the associated Procedd Instance Id will 0 as the process is not yet invoked. Once the user fills the form and click Complete button, a Process Instance Id will be generated.
          Job Id: Represents each job executed by the JobManager service. These Jobs are used internally and you usually don't access these jobs in your process.
          So disregarding the Job Id, you may choose one from the two other options (Process Id or Task Id).
          Comparison:
          *One advantage of using ProcessId is, you can easily track the process details thgouh AdminUI. If you use Task Id, you will still able to track but need to find out the process Id first.
          *The disadvantage is that the first user of the process cannot see the Process Id until the process is started/invoked. If you use Task Id, the first user of the workflow can see an Unique Id.
          Hope that helps!
          Nith
          • 2. Re: retrieve adobe id
            Han Dao Level 1
            Hi Nith,
            Is it possible to find the status of the process when all info that I got are the Initiator (form filler) with date and time but not the Process ID?
            A query to run from the database would be helpful..
            Thanks in advance,
            Han
            • 3. Re: retrieve adobe id
              $Nith$ Level 4
              SELECT * FROM TB_PROCESS_INSTANCE A
              JOIN EDCPRINCIPALUSERENTITY B ON A.CREATOR_ID = B.REFPRINCIPALID
              Where B.UIDSTRING='administrator' and start_time= '2011-11-24 08:29:31'
              • 4. Re: retrieve adobe id
                Han Dao Level 1
                Thank You Nith!
