10 Replies Latest reply: Apr 9, 2012 11:16 AM by azeem878 RSS
    Preserving whitespace when importing an html String into a RichText
    Devin Warren
      Brief situation overview:
           The program allows the user to edit RichTextEditors and other classes in order to create presentable documents. The program handles printing the document so when the user wants a print preview or to actually print they select that option from the program's menu. Calling a print preview requests the printable data from all the elements in the document and puts them into formats that look more presentable (without editing controls).
      Problem:
           When the RichTextEditor's htmltext is retrieved it gets imported into an instance of RichText but the whitespace gets collapsed.
      Example:
      This (in RTE):
           Table
           Key     Value
           1         2
           3         4
           5         6
      Becomes (in RT):
           Table
           Key Value
           1 2
           3 4
           5 6
      Relevant code:
           if(data is String) {
                var curElem:RichText = new RichText();
                var importer:ITextImporter = TextConverter.getImporter(TextConverter.TEXT_FIELD_HTML_FORMAT);
                curElem.textFlow = importer.importToFlow(data);
                //Some curElem.textFlow leaf color and baselineShift changes
                addToPage(curElem);
           } else ...
      What I've tried/noticed:
           I have tried putting in
                XML.ignoreProcessingInstructions = false;
                XML.ignoreWhitespace = false;
                XML.prettyPrinting = false;
           and
                curElem.textFlow.whiteSpaceCollapse = WhiteSpaceCollapse.PRESERVE;
           before the importer.importToFlow() function gets called but it hasn't changed the results at all. Although changing the textFlow.whiteSpaceCollapse value wouldn't have done anything since the importer just creates a new textFlow (I thought I'd mention that I tried it anyway). When I tracked the values for XML that I changed during this process I made sure that they weren't getting reset to true at some point. Having said that I didn't do a depth step through the whole importToFlow() call so if it reset the values and changed them back (I don't know why it would do that) I probably wouldn't have noticed.
      Sorry if I'm unclear about anything, if you need any more information then please let me know.
      -Devin
