2 Replies Latest reply on Apr 27, 2011 1:46 PM by Ned Murphy
    GETURL ERROR
    melas076 Level 1
      Dear all,
      I need help with this code: bigImage.productTitle["txtlink"].onRelease = function(){
                  getURL("+linktxt+","_blank");
      linktxt is an attributes from xml = "pdf files"
      i apreciate your help
      MELAS
        • 1. Re: GETURL ERROR
          I cnanot account for anything else in the code, but you should not be quoting the link as you have.  If linktxt is a string of a url then use:
          getURL(linktxt,"_blank");
          • 2. Re: GETURL ERROR
            I should add that the line  before that is also questionable... if txtlink is a variable you do not want to quote it, as in...
            bigImage.productTitle[txtlink].onRelease
            and if it is a String you do not need to use it as a String at all since it is a complete word in the brackets by itself, as in...
            bigImage.productTitle.txtlink.onRelease
