5 Replies Latest reply on Apr 28, 2011 5:57 PM by John Hawkinson
    [CS4:JS] How to run ".sh" file through Javascript
    Adobe-InDesign CS4
      Dear All,
      How to run the ".sh" file through Adobe InDesign Javascript, I used the below coding:
      //================== Code =============================//
      var myFile = File("xxx/xxx/xxx/Test.sh");
      var Exec = "sh" + " "+ "\""+myFile+"\"";
      File(Exec).execute();
      //================== End =========================//
      the above coding is not working, I checked before without "sh" also, It is not working.
      Please anyone can give me the solutions & suggestion, and I will appreciate.
      Thanks & Regards
      T.R.Harihara SudhaN.,
        • 1. Re: [CS4:JS] How to run ".sh" file through Javascript
          John Hawkinson Level 5
          You can't do it. Your only choice is to use VB or AppleScript, as appropriate for your platform, to call the shell.
          This is what I use under OS X:
          function shell(cmd) {
              var
                  rv,
                  call ='do shell script "'+
                      cmd.replace(/\\/g,"\\\\").replace(/"/g,'\\"')+
              try {
                  rv = app.doScript(call,
                      ScriptLanguage.APPLESCRIPT_LANGUAGE);
              } catch(e0) {
                  rv = e0+"\n"+(rv?"":rv);
              return rv;
          • 2. Re: [CS4:JS] How to run ".sh" file through Javascript
            Adobe-InDesign CS4 Level 1
            Dear Hawkinson,
              Many thanks for this quick reply, I'm really very happy, but unfortunately the script is return the "Permission denied" value.
            I used the below code, Please kindly change if anything is wrong.
            //====================== Script Source =====================//
            var myFile ="/Applications/MacXinPro/IDMLExportparse.sh";
            shell(myFile);
            var
            rv,
            call ='do shell script "'+ cmd.replace(/\\/g,"\\\\").replace(/"/g,'\\"')+'"';
            try {
            rv = app.doScript(call,ScriptLanguage.APPLESCRIPT_LANGUAGE);
            } catch(e0) {
            return rv;
            //====================== End : Script Source =====================//
            //=========== Output ================//
            Execution finished. Result: Error: sh: /Applications/MacXinPro/IDMLExportparse.sh: Permission denied
            undefined.
            Please kindly help me...
            Thanks & Regards
            T.R.Harihara SudhaN
            • 3. Re: [CS4:JS] How to run ".sh" file through Javascript
              Does your file IDMLExportparse.sh have execute permissions set?
              If you open Terminal.app and type
              does it work? Or do you need to run "sh"? If so, either adjust the
              permissions with
                   chmod a+x /Applications/MacXinPro/IDMLExportparse.sh
              or change the JavaScript to:
              shell("sh "+myFile);
              • 4. Re: [CS4:JS] How to run ".sh" file through Javascript
                Message was edited by: Harihara Sudhan
                • 5. Re: [CS4:JS] How to run ".sh" file through Javascript
                  Hmm...looking back at my script I notice now:
                  } catch(e0) {
                  I'm not quite sure what I was thinking here. I think the ?: is backwards and this was intended to be (rv?rv:"") but that doesn't really make sense either, since that's the same as (rv), and rv never gets set if there's an exception anyhow. so it could have just been:  rv = e0;
                  Oh well... It doesn't break anything, just looks ugly.
