8 Replies Latest reply on May 10, 2011 7:07 AM by Muppet Mark-QAl63s
    Case insensitive replace
    Ghoulfool Level 1
      I'm working on a script that does a text search and replace in layer names, but it could be improved with the addition of case insensivity
      function processLayers (srcDoc) {
      for (var i = 0; i < numLayers; i++)
      var thisLayer = srcDoc.artLayers[i].name;
      if (thisLayer.search(mySearch) != -1)
         tempName = app.activeDocument.artLayers[i].name
         app.activeDocument.artLayers[i].name = tempName.replace(mySearch,myReplace)
      } //function close
      I know the javascript method is to add slash i for case insensitive but I don't know how that transfers to the Photoshop DOM. Can anyone kindly help me out. Cheers
        • 1. Re: Case insensitive replace
          Muppet Mark-QAl63s Level 4
          Im not sure I understand what you want here… Could you not just pass your 'mySearch' to the reg exp constructor and have that include case or ignore case…
          • 2. Re: Case insensitive replace
            Michael L Hale Level 5
            You can either use a RegExp as Mark suggested or force the case to what ever case your replace string is using.
            tempName = app.activeDocument.artLayers[0].name.toLowerCase();
            • 3. Re: Case insensitive replace
              Ghoulfool Level 1
              Sorry I didn't explain it very well. If the user puts in "layer" as the search criteria it would replace any layers called "layer", "LAYER" or "Layer" The replacement would be to lowercase.
              • 4. Re: Case insensitive replace
                Yes, "layer", "LAYER" or "Layer" all return 'layer' with toLowerCase() so replace should find and replace any of those three layer names if 'layer' is the search string.
                • 5. Re: Case insensitive replace
                  Ghoulfool Level 1
                  var srcD
                  oc = app.activeDocument;
                  fileName = app.activeDocument.name;
                  var search = new Object();
                  var replace = new Object();
                  // prompt for search criteria
                  search.pattern = prompt('Enter the search pattern to look for for all layers.\n', 'Search');
                  replace.pattern = prompt('Enter the word to REPLACE ' + search.pattern + '.\n', 'Replace');
                  alert("Replacing  '"+ search.pattern + "' to be replaced with '" + replace.pattern + "'.")
                  var mySearch = search.pattern;
                  var myReplace = replace.pattern;
                  var numLayers = srcDoc.layers.length;
                  var layers = srcDoc.layers;
                           // extra line here
                           var layer = layers[i];
                           if (layer.typename == 'LayerSet')
                              alert("This is a group")
                        else
                        // returning lowercase of string
                        var thisLayer = srcDoc.artLayers[i].name.toLowerCase();
                          // alert (i + " " + layer)
                              tempName = app.activeDocument.artLayers[i].name.toLowerCase();
                  } // function close
                  The code now works as I want it to. But it ignores groups buts falls over with layers in groups. As i'm not sure how they are indexed I'm a bit stumpted. Is there any documentation on layersets that I might find useful. Cheers
                  • 6. Re: Case insensitive replace
                    Ghoulfool, I gave this a go… Ran a few basic tests and I think I got it right? Do let me know… Quite possibly not the most efficient way… But there you go…
                    #target photoshop
                    function layerNamer() {
                         var opts = new Object();
                         var win = new Window('dialog','Rename Layers…');
                         win.preferredSize = [200,undefined];
                         win.opacity = 0.95;
                         var red = 0, green = (1/256)*102, blue = (1/256)*153;
                         win.graphics.backgroundColor = win.graphics.newBrush
                         (win.graphics.BrushType.SOLID_COLOR, [red, green, blue]);
                         var grp1 = win.add('group');
                         grp1.orientation = 'column';
                         var opText = grp1.add('statictext',undefined,'Options: ');
                         opText.graphics.font = ScriptUI.newFont('Helvetica', 'Bold', 12);
                         opText.graphics.foregroundColor = opText.graphics.newPen
                         (opText.graphics.PenType.SOLID_COLOR, [1.0, 1.0, 1.0], 1);
                         grp1.add('statictext', [5,15,195,37], 'Find String/Expression:');
                         var findEdit = grp1.add('edittext', [5,45,195,67], '');
                         findEdit.graphics.backgroundColor = findEdit.graphics.newBrush
                         (findEdit.graphics.BrushType.SOLID_COLOR, [1.0, 1.0, 1.0], 1);
                         findEdit.active = true;
                         grp1.add('statictext', [5,75,195,97], 'Replacement String:');
                         var repEdit = grp1.add('edittext', [5,105,195,127], '');
                         repEdit.graphics.backgroundColor = repEdit.graphics.newBrush
                         (repEdit.graphics.BrushType.SOLID_COLOR, [1.0, 1.0, 1.0], 1);
                         var chkboxA = grp1.add('checkbox', [5,135,195,157], 'Case Sensitive');
                         var chkboxB = grp1.add('checkbox', [5,165,195,187], 'Global');
                         var chkboxC = grp1.add('checkbox', [5,195,195,217], 'Include Text Layers');
                         var grp2 = win.add('group');
                         grp2.cancelBtn = grp2.add('button',undefined,'Cancel',{name:'cancel'});
                         grp2.okBtn = grp2.add('button',undefined,'OK',{name:'ok'});
                         grp2.okBtn.onClick = function() {
                              opts.find = findEdit.text;
                              opts.replace = repEdit.text;
                              opts.ignore = chkboxA.value;
                              opts.global = chkboxB.value;
                              opts.txtLay = chkboxC.value;
                              processDoc(opts);
                              win.close(0);
                         win.center();
                         win.show();
                    if ( app.documents.length > 0) { layerNamer(); }
                    function processDoc(opts) {
                         var find;
                         if ( opts.global && !opts.ignore ) { find = new RegExp(opts.find,'gi'); }
                         if ( opts.global && opts.ignore ) { find = new RegExp(opts.find,'g'); }
                         if ( !opts.global && !opts.ignore ) { find = new RegExp(opts.find,'i'); }
                         if ( !opts.global && opts.ignore ) { find = new RegExp(opts.find); }
                         var doc = app.activeDocument;
                         recurseLayers(doc.layers);
                         function recurseLayers(layObj) {
                              for ( var i = 0; i < layObj.length; i++ ) {
                                   if ( find.test(layObj[i].name) )
                                             if (layObj[i].kind == LayerKind.TEXT && !opts.txtLay) { continue; }
                                             layObj[i].name = layObj[i].name.replace(find,opts.replace);
                                   if ( layObj[i].typename == 'LayerSet' )
                                        { recurseLayers(layObj[i].layers); }
                    • 7. Re: Case insensitive replace
                      Ghoulfool Level 1
                      Mark did tou mean to post this here or maybe on the end of Clevadio's post looking for replacing text (not layer names)
                      http://forums.adobe.com/thread/848745?tstart=0
                      • 8. Re: Case insensitive replace
                        I was meant to be here with regard to your last comment about layers within layer sets… if thats what you meant by groups?
