2 Replies Latest reply on Apr 28, 2011 10:31 AM by Shravan P
    Can any one help me regarding HTTPService
    Raghuvasa
      Hi All,
      I have a service with id as histogramService and i am adding listener to to this service dynamically in actionscript method like below shown
      histogramService.addEventListener(ResultEvent.RESULT,function(event:ResultEvent):void
                           methodCalling(event);
      Now the problem is the result event is coming two times if i add like above.
      The result event coming only one time if i add result to the directly to the service like below shown
      <mx:HTTPService id="histogramService" showBusyCursor="true"  useProxy="false" resultFormat="e4x" method="POST" result=" methodCalling(event)"  />
      i have to add listener dynamically and i need to get result only once.
      Can any one help me regarding this.
      Thanks in  advance
      Raghu
        • 1. Re: Can any one help me regarding HTTPService
          EvyatarBH Level 3
          Make sure you call the addEventListener function only once and that you removed the relevant MXML definition (result=" methodCalling(event)").
          • 2. Re: Can any one help me regarding HTTPService
            Shravan P Level 1
            I am bit confused with your code/question.
            Hope this below example solves your issue.
            private function fillList(src:String):void{
                                histogramService.url = src;
                            histogramService.send();
            private function methodCalling(event:ResultEvent):void {
                           //sample code
                            var xmlList:XMLList = XML(evt.result).images.image;
                            xmlListColl = new XMLListCollection(xmlList);
            <mx:Button label="fill"
                            click="fillList('gallery.xml');" />
            <mx:TileList id="tileList"
                        dataProvider="{xmlListColl}"
                        columnCount="3"
                        columnWidth="150"
                        rowCount="2"
                        rowHeight="100" />
            -Shravan P.
