4 Replies Latest reply on Apr 28, 2011 2:31 PM by cfsasmml
    Premiere Overwriting Media Files
    cfsasmml
      Having a serious problem. Editing a sequence with video footage from a Canon 5D and 7D, and an audio track in WAV format from a Xoom recorder. Attempting to cut the audio to replace camera audio.
      After working with the project for a couple of days, Premiere appears to have overwritten a number of the ORIGINAL audio files on the hard disk. The affected clips in the timeline appear with bold hashmarks through them (the track is not locked, it is only a random selection of clips in the timeline that are effected). When the sequence plays, there is no audio from these clips. They no longer display a waveform in the source monitor.
      Further, the link to the orginal media is no longer present (the opotion to "reveal in finder" or "reveal in Bridge" in the project panel is greyed-out.
      When I search in the media file folders on the har disk, I find that the original files have been changed at the time the clips became inaccesible. When I attempt to play them in Quicktime or Quickview them, they open showing no contents (0.00 start time and 0.00 duration), though the files still display a file size (i.e. 7mb).
      We have replicated this problem storing our project (and its corresponding media folders) both on a shared raid drive on a workstation and on a striped raid drive on a shared server directory.
      Hardware/software info as follows:
      Editing performed on an iMac i7 2.93 ghz, 8 GB ram, ATI Radeon HD 5750/1GB, Premiere Pro CS 5.03
      Files located on a Mac Pro Server 3.2 ghz Quadcore, 8 GB ram running OS X Server 10.6.7 with a 2 TB Raid 1 (2 x 1 TB Drives Striped).
      Previously the files were on a Mac Pro Workstation, OS X 10.6.7 with a shared 4 TB Raid 1 (2 x 2 TB Drives Striped)
      Any help would be GREATLY appreciated!
      David Breen
      Creative Director
      Canadian Forces School of Aerospace Studies
      Department of National Defence
      Government of Canada
        • 1. Re: Premiere Overwriting Media Files
          the_wine_snob Level 9
          Welcome to the forum.
          PrPro will never overwrite any original Asset, unless one were to Export the Timeline to that exact folder, with the exact file name, as the Asset, and then it would crash.
          What happens when you Import an Asset into a Project is that PrPro reads the data in that file. It then creates a link (in XML inside the PRPROJ Project file). PrPro will then seamlessly and transparently create working files, so that you can display the data from those untouched Asset files. PrPro is a non-destructive NLE.
          In the Sequence Timeline, the original Assets are not used. PrPro has already read (only) the data, and is then only writing XML instructions on what you want to do. Nothing has been generated, beyond the XML instructions, and they only affect what is displayed, and then tell PrPro what to do with the data from those original Assets, when one Exports.
          The actual Assets do not exist in the Project, just a representation of them.
          This ARTICLE goes into more detail.
          • 2. Re: Premiere Overwriting Media Files
            cfsasmml Level 1
            Hi Bill,
            Thanks for the reply... I am aware that PPro is Non-Destructive, that's why we are so puzzled as to what is happening. I was hoping that perhaps SOMEONE has had a similar experience, hence the post. I realize that this should not be possible (i.e. Premiere overwriting or corrupting linked media files), and should mention that we've used Premiere CS 3 followed by CS 4, and, for the past several months, CS 5, on a number of PC's and Macs, without anything like this every happening, nor have I ever encountered this with any version of FCP.
            Myself and one of my coworkers searched rather extensivley online for a similar occurence, but came up empty.
            I realize it's possible that this is an OS issue, but am pursuing every possibility to find the source of the problem.
            Thanks much!
            David Breen
            • 3. Re: Premiere Overwriting Media Files
              Colin Brougham Level 6
              Premiere may be non-destructive, but I have had it break files before, in a manner similar to what you're describing. In my experience, this has been tied to the "Write XMP ID to Files on Import" option in Edit > Preferences > Media.
              With that option enabled, Premiere will write some metadata into an imported file which it then uses to keep track of the file as it travels through the Adobe applications. I've had a few instances--both with specific file formats (SWF is an example) and with random individual files--where that process effectively broke files both in Premiere and on the desktop. I've actually rescued a few files by opening them up in a text editor, deleting the metadata (it's visible as XML), and resaving the file--it imports and plays properly, then. Of course, if you don't disable the "Write XMP ID" option, it happens all over again.
              Not saying this is specifically what is happening here, but here's a test if you're feeling enterprising:
              1. Find a file (WAV, for example) that hasn't been imported into Premiere yet. Make a copy of it with Explorer.
              2. Import one of the copies into Premiere, making sure the "Write XMP ID" option is checked before you do so.
              3. Grab and install WinMerge, which is a great little program for comparing two files. It will have an option to add an Explorer context menu item to "Compare" files--this makes it easy to do just that.
              4. Using WinMerge, compare the imported and the not-yet-imported WAVs; near the top of the file that was imported, you should see a few lines of XML data, while the file that wasn't imported won't have this. WinMerge keeps the scrolling synced so you can easily see differences between the two files. The rest of the file will be all binary mish-mash, but you should be able to see where the metadata is inserted--make a note of that.
              5. With Premiere close, find one of your "damaged" WAVs (make a copy of it, just to be safe), and open it up in a text editor; I'm partial to Notepad++. Pretty quickly, you'll be able to see the injected XML metadata. Simply select it and delete, making sure to delete only the parts that weren't in the non-imported file above. It should be pretty clear where that is, but just in case, that's why we made a duplicate first.
              6. Once you delete the metadata, simply save the file, and try playing it back in whatever player didn't work correctly before. If it works (here's hoping!), give it a shot in Premiere. If it works there, I'd suggest fixing all your broken WAVs, and then opening them in an audio editor of one sort another and saving to new files (same format). This will basically just repackage the contents of the file in a new container that hopefully won't break again if you re-enable the "Write XMP ID" option (which is a good idea).
              If that doesn't work... well... we'll cross that bridge later
              • 4. Re: Premiere Overwriting Media Files
                cfsasmml Level 1
                Hi Colin,
                I will try your suggestion tommorow (when I am back at the office). We believe we have discovered that the problem is specific to wav files, and that the damage is in the file header. Not sure what triggered it (possibly what you are describing?) It seems to only occur once the files are added to the timeline (the damaged asset files are time stamped as being modified at that time). I have found a number of discussions relating to damaged wave files on other forums. One suggestion is that the files becomes susceptible to corruption if the file names exceed 20 characters... indeed, one of our staff had renamed the files and the names were longer than 20 chars. We have used Audition to batch convert a backup of the files to AIFF, allowing us to continue working on the project. Still would like to know what the actual problem was, though. We'll see what tomorrow brings!
                Thanks for your help,
                David Breen
