4 Replies Latest reply on Apr 28, 2011 2:24 PM by Safetymatch99
    Sequence Settings
    Safetymatch99
      Hi there,
      I have been editing together a project for the pasr few days only to realise my sequence settings are set at 25 fps when the imported footage is actually 24 fps, can I change the settings and if not how much will this mistake affect my project.
        • 1. Re: Sequence Settings
          Jim_Simon Level 8
          You can't change them, but you can create a new sequence and Copy/Paste everything into it.  Just make sure to expand the sequence to frame level and check all your edit points afterwards.
          • 2. Re: Sequence Settings
            Safetymatch99 Level 1
            Tried that, but seem to have lost all video transitions, any way of keeping them?
            • 3. Re: Sequence Settings
              Jim_Simon Level 8
              They normally don't go anywhere.  Just hit CTRL-A in the old sequence to select everything, CTRL-C to copy, then move to the new sequence and hit CTRL-V to paste everything.
              • 4. Re: Sequence Settings
                Colin Brougham Level 6
                Yeah, that will happen, because the timebase is different and the edit points will all have shifted--in fact, they'll often shift to the "middle" of frames, which aren't legal time demarcations. You'll end up with a big mess when you try to export.
                First, tweak all your edit points; you can zoom in and then just drag the ends. They'll snap to the whole frame demarcations. Then, drag your original timeline panel out into its own panel; if you grab the sequence tab and drag down, you'll see a purple trapezoid appear and you can drop the panel so you have two visible sequences. From there, you can copy from the first and paste into the second--it won't be fun.
                If you're using a standard transition and duration, you could also select all the clips in the new sequence and go to Sequence > Apply Default Transitions to Selection.
