1. Re: Can not copy spaces from some pdf file
Bernd Alheit Apr 29, 2011 1:18 AM (in response to asdfabcedasf)I can't see any problem with this file.
2. Re: Can not copy spaces from some pdf file
MichaelKazlow Apr 29, 2011 7:26 AM (in response to asdfabcedasf)I tried copying the initial text in the box at the top and certainly I'm getting gibberish. When I export to text, most of the text is ok. However, the same text that I copy as gibberish is gibberish on export. When I use Acrobat Preflight tools, it mentions the file has compressed objects within pdf, my bet this is the cause of gibberish. I don't think there is a fault in the pdf, but I think the way the pdf file was created has created issues for it use for anything other than viewing or printing.
3. Re: Can not copy spaces from some pdf file
CtDave Apr 29, 2011 8:02 AM (in response to asdfabcedasf)It appears that the PDF creation process was deliberately intended to make repurpose of content difficult.
--| The table description/caption uses "Calibri" font having non-standard lookup tables.
(for some relevant discussion scroll to UVSAR's post in this thread:
http://acrobatusers.com/forum/printing-prepress/pdfs-printing-garbage-characters )--| The 3.3 font size of the table cells' content.
--| The small page size associated with dense packing of content.Perhaps if you print to an image (from Acrobat) and OCR the resultant PDF you may be able to do something.
However, the small font size may be problematic.Be well...
