17 Replies Latest reply on Jun 1, 2011 5:23 AM by Flying_Kiwi
    BROWSER WON'T READ PDFs
    SLR5000
      Wonder if someone can advise me as to why I am unable to view PDFs on-line.   As an example, I go to a web site to view and to download a PDF and the browser says, 'Internet Explorer cannot display the webpage'.   My operating system is Windows 7, 64 bit.   Thanking you in anticipation.   Lance (Australia).
        • 1. Re: BROWSER WON'T READ PDFs
          cowboy1611
          I was just about to post the same thing .
          Hope there are some answers.
          • 2. Re: BROWSER WON'T READ PDFs
            Fabrizio Bruini
            The same thing also for me....the same system...
            I hope for one answer...
            • 3. Re: BROWSER WON'T READ PDFs
              luizap
              I'm having the same problem.  It's very frustrating..............except it just won't display anything
              Windows 7, IE 8, Adobe reader X.  I have also done a repair of Reader and restarted my computer.
              In IE 8, tools, programs, the add-in for Adobe reader does not show as being currently loaded, but it is enabled.
              One other note, I can save the file on my computer, and then open it.  I don't always want to do this tho............
              Does this help>
              Another thought.  Every time reader gets updated with a newer version, something doesn't work the way it used to, or it doesn't work right.  It used to be a great PDF reader.  Is there something else that will do the same thing?
              • 4. Re: BROWSER WON'T READ PDFs
                ~graffiti Adobe Community Professional & MVP
                It's going to be hard to answer anyone without knowing what browser, version of browser, exact version and latest update of Reader...etc.
                The more info you can give, the better a chance of getting an answer.
                • 5. Re: BROWSER WON'T READ PDFs
                  ohm777
                  Windows Vista 64 Bit.  Internet Explorer 8 (256 bit encryption).  Windows Firewall.  Adobe Reader X (10.0.1).  I also have the full version of Adobe 9 Pro (which I have unistalled to troubelshhot this problem since sites say I need Adobe Reader).
                  I didn't used to have this problem w/9 Pro, but now I have it regardless of whether I use Reader or Pro.  Worse yet, despite having dowloaded and installed Reader X, sites still say I need to install reader. It's as if the sites don't recognize Reader (or any other version of adobe installation(s)).  I don't have this problem on my XP laptop.  I'm able to view browser pdfs no problem.  Problem appears related to Windows64-bit OS.  Hope theres a solution soon.  ... Having to use my XP machine and then transfer to my [main] Vista machine is extremely frustrating.
                  • 6. Re: BROWSER WON'T READ PDFs
                    First off, update Reader. The current version is 10.0.3. There may be a fix there.
                    Also, be sure your browser is up to date as well.
                    • 7. Re: BROWSER WON'T READ PDFs
                      One more potential problem. Do you have Reader and Acrobat Pro on the same machine? If so, you have to remove one of them (then reinstall the other). They share and fight over resources so it's not recommended nor supported to have both.
                      You CAN however have Reader X and Acrobat X on the same machine.
                      • 8. Re: BROWSER WON'T READ PDFs
                        ohm777 Level 1
                        Thanks, but can't find Reader 10.0.3 ... Adobe web site only has 10.0.1 as a download.  And no, I don't have Pro 9.0 and Reader X on same machine ... only Reader X while I troubleshoot this problem since web sites keep saying I need Reader to view PDFs.  I know that shouldn't matter, the full version of Adobe should work as well, but now nothing works.
                        I'll be on the lookout for 10.0.3.
                        OMM
                        • 9. Re: BROWSER WON'T READ PDFs
                          Sorry. I think 10.0.3 is just for the Mac at this point. You are correct. 10.0.1 is the latest for Windows.
                          • 10. Re: BROWSER WON'T READ PDFs
                            cowboy1611 Level 1
                            I'm using Reader 9.4.4 and Firefox 3.6.13
                            • 11. Re: BROWSER WON'T READ PDFs
                              luizap Level 1
                              I changed my preferences in Reader X for the internet.  I unchecked "Display PDF in Browser".  Now I can display pdf files from IE, but I believe that it creates a temporary file and then displays it in Adobe not the browser.  Hopefully this will be a temporary fix.
                              Lois
                              • 12. Re: BROWSER WON'T READ PDFs
                                sumtinwrong
                                Having same problem.  Windows 7 SP1  - 32bit, IE 9, Reader 10.0
                                Use to be able to open PDFs - don't know what happened.  Could be, I got auto update and it failed???  Not sure what it was for but, vaguely recall one running for a hour+.  Probably figured because it was hung, it failed, and, being that it was very late, x'ed out of it and shutdown.  On hindsight, maybe I shouldn't have done that.  But if I left it to do it's thing, it could still be churning several days later.
                                Is it possible to fallback to a previous Adobe reader version?    Adobe, HEEELLLLPPPP!!!!!
                                • 13. Re: BROWSER WON'T READ PDFs
                                  tsleykis101
                                  Having a similar issue. I am able to view most PDFs, but the problem seems to happen more when the PDF are embedded into a page or when I try to download them. I read somewhere this was due to some issues with Adobe not getting the final codes for IE9?
                                  I'm running Win7 64bit with IE9. No problems with PDFs using Firefox 4 though.
                                  • 14. Re: BROWSER WON'T READ PDFs
                                    luizap Level 1
                                    I just updated to IE 9 and the problem went away.  Maybe Adobe is getting too far ahead of the game............
                                    • 15. Re: BROWSER WON'T READ PDFs
                                      Flying_Kiwi Level 1
                                      Maybe the particular problem you were experiencing went away but Reader 10.0.1 under Internet Explorer 9 definitely has its own issues.
                                      The toolbar in Reader X isn't even functional on my Windows 7 (150% Display setting) PC - whatever you click on has no effect, hows that for a showstopper bug! It's been like that for months even though the problem has been reported. The suggestion was to open the pdf and read it directly within Reader X which is all well and good if the website lets you do that but many don't. I really can't believe its taking Adobe so long to fix this compatibility with IE9/Windows 7 issue - long after IE9 has been released.
                                      • 16. Re: BROWSER WON'T READ PDFs
                                        twistedemotions
                                        If you are using a 64-bit version of Windows, your system will have both the 32-bit and 64-bit version of Internet Explorer.  Adobe Reader is a 32-bit application and will only install 32-bit browser plugins.  So if you are using 64 bit IE, you will not be able to view PDFs embedded into web pages or within a browser window.  You may however still download and open them like any file.
                                        For viewing within a brower window the Display PDF In Browser setting must be turning on in Reader's preferences.
                                        For viewing embedded within a page the Adobe PDF Reader (AcroPDF.dll) Add-on must not be disabled.
                                        • 17. Re: BROWSER WON'T READ PDFs
                                          Flying_Kiwi Level 1
                                          function(){return A.apply(null,[this].concat($A(arguments)))}
                                          Thanks for the reply and ideas. Indeed I am using the default 32 bit browser version of IE9 (the 64 bit version sits there on the start menu unused until more software producers make 64 bit plugins to go with it... are you listening Adobe
                                          I've checked all the other things you've suggested and they're all default settings after a fresh OS install and exactly as you list so it looks like this is down to bugs within Reader X 10.0.1 afterall. There is no mention of Adobe Reader at all in the Control Panel -> Internet Options -> Programs -> Manage Add-on section but I've not deleted anything there - perhaps this is associated with the problem?
