3 Replies Latest reply on Jun 11, 2011 5:11 AM by Jens Eckervogt
    Example for Runasadmin with AIr Applications
    Jens Eckervogt Level 1
      Hello,
      i have problem of nativepath because nativepathw rite to reg file example:
      How does air app work when air app writes double backsplash "\\".
      I have been coded thsi example for writing reg file than air app opens cmd file than cmd calls admin right of regedit.
      protected function init(event:FlexEvent):void
                          // Center main AIR app window on the screen
                          nativeWindow.x = (Capabilities.screenResolutionX - nativeWindow.width) / 2;
                          nativeWindow.y = (Capabilities.screenResolutionY - nativeWindow.height) / 2;
                          // Load regFile and cmdFile
                          getRegFile();
                     private var airAdminFile:File = File.applicationDirectory.resolvePath("AirAdmin.exe");
                     private var regeditFile:File = new File("C:\\Windows\\regedit.exe");
                     private var regFile:File = File.documentsDirectory.resolvePath("AirAdmin.reg");
                     private var cmdFile:File = File.documentsDirectory.resolvePath("AirAdmin.cmd");
                     private var cmdAppFile:File = new File("C:\\Windows\\System32\\cmd.exe");
                     protected function getRegFile():void
                          // regfile
                          var regFileStream:FileStream = new FileStream;
                          var regFileStructur:String = 'Windows Registry Editor Version 5.00\n';
                          regFileStructur += File.separator + "\n" + File.lineEnding;
                          regFileStructur += '[HKEY_CURRENT_USER\\Software\\Microsoft\\Windows NT\\CurrentVersion\\AppCompatFlags\\Layers]\n' + File.lineEnding;
                          regFileStructur += '"' + airAdminFile.nativePath + '"="RUNASADMIN"\n' + File.lineEnding;
                          var cmdFileStream:FileStream = new FileStream;
                          var cmdFileContent:String = regeditFile.nativePath + ' /s "' +regFile.nativePath + '"' + File.lineEnding;
                          if(regFile.exists, cmdFile.exists)
                               regFileStream.open(regFile, FileMode.READ);
                               regFileStructur = String(regFileStream.readUTFBytes(regFileStream.bytesAvailable));
                               regFileStream.close();
                               cmdFileStream.open(cmdFile, FileMode.READ);
                               cmdFileContent = String(cmdFileStream.readUTFBytes(cmdFileStream.bytesAvailable));
                               cmdFileStream.close();
                               openShell();
                          else
                               regFileStream.open(regFile, FileMode.WRITE);
                               regFileStream.writeUTFBytes(regFileStructur);
                               cmdFileStream.open(cmdFile, FileMode.WRITE);
                               cmdFileStream.writeUTFBytes(cmdFileContent);
                               openShell();
                     protected function openShell():void
                          cmdFile.openWithDefaultApplication();
      Than i try example when air application gets to administrative mode.
      PS: If your air app already is in the administrative mode. Than it will change to state like this
      adminConfig.xml
      <config>changeStateAdmin()</config>
      Than it runs with administrative right. If you like your app with rewriting and deleting function once applicationDirectory
      I hope you because it should fix for "\\" in regfile
      Why does nativepath not work with "\\" , when air app create regfile:
      [HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers]
      "C:\Program Files (x86)\AirAdmin\AirAdmin.exe"="RUNASADMIN"
      I try nativepath with air app function "\" to "\\" via replacement?
      "C:\\Program Files (x86)\\AirAdmin\\AirAdmin.exe"="RUNASADMIN"
      How does air app write when regfile does not give error with "\\"?
      Can you help me? I can not find google Problem with nativepath
      Thanks Jens
