2 Replies Latest reply on May 11, 2011 10:24 AM by InfoCon_Brian
    Printing a Flex Component
    InfoCon_Brian Level 1
      I am trying to print a component with a datagrid(print version) and panels.
      However, all I get is the uppper left corner with some of the controls filled.
      How do I get multiple pages?
      I have tried the following code segments:
      package
          import flash.printing.PrintJob;
          import flash.display.Sprite;
          public class BasicPrintExample extends Sprite
              var myPrintJob:PrintJob = new PrintJob();
              var mySprite:Sprite = new Sprite();
              public function BasicPrintExample()
                  myPrintJob.start();
                  myPrintJob.addPage(mySprite);
                  myPrintJob.send();
      and the following data grid centric:
      // The function to print the output.
              public function doPrint():void {
                  var printJob:FlexPrintJob = new FlexPrintJob();
                  if (printJob.start()) {
                      // Create a FormPrintView control as a child of the current view.
                      var thePrintView:FormPrintView = new FormPrintView();
                     Application.application.addChild(thePrintView);
                      //Set the print view properties.
                      thePrintView.width=printJob.pageWidth;
                      thePrintView.height=printJob.pageHeight;
                      thePrintView.prodTotal = prodTotal;
                      // Set the data provider of the FormPrintView component's data grid
                      // to be the data provider of the displayed data grid.
                      thePrintView.myDataGrid.dataProvider = myDataGrid.dataProvider;
                      // Create a single-page image.
                      thePrintView.showPage("single");
                      // If the print image's data grid can hold all the provider's rows,
                      // add the page to the print job.
                      if(!thePrintView.myDataGrid.validNextPage)
                          printJob.addObject(thePrintView);
                      // Otherwise, the job requires multiple pages.
                      else
                          // Create the first page and add it to the print job.
                          thePrintView.showPage("first");
                          thePrintView.pageNumber++;
                          // Loop through the following code until all pages are queued.
                          while(true)
                              // Move the next page of data to the top of the print grid.
                              thePrintView.myDataGrid.nextPage();
                              thePrintView.showPage("last");
                              // If the page holds the remaining data, or if the last page
                              // was completely filled by the last grid data, queue it for printing.
                              // Test if there is data for another PrintDataGrid page.
                                  // This is the last page; queue it and exit the print loop.
                                  break;
                              else
                              // This is not the last page. Queue a middle page.
                                  thePrintView.showPage("middle");
                      // All pages are queued; remove the FormPrintView control to free memory.
                      Application.application.removeChild(thePrintView);
                  // Send the job to the printer.
                  printJob.send();
        • 1. Re: Printing a Flex Component
          Shravan P Level 1
          check out this below code:
          <mx:Application
          xmlns:mx=http://www.adobe.com/2006/mxml layout="absolute" initialize="init()">
          <mx:Script>
          <![CDATA[
          import mx.printing.PrintDataGrid;import mx.printing.FlexPrintJob;import mx.collections.ArrayCollection;
          [Bindable]
          public var dataSource:ArrayCollection = new ArrayCollection();private var totalRecords:Number = 50;
          private function init():void {
          for (var i:int = 1; i<=totalRecords; i++) {
          var dataObject:Object = new Object();
          dataObject.Name =
          "Name #" + i;"Phone #" + i;"Address #" + i;
          dataObject.Phone =
          dataObject.Address =
          dataSource.addItem(dataObject);
          private function doPrint():void {
          var myPrintData:PrintDataGrid = new PrintDataGrid();
          Application.application.addChild(myPrintData);
          myPrintData.dataProvider = myData.dataProvider;
          myPrintData.width = printJob.pageWidth;
          myPrintData.height = printJob.pageHeight;
          printJob.addObject(myPrintData);
          while (myPrintData.validNextPage) {
          myPrintData.nextPage();
          Application.application.removeChild(myPrintData);
          printJob.send();
          </mx:Script>
          <mx:Panel title="PrintDataGrid" width="500" height="500" horizontalCenter="0" verticalCenter="0"center" verticalAlign="middle">
          horizontalAlign="
          <mx:DataGrid id="myData" dataProvider="{dataSource}" width="400" height="400" />
          <mx:Button label="Print" click="doPrint()"/>
          </mx:Panel>
          </mx:Application>
          • 2. Re: Printing a Flex Component
            Maybe, I wasn't clear.
            I am trying to print a component that contains a data grid and a panel with
            client information, etc.  printing the component as it appears on
            the screen.
            Similar to what is done in coldfusion report generator.
            Which I don't want to use, because I would have to trigger a
            download, etc. (a pain for the user.)
            So the printed output looks like an invoice.
