11 Replies Latest reply: Jun 4, 2012 8:35 AM by Muppet Mark RSS
    Help, Need to change ExportType
    RichardM0701 Community Member
      I have a handy script that exports my files to .png files. I need to change my script to export text files but I cannot find the appropriate ExportType for a .txt file. Can anyone help? See script below. Thank you very much in advance!!!
      var j, sourceDoc, targetFile;
      var destFolder = null;
      // Get the destination to save the files
      destFolder = Folder.selectDialog( 'Select the folder where you want to save the exported files.', '~' );
      if (destFolder != null) {
        for ( j = 0; j < app.documents.length; j++ ) {
          sourceDoc = app.documents[ j ]; // returns the document object
          targetFile = getNewName(sourceDoc, destFolder);
          // set PNG export options
          var opt = new ExportOptionsPNG24();
          opt.antiAliasing = true;
          opt.transparency = true;
          // Export
          sourceDoc.exportFile(targetFile, ExportType.PNG24, opt);
        alert( 'Files are saved as PNG24 in ' + destFolder );
      function getNewName(sourceDoc, destFolder) {
        var docName = sourceDoc.name;
        var ext = '.png'; // new extension for png file
        var newName = "";
        // if name has no dot (and hence no extension,
        // just append the extension
        if (docName.indexOf('.') < 0) {
          newName = docName + ext;
        } else {
          var dot = docName.lastIndexOf('.');
          newName += docName.substring(0, dot);
          newName += ext;
        // Create a file object to save the png
        saveInFile = new File( destFolder + '/' + newName );
        return saveInFile;
