5 Replies Latest reply on Apr 29, 2011 5:12 PM by Black Mutt
    ADE won't download file
    Black Mutt
      ADE gives the following message - this version of ADE does not support password protected documents.  The file in question is an Operating Manual for amateur transceiver and resides on my hard drive.  Is there a way around this problem?  Thanks for your help.
        • 1. Re: ADE won't download file
          Robin_R_D_ Level 1
          Hello
          Simply open the file in Adobe Reader. You must know the password to open the file.
          • 2. Re: ADE won't download file
            Black Mutt Level 1
            Thanks for the response.  Clarification - I can open and read the the file on my computer.  What I would like to do is download it to my E-Reader but as noted ADE will not work with the file as it is encrypted.  I do not want to change or edit the file - only download and read it on my E-Reader.  I am wondering why it will work on my computer through Acrobat, but not through ADE on my E-Reader.
            • 3. Re: ADE won't download file
              Robin_R_D_ Level 1
              ADE is unable (on PC-eReaders) to open password protected files and it was created to manage only DRM protected and "fully non protected" epub-pdf files, you must go to other app in your eReader able to manage traditional pdf files, perhaps this app is included in the app pool of your eReader. Another approach is removing password from your pdf. You must be sure than password protected PDF are not the more secure files.
              • 4. Re: ADE won't download file
                Level 4
                Unfortunately, this won't work - because the password protection can be set
                by the publisher and cannot be changed by the user.  Also, if the file is
                encrypted, it cannot be managed by ADE - which is the way ADE was designed,
                as noted above.  That's not true of Adobe Reader, which is based on your
                computer, not your ereader.  So, it's not possible to download an encrypted
                file to your ereader and open it with ADE.  That does NOT mean that your
                ereader won't work with encrypted files IF you use a different software.
                I'm not sure of all the software out there, so I can't suggest a particular
                one, but a little Google work might do the trick.
                Sorry!
                • 5. Re: ADE won't download file
                  Black Mutt Level 1
                  Thanks for the quick responses and information.  Have a great day
