6 Replies Latest reply on May 1, 2011 12:14 PM by Peter Grainge
    Linking to PDFs but not generating them
    celkins
      I'm using RoboHelp HTML on RH8, formerly using RH6. In RH6, I think there was somewhere to indicate that links to PDF files that exist in the same folder as a topic could be excluded from the compile. That allowed me to maintain one copy of the PDF that was not overwritten. I can't find how to set this in RH8. As a consequence, all of the PDF files that I link to (hundreds of them) are being copied to the Output folder, resulting in horrendous build times. Does anyone know where this setting is located in RH8? ~Carol
        • 1. Re: Linking to PDFs but not generating them
          The only thing I can think of is applying a build tag to the PDF. That would stop the PDF being included in the output. As the output folder gets cleared every time it would also mean those links would either fail or possibly even not show as links. In RoboHelp 8 PDFs are part of the search so that may account for the longer build time.
          I wonder if perhaps rather than the generated output you are thinking of the published output? If so there is a setting that only uploads changed files.
          @petergrainge
          • 2. Re: Linking to PDFs but not generating them
            celkins Level 1
            Thanks, Peter. I don't publish the project, I
            just generate it and then manually FTP the files
            to my Web site. I have deselected the "Republish
            all" setting in the WebHelp (Primary Layout)
            Generate options to upload only changed files,
            but that doesn't affect the time to generate. I
            didn't realize that RH8 includes PDF files in its
            search. That certainly is NOT something that I
            want in the particular applications that I use RH
            for (not traditional software Help). Is there any
            way to disable that, do you know?
            In the RH Help Viewer, it says this: "Search
            Office and PDF files (WebHelp/Pro, FlashHelp/Pro)
            You can search for baggage files (such as PDF,
            Word, and Excel files) in published output. To
            appear in search results, these baggage files
            must be referenced in a topic through a
            hyperlink. Note: You must have iFilter for
            Microsoft and PDF installed on to enable baggage file search."
            My primary layout is WebHelp, not WebHelp Pro. A
            quick Google indicated that this iFilter thing is
            the AcroIF.dll, and I'm pretty sure that if I
            uninstall it, it will hose my Acrobat
            application. How can I force RH to ignore baggage file search?
            Since I don't have a support account any longer
            on RH, do you know of any way I can pose these questions to a RH developer?
            Regarding your idea of applying a build tag to
            the PDF, I don't see how this is possible. When I
            select a PDF file in the Project Manager, the
            Format>Apply Conditional Build Tag options are
            greyed out. Do you how I could do this?
            Again, thanks for your time Peter. You have
            helped me so much with the resources you provide on your Web site.
            Carol
            • 3. Re: Linking to PDFs but not generating them
              I have deselected the "Republish all" setting in the WebHelp (Primary Layout) Generate options to upload only changed files, but that doesn't affect the time to generate.
              It will not. That setting is only relevant to publishing. RoboHelp always clears the generate folder and recreates it, as explained earlier.
              Is there any way to disable that, do you know?
              See Using RoboHelp 8 on my site.
              In the RH Help Viewer... ...Note: You must have iFilter for Microsoft and PDF installed on to enable baggage file search.
              That's the first time I have seen any reference to the need for iFilter. I will try to find out more but meantime work on the basis that the search is automatic and, in RoboHelp 8, cannot be stopped via the interface. However, as above you can stop the PDF search.
              Since I don't have a support account any longer on RH, do you know of any way I can pose these questions to a RH developer?
              You get what you pay for.
              Even with paid support, you do not get direct access to a developer.
              Regarding your idea of applying a build tag to the PDF
              It wasn't meant as a suggestion. What I was trying to get at was that a build tag was the only way I could see to stop the PDFs ending up in the output and I explained that had a downside.
              See what happens when you exclude PDFs from the search.
              @petergrainge
              • 4. Re: Linking to PDFs but not generating them
                Looking at the RoboHelp Search topic again, the iFilter information is for WebHelp Pro and FlashHelp Pro only.
                In WebHelp PDFs are searched automatically unless you follow the steps on my site.
                @petergrainge
                • 5. Re: Linking to PDFs but not generating them
                  celkins Level 1
                  Thanks again, Peter. I guess I will use a
                  combination of approaches. When I initially build
                  the project, I'll include the PDFs so that the
                  PDF files are copied to the Output file, thus
                  enabling links to them to remain valid. Then I'll
                  exclude PDFs from the search as instructed on
                  your Web site so that all subsequent builds are
                  completed quickly. I'll manually upload the
                  changed .htm files just as I've been doing.
                  Carol
                  • 6. Re: Linking to PDFs but not generating them
                    Exclude them from the search first time. It will not stop RoboHelp adding the files to the generate folder, it just stops them being searched which should save time.
                    Just uploading the HTM files is not the best policy as other files change. Better to publish and tick the box so that only changed files are published.
                    @petergrainge
