1. Re: flexunit breaks when using -load-config
vertex_shader Apr 29, 2011 6:48 PM (in response to vertex_shader)Update: This is for a Library project. It seems to work fine for a regular project.
2. Re: flexunit breaks when using -load-config
Michael Labriola Apr 29, 2011 6:58 PM (in response to vertex_shader)hi, sorry but i dont know that there is much we can do to help. this sound like a flash builder bug. these forums are for the open source flexunit project. the execute flexunit stuff inside builder was implemented by the flash builder team and is not part of the project nor maintained outside of adobe engineering. i would file a bug at bugs.adobe.com and post the bug number here. i can try to get some attention drawn to it, but we dont even have access to that source
mike
3. Re: flexunit breaks when using -load-config
vertex_shader Apr 29, 2011 7:17 PM (in response to Michael Labriola)As a workaround, could I create an ant task to run the tests for library projects?
4. Re: flexunit breaks when using -load-config
Michael Labriola Apr 29, 2011 7:20 PM (in response to vertex_shader)you can. the other thing you can do is make a separate regular project and add the tests in the library project as an additional source path to the project. that is what i generally do
