3 Replies Latest reply on May 2, 2011 8:44 AM by Jim_Lester
    e reader
    joanh123
      When trying to activate my ereader (cooler) with ADE I get E_ADEPT_BAD_ELEMENT_VALUE and also E_AUTH_BAD_DEVICE_KEY what does this mean
        • 1. Re: e reader
          Level 4
          I'm thinking that the combination of these two messages means you haven't
          activated your ereader and set its clock.
          Generally, errors that refer to ADEPT are related to a problem with your
          computer's clock.  You should check the date, time zone and time of your
          computer's clock, and make sure that it's correct.  If it is, then your
          ereader's settings aren't set yet.
          The second message relates to your ereader.  You didn't say what that
          ereader is, so I can't talk about specifics.  General process is to to to
          the site that is linked to you ereader and register it with that site (Nook
          to B&N, SONY to SONY, etc.).  Once you've done that, then ADE will be able
          to authenticate your ereader and work with it.
          There's also a chance that your ereader isn't supported by ADE.  If you go
          to ADE's Help page, you'll find a link to supported devices on the right
          hand side, at the bottom of the first group.  If your ereader isn't
          supported (iPad's aren't, for example), then you'll have to use another
          etext management software, not ADE.
          Hope this helps!
          • 2. Re: e reader
            joanh123 Level 1
            My ereader is cooler and ADE does support it
            • 3. Re: e reader
              Jim_Lester Level 4
              The device is reporting bad values to Adobe.  Try to reset the device to see if that helps.  If not, some people have reported luck deleting the .adobe-digital-editions folder on the device, and then resetting the device.
