10 Replies Latest reply on Apr 30, 2011 4:27 PM by Bill Gehrke
    i7-970 vs i7-950
    nantoskey
      I am slowly but sure getting close to my budget build selections..  I will mostly edit HD JVC HM700 & DSLR footage.
      Is it worth it for me to spend the extra bucks from i7-950 to i7-970?
      Processor
      Intel >
      Item#: N82E16819115066
      Intel Core i7-970   Gulftown 3.2GHz 6 x 256KB L2 Cache 12MB L3 Cache LGA 1366 130W Six-Core   Desktop Processor BX80613I7970
      595
      Processor
      Intel
      Item#: N82E16819115211
      Intel Core i7-950   Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core   Processor BX80601950
      270
      Thanks.
      --NAN
        • 1. Re: i7-970 vs i7-950
          JEShort01 Level 4
          NAN,
          Without knowing more, I'd lean towards saying the i7-970 is worth the extra outlay.
          To be more more certain of which would be best for your needs, please tell us:
          - what is your total system budget?
          - what components have you selected so far?
          - what are the specifics of your hard drive plans, including hardware controller details if you will use one?
          - will you be overclocking your CPU or sticking with stock settings?
          Jim
          • 2. Re: i7-970 vs i7-950
            Harm Millaard Level 7
            It depends on your workflow and your delivery format. If you usually deliver to MPEG2-DVD or web, I think the price difference is pretty steep, but if you usually deliver to H.264-BR format, there is a definite performance advantage from the hexa core and the larger L3 cache. If your workflow is edit and export, without the need to render for preview purposes, it makes less sense to invest in the 970, but if you have lots of multitrack and multicam work, often use previews to check your work, use DL to AE, then it may be worth to invest in the 970. I have no idea how tight your budget is with all the other components, but a fairly common approach is to get the fastest CPU one can afford and forget about the other components, especially disk setup, which ultimately can end up as the weakest link. Disk setup is often overlooked and to give you an example, just today I configured a server, using spare parts I had laying around and with a 7 disk setup (1 boot and 6 x 1 TB disk for storage) the cost is only € 650, but adding a good raid controller, BBU and cache, increased the cost to € 1,715. (All excluding VAT). The message actually is: Often it pays more to get a decent disk setup and forfeit a top-notch CPU to get a more balanced system. Raid controllers and disks do add up to the overall cost.
            • 3. Re: i7-970 vs i7-950
              nantoskey Level 1
              Thanks.
              Ideally, my budget is 3K ... with monitors, but I could go up to $3500.
              I want to deliver to H.264-BR format and hope to incorporate more DL AE.  Sounds like it may be worth it ...
              Processor
              Intel >
              595
              Processor
              Intel
              270
              Mobo
              ASUS >
              Item#: N82E16813131641
              ASUS P6X58D-E LGA   1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
              220
              CPU Cooler
              Noctua 6 Dual   Heatpipe
              Noctua 6 Dual   Heatpipe with 140mm/120mm Dual SSO Bearing Fans CPU Cooler NH-D14 - Retail
              Pasted   from <http://www.amazon.com/gp/product/B002VKVZ1A/ref=ox_sc_act_title_1?ie=UTF8&m=ATVPDKIKX0DER>
              85
              Thermal Paste
              Arctic 5 Silver
              Arctic Silver 5   Thermal Compound
              Pasted   from <http://www.amazon.com/Arctic-Silver-5-Thermal-Compound/dp/B0002EQU6C/ref=sr_1_4?s=electron ics&ie=UTF8&qid=1303761868&sr=1-4>
              5
              Power Supply
              Corsair >
              Item#: N82E16817139009
              CORSAIR Enthusiast   Series CMPSU-850TX 850W ATX12V v2.2 / EPS12V v2.91 SLI Certified CrossFire   Ready 80 PLUS Certified Active PFC Power Supply
              140
              C:
              OS Drive
              Western   Digital >
              Item#: N82E16822136322
              Western Digital   VelociRaptor WD3000HLFS 300GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5"   Internal Hard Drive -Bare Drive
              150
              D: [RAID5]
              Media, Projects,   Media Cache, Exports
              Western   Digital >
              Item#: N82E16822136798
              Western Digital   RE4 WD1003FBYX 1TB 7200 RPM 64MB Cache SATA 3.0Gb/s 3.5" Internal   Enterprise Hard Drive -Bare Drive
              360
              3x120
              RAID Hot Spare
              Western   Digital >
              Item#: N82E16822136697
              Western Digital   RE4 WD5003ABYX 500GB 7200 RPM 64MB Cache SATA 3.0Gb/s 3.5" Internal Hard   Drive -Bare Drive
              80
              RAM
              Corsair
              Item#: N82E16820145350
              CORSAIR   Vengeance 24GB (6 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
              320
              Video Card
              EVGA GeForce GTX   570
              EVGA GeForce GTX   570 Superclocked 1280 MB GDDR5 PCI-Express 2.0 Graphics Card with Lifetime   Warranty 012-P3-1572-AR
              Pasted   from <http://www.amazon.com/EVGA-Superclocked-PCI-Express-Graphics-012-P3-1572-AR/dp/B004EYSMGW/ ref=sr_1_1?s=electronics&ie=UTF8&qid=1303761406&sr=1-1>
              $20 REBATE
              350
              RAID Controller
              3ware
              Item#: N82E16816116109
              3ware Internal   9750-4i SATA/SAS 6Gb/s PCI-Express 2.0 w/ 512MB onboard memory Controller   Card, Single
              329
              RAID cable
              3ware >
              Item#: N82E16816116097
              3ware   CBL-SFF8087OCF-05M 1 unit of 0.5m Multi-lane Internal (SFF-8087) Serial ATA   breakout cable
              20
              OS
              Microsoft
              Item#: N82E16832116992
              Microsoft Windows   7 Professional SP1 64-bit 1-Pack - OEM
              140
              Case
              Antec >
              Item#: N82E16811129100
              Antec Twelve   Hundred V3 Black Steel ATX Full Tower Computer Case
              159
              15 shipping
              Keyboard
              Logitech K350
              Logitech K350   Black USB 2.4 GHz Wireless Ergonomic Keyboard
              50
              Mouse
              Logitech M505
              Logitech M505   Silver 3 Buttons Tilt Wheel Wireless Laser Mouse
              37
              DVD/BD
              Pioneer >
              Item#: N82E16827129066
              Pioneer Black 12X   BD-R 2X BD-RE 16X DVD+R 8X BD-ROM 4MB Cache SATA Internal Blu-ray Burner   Blu-ray Burner BDR-206DBKS
              114
              i7-950 build
              2844
              i7-970 build
              3169
              Monitors
              Samsung F2380
              2
              400
              2x200
              • 4. Re: i7-970 vs i7-950
                Nan,
                Given the list you gave and the budget you indicated, I would suggest adding another RE4 drive to that raid5. It will make your disk setup significantly faster and give you more storage space. But that will also restrict you from further expansion. 3Ware is not the fastest controller and 4-ports can be limiting. OTOH, going for an 8 port or more controller, will bring you out of budget range.
                For the rest, your list looks very good. I would opt for the 970 in relation to your delivery format.
                • 5. Re: i7-970 vs i7-950
                  JEShort01 Level 4
                  NAN,
                  Like Harm just said, the disk setup is often overlooked, and yours having a 3 drive RAID does seem underpowered compared with the rest of your system.
                  For your budget I'd suggest the i7-950 (or SB 2600k actually, another 32nm solution like the i7-970), and build up your RAID array to at least 5 drives.
                  If your price point is really firm, many users here are going with multiple 2x1TB Raid 0 arrays off their motherboard and then handling redundancy with an external backup solution (set up following Harm's drive configuration tips).
                  Regards,
                  Jim
                  • 6. Re: i7-970 vs i7-950
                    Bill Gehrke Most Valuable Participant
                    My opinion is go for the best CPU first and consider the lowest priority item on the list the 3Ware mediocre RAID controller as a last resort.  Do consider the dual motherboard RAID 0 as a starting point as suggested but be sure to at least have another large disk drive for archiving
                    • 7. Re: i7-970 vs i7-950
                      nantoskey Level 1
                      I can't get invest in high buck RAID controller now ... but would really like some redundancy.
                      For about $150 more I could get the Intel RS2BL080SNGL as I've seen noted on other posts as an OK budget card.  It has 8 ports.  But transfer rate is 600 MBps Per Port as opposed to 3ware Up to 6Gb/s ... am I missing something?
                      I know people have not raved about this card ... but a fellow forum mate has had good luck with it.  Though I need to confirm if he's doing RAID5.
                      I think 4 port/ 4Tb for storage would work for me for awhile.
                      3ware Internal 9750-4i SATA/SAS 6Gb/s PCI-Express 2.0 w/ 512MB onboard memory Controller Card, Single - $329
                      Specifications
                      Type
                      SATA / SAS (Serial Attached SCSI)
                      Internal Connectors
                      1 x SFF-8087 mini-SAS
                      Interface
                      PCI-Express 2.0
                      Transfer Rate
                      Up to 6Gb/s
                      Cache Memory
                      512MB DDRII cache (800MHz)
                      RAID
                      RAID 0, 1, 5, 6, 10, 50 and Single Disk
                      Operating Systems Supported
                      Extensive support includes Microsoft Windows Vista, Windows 7,  Windows Server 2003/2008, Red Hat Linux, SuSE Linux, Fedora Core Linux,  FreeBSD, and more.
                      Intel RS2BL080SNGL PCI-Express 2.0 Low Profile SAS 8-port SAS RAID Controller - $569
                      Transfer Rate:
                      600 MBps Per Port
                      RAID:
                      RAID 0/1/5/6/10/50/60
                      Cache Memory:
                      512 MB ECC DDR2 SDRAM
                      Features:
                      Host Interface: PCI Express 2.0 x8  Interfaces:  Serial ATA/600 Serial Attached SCSI  Drive Support: 32 x Physical  Platform Support: PC / SPARC  Ports: 2 x 36-pin SFF-8087 SAS 300 - Mini-SAS Internal  Form Factor: Low-profile Plug-i
                      • 8. Re: i7-970 vs i7-950
                        JEShort01 Level 4
                        NAN,
                        OK then, how about taking the 3ware RAID up to 4 drives and addiding another 2 7200 rpm drives in RAID 0 that CS5 could use for cache, scratch, etc. but would not be used for media, projects, etc. where you would need the redundancy?
                        Jim
                        • 9. Re: i7-970 vs i7-950
                          nantoskey Level 1
                          Sure , that makes good sense.
                          Thanks.
                          -NAN
                          Nan Toskey
                          651.206.4659
                          www.MEDIAtoRemember.com
                          • 10. Re: i7-970 vs i7-950
                            Looking at the specs that you provided are hard to explaining 600 MB/s (there are no disk drives that are rated at 600 MB/s or 4.8 Gb/s) except that maybe a non-technical person wrote the Intel spec.  If you look at this Intel literature you will see that the SAS Interface transfer rate is 6 Gb/s, but unless there have been changes not appearing in the Intel literature the SATA transfer rate is listed as 3 Gb/s.  Incidently this product is manufacturer by LSI as the MegaRAID SAS 9260-8i which does not specify a seperate SAS and SATA transfer rate it just specifies a Port transfer rate of 6 Gb/s.  Confused?  So am I.  Maybe Eric at ADK can explain.
