2 Replies Latest reply: May 1, 2011 4:44 PM by Mindbreak.net RSS
    Selecting / Deleting Multiple Tracks
    Mindbreak.net Community Member
      Hello, just wondering if someone can help with what should be an extraordinarily simple task.  I can not find the answer to this in the forums or even the Help menu within the program.
      How on earth do you select multiple tracks so you can delete them all at once?
      For example, I have a project with 3 video tracks and 5 audio tracks in it.  I put an in point and and an out point in my sequence somewhere in the middle so I can cut out maybe a second or two of one of the clips.  I select one Video track and one Audio track, then Cut, but it only takes out those two tracks.  then I have to put in a new in and out point and select the Video 2 track and Audio 2 track, so I can delete those, and so on.
      The MUST be a way to select Video 1, 2, 3 tracks and Audio 1-5 tracks all at the same time, so when I hit cut (Ripple Delete is usually grayed out and I can't select it), it takes that in/out point out from all the tracks at exactly the same time and shifts over everything after it over to the clips on the left.
      Did I over-explain?  It's actually a really simple question...
      Thanks a lot!!!
      Greg
