3 Replies Latest reply on Aug 14, 2006 7:03 PM by Malcolm Edgar
    RemoteObject 404 error
    Malcolm Edgar Level 1
      Hi All,
      I am trying to get the mx:RemoteObject functionality to work, and I am getting the following error on the client:
      [RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 404"]
      at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::faultHandler()
      at mx.rpc::Responder/fault()
      at mx.rpc::AsyncRequest/fault()
      at mx.messaging::ChannelSet/::faultPendingSends()
      at mx.messaging::ChannelSet/channelFaultHandler()
      at flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at mx.messaging::Channel/mx.messaging:Channel::connectFailed()
      at mx.messaging.channels::PollingChannel/mx.messaging.channels:PollingChannel::connectFailed ()
      at mx.messaging.channels::AMFChannel/mx.messaging.channels:AMFChannel::statusHandler()
      On the sever log all I am getting is:
      14/08 15:02:45 error Requested resource '/messagebroker/amf' (%2fmessagebroker%2famf) not found
      The full error log is:
      D:\fds2\jrun4\bin>jrun start default
      Starting Macromedia JRun 4.0 (Build 106363), default server
      Flex OEM License for JRun enabled
      14/08 15:11:49 warning Unable to open D:\fds2\jrun4/lib/license.properties
      14/08 15:11:50 info JRun Naming Service listening on *:2907
      14/08 15:11:50 info No JDBC data sources have been configured for this server (see jrun-resources.xml)
      14/08 15:11:50 info JRun Web Server listening on *:8700
      14/08 15:11:50 info Deploying web application "Flex Default Web Application" from: file:/D:/fds2/jrun4/servers/default/d
      efault-war/
      14/08 15:11:50 user JSPServlet: init
      14/08 15:11:50 info Deploying web application "Flex Data Services" from: file:/D:/fds2/jrun4/servers/default/flex/
      14/08 15:11:51 user FlexMxmlServlet: init
      14/08 15:11:51 INFO Loading configuration file D:\fds2\jrun4\servers\default\flex\WEB-INF\flex\flex-webtier-config.xml
      14/08 15:11:51 INFO Loading configuration file D:\fds2\jrun4\servers\default\flex\WEB-INF\flex\flex-config.xml
      14/08 15:11:52 user FlexMxmlServlet: Starting Adobe Flex Web Tier Compiler
      14/08 15:11:52 user FlexMxmlServlet: Adobe Flex Web Tier Compiler Build: 143451
      14/08 15:11:52 user MessageBrokerServlet: init
      [Flex] [INFO] [Configuration] Starting Adobe Flex Data Services 2 Express
      [Flex] [INFO] [Configuration] Adobe Flex Data Services Build: 143451
      [Flex] [INFO] [Configuration] Endpoint my-amf created with security: None
      at URI: http://{server.name}:{server.port}/{context.root}/messagebroker/amf
      [Flex] [INFO] [Configuration] Endpoint my-polling-amf created with security: None
      at URI: http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling
      [Flex] [INFO] [Configuration] Endpoint my-http created with security: None
      at URI: http://{server.name}:{server.port}/{context.root}/messagebroker/http
      [Flex] [INFO] [Configuration] Endpoint my-secure-amf created with security: None
      at URI: https://{server.name}:9100/{context.root}/messagebroker/amfsecure
      [Flex] [INFO] [Configuration] Endpoint my-rtmp created with security: None
      at URI: rtmp://{server.name}:2038
      [Flex] [INFO] [Configuration] Endpoint my-secure-http created with security: None
      at URI: https://{server.name}:9100/{context.root}/messagebroker/httpsecure
      14/08 15:11:52 user FlexSwfServlet: init
      [Flex] [INFO] [Endpoint.RTMP] RTMP-Server listening on port:2038
      14/08 15:11:52 user FlexInternalServlet: init
      14/08 15:11:52 info Deploying web application "Flex Admin Web Application" from: file:/D:/fds2/jrun4/servers/default/fle
      x-admin/
      14/08 15:11:52 user JSPServlet: init
      14/08 15:11:53 info Deploying web application "Flex Data Services Samples" from: file:/D:/fds2/jrun4/servers/default/sam
      ples/
      14/08 15:11:53 user JSPServlet: init
      14/08 15:11:53 user FlexMxmlServlet: init
      14/08 15:11:53 INFO Loading configuration file D:\fds2\jrun4\servers\default\samples\WEB-INF\flex\flex-webtier-config.xm
      l
      14/08 15:11:53 INFO Loading configuration file D:\fds2\jrun4\servers\default\samples\WEB-INF\flex\flex-config.xml
      14/08 15:11:53 user FlexMxmlServlet: Starting Adobe Flex Web Tier Compiler
      14/08 15:11:53 user FlexMxmlServlet: Adobe Flex Web Tier Compiler Build: 143451
      14/08 15:11:53 user MessageBrokerServlet: init
      14/08 15:11:54 user FlexSwfServlet: init
      14/08 15:11:54 user FlexInternalServlet: init
      14/08 15:11:54 info Deploying enterprise application "JRun 4.0 Internal J2EE Components" from: file:/D:/fds2/jrun4/lib/j
      run-comp.ear
      14/08 15:11:54 info Deploying EJB "JRunSQLInvoker" from: file:/D:/fds2/jrun4/lib/jrun-comp.ear
      Server default ready (startup time: 6 seconds)
      14/08 15:12:29 user FileServlet: init
      14/08 15:12:29 error Requested resource '/messagebroker/amf' (%2fmessagebroker%2famf) not found
      The example code is trivial and uses the sample services:
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml"
      layout="absolute"
      creationComplete="myService.getSandwitchList();">
      <mx:RemoteObject
      id="myService"
      destination="simpleService"/>
      <mx:DataGrid x="319" y="403"
      dataProvider="{myService.getSandwichList.lastResult}">
      </mx:DataGrid>
      </mx:Application>
        • 1. Re: RemoteObject 404 error
          FlexNubi
          Have you setup the destination object in the flex config files? You specify a remote object and tell it a destination, but without specifying the destination of simpleService in the Flex config, Flex does not know where to go for it. Thats my understanding of it anyway.
          • 2. Re: RemoteObject 404 error
            aBill
            Hi
            By looking at your serverlog and error message, server didn't know the url. I think you know the problem too, since you particularly pointed out that in your server log
            However, I can see the server reporting the available channel in default web app
            Not sure your default web's context root is '/' , or did you change it? Also please check your servlet mapping in your web.xml is
            /messagebroker/*
            Thanks!
            William
            • 3. Re: RemoteObject 404 error
              Hi All,
              thanks for the replies.
              I have found a solution moving by Flex Data Services project to compile on the server, somehow I must have configured the project incorrectly.
              regards Malcolm Edgar
