3 Replies Latest reply on May 3, 2011 3:35 AM by AspiringDIV
    low quality video.....
    betohlbeto
      Hello my friends....
      I have intel(r) core(tm) i7 cpu 950@3.07 ghz 3.19 Ghz
      memory ram  12 Gb
      64 bit
      windows 7
      premiere pro cs5.....
      I doing my recordings on canon XH A1   hd     60 fps
      but when i doing the transfer to my computer the image look very poor, grainy, with lots of noise....
      how i can transfer with not loose quality or what I can use...
      thanks....
        • 1. Re: low quality video.....
          Jim_Simon Level 8
          The capture process is a bit for bit identical copy of the original on tape.  So, this issue can be explained by one of two things.  Either the problem is in the footage, or observer error.
          • 2. Re: low quality video.....
            betohlbeto Level 1
            the image on my camera look excellent,
            full of ligths and color....
            when I do play you can see nice quality image on....
            but who is observer error mean.?
            • 3. Re: low quality video.....
              AspiringDIV Level 1
              Limited knowledge here but maybe I can help...
              Use Premiere's in-built capture functionality via Firewire cable - at least that's what I do and the footage looks perfect.
              If the footage is grainy, it might be because you are filming with low light on auto (for example), where grain will often occur. Try looking at some footage which is shot in good light, outdoors, for example - and it should look of good quality even if you are using auto settings.
              In terms of improving your low light footage, try shooting with one of the common XHA1s presets which are widely available, as a starting point.
              Hope that helps
