2 Replies Latest reply on May 4, 2011 8:22 AM by Scaljeri
    reuse a MXML component
    Scaljeri Level 1
      Hi All
      I have setup (not complete yet) a mxml component (see code below), which I want to implementhe multiple times in s:Application.
      Within the s:Script tag (currently empty) I want to reference the VideoDisplay, Buttons, etc. To do this I use the ID, but the problem is that I need to implement this component multiple times ? An other problem is that each instance should have a different video url. Any suggestions ?
      Cheers
      <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx">
      <s:layout>
      <s:BasicLayout/>
      </s:layout>
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      </fx:Script>
      <mx:DateFormatter id="dateFormatter" formatString="NN:SS" />
      <mx:Panel title="{videoDisplay.source.split('/').pop()} ({videoDisplay.state})">
      <mx:VideoDisplay id="videoDisplay" visible="false" width="400" height="100"
      playheadUpdate="videoDisplay_playheadUpdate('')"
      ready="videoDisplay_ready('')"
      rewind="videoDisplay.play()"
      source="./Android_Demo.flv" />
      <mx:ControlBar id="controlBar" visible="false">
      <mx:Button id="play" name="play" label="Play" click="videoDisplay.play()"></mx:Button>
      <mx:Button id="pause" name="pause" label="Pause" click="videoDisplay.pause()"></mx:Button>
      <mx:HSlider id="slider" width="100%"
      allowTrackClick="false"
      invertThumbDirection="true"
      liveDragging="false"
      maximum="{videoDisplay.totalTime}"
      minimum="0"
      thumbPress="slider_thumbPress('')"
      thumbRelease="slider_thumbRelease('')"
      tickInterval="1"
      value="{videoDisplay.playheadTime}" />
      <mx:Label id="timeLabel" textAlign="right" />
      </mx:ControlBar>
      </mx:Panel>
      </s:Group>
        • 1. Re: reuse a MXML component
          David_F57 Level 5
          You just create bindable vars(public) in the component, then you can reference them as a component property, this property can be any type string,int, array etc....
          David
          simple app using the same component twice
             xmlns:components="components.*"
             minWidth="955" minHeight="600">
          <fx:Declarations>
          </fx:Declarations>
          <components:MyComponent x="45" y="161" caption="Hello World" icon="img1.jpg" description="picture 1">
          </components:MyComponent>
          <components:MyComponent x="479" y="161" caption="Another Component" icon="img2.jpg" description="picture 2">
          </s:Application>
          the simple component -
          xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="300">
          <fx:Declarations>
          </fx:Declarations>
          <fx:Script>
          <![CDATA[
          [Bindable] public var caption:String;
          [Bindable] public var icon:String;
          [Bindable] public var description:String;
          </fx:Script>
          <s:Panel left="0" right="0" top="0" bottom="0" title="{caption}">
          <s:VGroup verticalCenter="0" horizontalCenter="0">
          <s:Image width="140" height="140" horizontalCenter="0" source="{icon}"/>
          <s:Label text="{description}" width="100%" textAlign="center"/>
          </s:VGroup>
          </s:Panel>
          </s:Group>
          • 2. Re: reuse a MXML component
            Scaljeri Level 1
            thanks a lot!!
            cheers
