3 Replies Latest reply on May 4, 2011 8:07 PM by Rick Gerard
    help loop timeline
    waspnator
      Good morning everyone,
      Can someone help, i am newbie in after effects and got the following question:
      I have two compositions on the timeline:
      The first start at 0 and  end in 7 seconds.
      The second
      start at 0 and  end in 7 seconds too.
      The question is how do I make a loop? I want the loop start in 3 seconds, but he always start at 0 seconds
      Since you already appreciate the help.
        • 1. Re: help loop timeline
          I'm not sure I completely understand what you're trying to do. You can make a composition loop by dropping the comp in a new composition (or pre-Composing everything) then extending the length of the new composition and applying Layer>Time>Time Remapping.
          This will put two keyframes in your composition. You then can loop the keyframes by using the standard loop out expression. It looks like this:
          loopOut(type = "cycle", numKeyframes = 0)
          Then by adjusting the spacing of the keyframes you can speed up or shorten the video. You can also extend the length of the composition.
          • 2. Re: help loop timeline
            waspnator Level 1
            thanks Rick for reply
            And sorry my english is bad.
            I'll try to explain.
            I have comp1 in the timeline, it start in 0(zero) seconds and finish in 7 seconds, i have comp2 that start in 3 seconds and finish in 7 seconds.
            I want that comp1 pause or stop when the timeline is in 3 seconds
            with the comp2  when the time reach 7 seconds, It enter in loop go back to 3 seconds, while comp1 keep stoped
            • 3. Re: help loop timeline
              Time Remapping is your friend here. First enable Time Remapping on both comps. Now add a keyframe on Comp 1 at 3 seconds and delete the keyframe at 7 seconds. This will freeze Comp 1 at 3 seconds.
              Comp 2 should start at 3 seconds With Time Remapping enabled you'll see a keyframe at 3 seconds (the Comp 2 in point) and another keyframe at the out point. These keyframes represent the starting and ending time of Comp 2.
              Alt or Option + click on the Time Remapping stopwatch in the timeline and add this expression:
              Then extend the out point of Comp 2.
              That should do it. Comp 2 will loop for the entire length of the main composition.
