2 Replies Latest reply on May 3, 2011 10:59 PM by S k R Pasha
    change resolution based on dpi in flex
    S k R Pasha Level 1
      Hi All ,
          In my Flex Application , i am getting image for chart / process from java. Its working fine.
      Now my new requirement is :
      1) For the first time when getting image the default dpi should be  : 72dpi
      2) And i should have 2 more options to select 90dpi and 150dpi in flex
         and when selecting these dpis , my chart/process resolution should change based on selected dpi in Flex.
      Please helpp.....
        • 1. Re: change resolution based on dpi in flex
          matthew horn Level 3
          SkR Pasha,
          If I understand what you mean, there are two approaches you can take:
          1) The easiest way is to just define 3 paths to images, each one being a different resolution:
          var img1:String = lowResImage.gif;
          var img2:String = medResImage.gif;
          var img3:String = highResImage.gif;
          Then load the one that is appropriate when the DPI changes.
          2) Flex 4.5 includes support for multiple DPIs. First you get the current DPI:
          FlexGlobals.topLevelApplication.applicationDP
          Then you use the MultiDPIBitmapSource class to specify which image to use based on the DPI.
          Here's an example that you can apply to a standard application (you don't need to write a mobile app to do it):
          http://help.adobe.com/en_US/flex/mobileapps/WS19f279b149e7481c682e5a9412cf5976c17-8000.htm l
          hth,
          matt horn
          flex docs
          • 2. Re: change resolution based on dpi in flex
            S k R Pasha Level 1
            Thanks ,
            But i am using Flex 3...
            Here is my code :
            var img:Image;
            img.source=processUrlString+"&width="+imagewidth+"&height="+imageheight;
            Here  processUrlString = "/dashboard/servlet/processmap.do" ( ie i am calling java url ..which creates chart and  reurns byte[]s to flex. And i am adding this image to Panel in Flex.
            Here .. i want to set Image DPI like 75dpi or 90dpi etc.... by selecting the dpi from Combobox[Drop down B ox]
            thanks in advance...
