3 Replies Latest reply on Jul 2, 2009 12:05 AM by moutfeh5
    click event on tree icon
    bsr328
      I am trying to create a click event for just the icons of a tree (ideally, only the leaf icons, but I can deal with that logic in the event handler if need be).
      Here is my code for the custom renderer:
      package renderers{
      import mx.collections.*;
      import mx.controls.treeClasses.*;
      import mx.controls.Alert;
      import mx.core.IFlexDisplayObject;
      import mx.controls.Image;
      public class ItemViewTreeItemRenderer extends TreeItemRenderer {
      import com.ItemViewBase;
      import flash.events.MouseEvent;
      public function ItemViewTreeItemRenderer() {
      super();
      override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void {
      super.updateDisplayList(unscaledWidth, unscaledHeight);
      if(super.data) {
      super.icon.addEventListener(MouseEvent.CLICK, clickEvt);
      private function clickEvt(event:MouseEvent = null):void{
      Alert.show("CLICKED", "IntraVIEWER", Alert.OK, null, null, null, Alert.OK);
      Eventually, I want to call a function outside of the renderer, but for now, I can't even successfully call the clickEvt function.
      Any ideas??? Thanks!!
        • 1. click event on tree icon
          bsr328 Level 1
          I found that this change will add the event listener only for the leaves of a tree:
          if(super.data && ! super.icon.hasEventListener(MouseEvent.CLICK)) {
          if(!TreeListData(super.listData).hasChildren){
          But the event is still not being fired when I click the icon...
          • 2. Re: click event on tree icon
            moutfeh5
            I have the same problem, i need to add an event to the icon(mouse click), i have customize all the icon in the tree through setItemIcon. Is there any problem if i customized the icon
            If u solve it please tell me how
            Thank you
            • 3. Re: click event on tree icon
              moutfeh5 Level 1
              Hi
              I found the solution
              i set mouseEnabled = true; in the construction of the inherited treeItemRenderer.
              I was using the example in the Flex CookBook, In this example at the constructor level, mouseEnabled was set to false
              AND in the createChildren method i add MouseEvent.Click
              It is written below
              override
              protected function createChildren():
              void
              super.createChildren();
              super.addEventListener( MouseEvent.CLICK, imageToggleHandler);
              Gd Luck
