My computer crashed recently. I used to use Adobe 9 to print out faxes I receive. That was not available anymore so I am now using Reader X. My system is an XP. When I try to print faxes (pdf files) and my printing options come up the box is blank. I basically guess which button to push to print. It prints just fine. My problem is that occasionally I need to print just one page of say a 30 page fax. I'm not able to make that selection because the box is blank.
Thanks for any help.
libby
Probably has something to do with your crash. Something is munged. If you set a point so you can restore your computer to before the crash you might be ok. If not I'd recommend you find a decent registry fixer and remove all traces of Reader 9 or 10 and then re-install 10. You might be out of luck though and need to re-install your OS if that doesn't work.
Of course if you have a good backup, you can erase your drive and restore your backup.
We have already reinstalled our OS.
