0 Replies Latest reply on May 3, 2011 2:18 PM by bmberkowitz2010
    Text sprite color error?
    bmberkowitz2010 Level 1
      Hi, I'm having a problem with the .bgcolor and .color properties for a text sprite.
      Basically I have 4 text sprites (all of different members, but nothing I can see that is different) using the same behaviors.  I have a behavior that modifies the .bgcolor and .color properties for each one.
      The problem is, when I try to modify the sprites using the bgcolor and color properties within the behaviors, 3 of the sprites change correctly; however, the 4th sprite begins using color indeces instead of the rgb values and seems to have the color and bgcolor switched so that the color changes when the bgcolor is supposed to change and vice-versa.
      Since the 4 sprites are all using the same behaviors, I have no idea why this is happening.  Does anyone know of anything that would cause this?
