4 Replies Latest reply on May 4, 2011 10:02 AM by ssardar
    AdvancedDataGrid selectedItem is null
    checker2505
      My source is below. When I am click on a cell in AdvancedDataGrid and try to look to the cell value using the selctedItem attribute, the value of the selectedItem is null in the first line of the showPopUp(evt:Event) method.
      I am new to AdvancedDataGrid and not sure why that attribute is null. Any help is very much appreciated...
      Source Code:
      <mx:VBox
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="
      library://ns.adobe.com/flex/spark"
      xmlns:mx="
      library://ns.adobe.com/flex/mx"
      minHeight="
      0"
      minWidth="
      0"
      width="
      100%"
      height="
      100%"
      color="
      black">
      <fx:Script>
      <![CDATA[
      protected function Maximize_clickHandler(event:MouseEvent):void
      if (maxRestoreButton.label == "Maximize") {
      "Restore";
      this.parent.removeChild(this);
      else {
      "Maximize";
      protected function advanceddatagridcolumn1_activateHandler(event:Event):void
      // TODO Auto-generated method stub
      </fx:Script>
      <fx:Script>
      <![CDATA[
      import mx.containers.Canvas;
      import mx.core.DragSource;
      import mx.core.UIComponent;
      import mx.events.*;
      import mx.managers.DragManager;
      // Initializes the drag and drop operation.
      private function mouseMoveHandler(event:MouseEvent):void {
      // Create a DragSource object.
      var ds:DragSource = new DragSource();
      // Add the data to the object.
      ds.addData(
      this, 'dragInitiator');
      // Call the DragManager doDrag() method to start the drag.
      DragManager.doDrag(
      this, ds, event);
      // Called when the user moves the drag indicator onto the drop target.
      private function dragEnterHandler(event:DragEvent):void {
      // Accept the drag only if the user is dragging data
      // identified by the 'color' format value.
      if (event.dragSource.hasFormat('dragInitiator')) {
      // Get the drop target component from the event object.
      var dropTarget:VBox=VBox(event.currentTarget);
      // Accept the drop.
      DragManager.acceptDragDrop(dropTarget);
      // Called if the target accepts the dragged object and the user
      // releases the mouse button while over the Canvas container.
      private function dragDropHandler(event:DragEvent):void {
      // Get the data identified by the color format
      // from the drag source.
      var dragInitiator:Object = event.dragSource.dataForFormat('dragInitiator');
      var x:int = this.parent.getChildIndex(DisplayObject(dragInitiator));
      var child2:DisplayObject = this.parent.getChildByName("itemsettings");
      var x2:int = this.parent.getChildIndex(child2);
      parent.addChildAt(child2, x);
      parent.addChildAt(DisplayObject(dragInitiator), x2);
      </fx:Script>
      <fx:Declarations>
      <s:ArrayCollection id="arr"/>
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import spark.components.supportClasses.ItemRenderer;
      import flash.sampler.getInvocationCount;
      import mx.containers.Panel;
      import mx.controls.dataGridClasses.DataGridItemRenderer;
      import mx.skins.ProgrammaticSkin;
      import mx.collections.ArrayCollection;
      import mx.collections.Grouping;
      import mx.collections.GroupingCollection2;
      import mx.collections.GroupingField;
      import mx.events.DataGridEvent;
      import mx.events.ListEvent;
      import mx.events.MenuEvent;
      import mx.managers.PopUpManager;
      Bindable]
      public var dpHierarchy:ArrayCollection = new ArrayCollection([
      {DATALEVEL:
      "Austin DC", children: [
      {DATALEVEL:
      "123451-00", PROD_DESCP:"Prod Desc 1", BDC:"001002003", BDC_SUBGRP:"1", PROD_STAT:"P - Plan", UOM:"CASE", EACHES_PER_UOM:"24",
      MIN_INC_FLG:
      "Auto", TAG:"Tag 1", DLY_ALLOC:"?", FCST_PCT: "?", SKU_MFG_SUBCLS:"06", OVRD_PROD_FLG:"No", ON_OFF_LINE:"Off", PROD_LEAD_TM:"No Components",
      NON_PROD_LEAD_TM:
      "No Components", RECIPE_EXISTS_FLG:"Yes", children: [
      {DATALEVEL:
      "Arlington Plant", EFF_DT:"04-25-2011", END_DT:"12-25-2025", ORD:"SMTWTFS", RECV_WKS:"1234", LOAD_OFFSET:"24", TIME_FENCE:"10", TRANS_LEAD_TM:"1"},
      {DATALEVEL:
      "DBS MFG Plant", EFF_DT:"04-25-2011", END_DT:"12-25-2025", ORD:"SMTWTFS", RECV_WKS:"1234", LOAD_OFFSET:"24", TIME_FENCE:"10", TRANS_LEAD_TM:"1"},
      {DATALEVEL:
      "123452-00", PROD_DESCP:"Prod Desc 2", BDC:"001002003", BDC_SUBGRP:"1", PROD_STAT:"P - Plan", UOM:"CASE", EACHES_PER_UOM:"24",
      MIN_INC_FLG:
      "Auto", TAG:"Tag 2", DLY_ALLOC:"?", FCST_PCT: "?", SKU_MFG_SUBCLS:"06", OVRD_PROD_FLG:"No", ON_OFF_LINE:"Off", PROD_LEAD_TM:"No Components",
      NON_PROD_LEAD_TM:
      "No Components", RECIPE_EXISTS_FLG:"No", children: [
      {DATALEVEL:
      {DATALEVEL:
      {DATALEVEL:
      "Irving Plant", children: [
      {DATALEVEL:
      MIN_INC_FLG:
      NON_PROD_LEAD_TM:
      {DATALEVEL:
      {DATALEVEL:
      {DATALEVEL:
      MIN_INC_FLG:
      NON_PROD_LEAD_TM:
      {DATALEVEL:
      {DATALEVEL:
      private function init():void {
      var lh:MenuLeafHandler = new MenuLeafHandler();
      var t:Traversal = new Traversal(lh);
      t.traverseAndGetHandler(grid.groupedColumns);
      arr = lh.getArray();
      private function menu_change(evt:MenuEvent):void {
      var lh:HideShowHandler = new HideShowHandler(evt.item.label);
      lh.getLeaf().visible = popupmenubutton1.dataDescriptor.isToggled(evt.item);
      public function editCell(evt:Event):void {
      var selCells:Array = grid.selectedCells;
      var s:String = evt.toString();
      private function showPopUp(evt:Event):void {
      var strvar:String = evt.target.selectedItem.toString();
      if (evt.currentTarget.selectedCells[0].columnIndex == 7) {
      var minIncCalcFlagPopUp:MinIncCalcFlagPopUp = new MinIncCalcFlagPopUp();
      PopUpManager.addPopUp(minIncCalcFlagPopUp,
      this,true);
      PopUpManager.centerPopUp(minIncCalcFlagPopUp)
      else if (evt.currentTarget.selectedCells[0].columnIndex == 8) {
      var tagPopUp:TagPopUp = new TagPopUp();
      tagPopUp.init();
      var tagPanel:Panel = tagPopUp.panel;
      PopUpManager.addPopUp(tagPanel,
      this,true);
      PopUpManager.centerPopUp(tagPanel);
      else if (evt.currentTarget.selectedCells[0].columnIndex == 9) {
      var dlyAllocPopUp:DlyAllocPopUp = new DlyAllocPopUp();
      PopUpManager.addPopUp(dlyAllocPopUp,
      this,true);
      else if (evt.currentTarget.selectedCells[0].columnIndex == 10) {
      var fcstPopUp:FcstPctPopUp = new FcstPctPopUp();
      PopUpManager.addPopUp(fcstPopUp,
      this,true);
      PopUpManager.centerPopUp(fcstPopUp);
      else if (evt.currentTarget.selectedCells[0].columnIndex == 19) {
      var ovrdeRecvDaysPopUp:OvrdeRecvDaysPopUp = new OvrdeRecvDaysPopUp();
      PopUpManager.addPopUp(ovrdeRecvDaysPopUp,
      this,true);
      PopUpManager.centerPopUp(ovrdeRecvDaysPopUp)
      </fx:Script>
      <s:VGroup height="100%" width="100%" gap="10" paddingLeft="10" paddingRight="10" paddingTop="10" paddingBottom="10" >
      <s:Label mouseMove="mouseMoveHandler(event);" text="Item Settings" fontWeight="bold" textAlign="center" color="#04498F" fontSize="18" fontStyle="normal" horizontalCenter="22" alpha="1.0"/>
      <s:HGroup width="100%">
      <mx:PopUpMenuButton id="popupmenubutton1" x="10" y="10" label="Hide/Show Columns" dataProvider="{arr}" itemClick="menu_change(event)"/>
      <mx:Spacer width="100%" />
      <s:Button label="Run Item Settings Analyzer" color="0x000000" />
      <s:Button label="Save..." color="0x000000" />
      <s:Button label="Export..." color="0x000000" />
      <s:Button id="maxRestoreButton" label="Maximize" click="Maximize_clickHandler(event)" color="0x000000" />
      </s:HGroup>
      <mx:AdvancedDataGrid id="grid"
      width="
      100%" height="100%"
      rowHeight="
      20"
      paddingBottom="
      0"
      paddingTop="
      0"
      wordWrap="
      false"
      editable="
      true"
      enabled="
      true"
      displayItemsExpanded="
      true"
      allowMultipleSelection="
      true"
      allowDragSelection="
      true"
      selectionMode="
      multipleCells"
      headerSortSeparatorSkin="
      mx.skins.ProgrammaticSkin"
      verticalScrollPolicy="
      on"
      horizontalScrollPolicy="
      on"
      itemClick="showPopUp(event)"
      <mx:dataProvider>
      <mx:HierarchicalData source="{dpHierarchy}"
      childrenField="
      children"/>
      </mx:dataProvider>
      <mx:groupedColumns>
      <mx:AdvancedDataGridColumn dataField="DATALEVEL"
      headerText="
      Destination/Product/Source"
      fontWeight="
      bold"
      width="
      200"
      editable="
      false"
      textDecoration="
      underline"/>
      <mx:AdvancedDataGridColumn dataField="PROD_DESCP"
      headerText="
      Prod Descp"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumnGroup headerText="Product-Level Attributes" fontWeight="bold" textDecoration="underline">
      <mx:AdvancedDataGridColumn dataField="BDC"
      headerText="
      BDC"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="BDC_SUBGRP"
      headerText="
      BDC SubGrp"
      editable="
      true"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="PROD_STAT"
      headerText="
      Prod Status"
      editable="
      true"
      itemEditor="
      mx.controls.TextArea"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="UOM"
      headerText="
      UOM"
      editable="
      false"
      width="
      50"/>
      <mx:AdvancedDataGridColumn dataField="EACHES_PER_UOM"
      headerText="
      Eaches/UOM"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="MIN_INC_FLG"
      headerText="
      Min/Inc Flag"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="TAG"
      headerText="
      Tags"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="DLY_ALLOC"
      headerText="
      Daily Alloc"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="FCST_PCT"
      headerText="
      Fcst Pct"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="SKU_MFG_SUBCLS"
      headerText="
      Sku Mfg Subcls"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="OVRD_PROD_FLG"
      headerText="
      Override Prod Flg"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="ON_OFF_LINE"
      headerText="
      On/Off Line"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="PROD_LEAD_TM"
      headerText="
      Produced Lead Time"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="NON_PROD_LEAD_TM"
      headerText="
      Non-Produced Lead Time"
      editable="
      false"
      width="
      100"/>
      <mx:AdvancedDataGridColumn dataField="RECIPE_EXISTS_FLG"
      headerText="
      Recipe"
      editable="
      false"
      width="
      100"/>
      </mx:AdvancedDataGridColumnGroup>
      <mx:AdvancedDataGridColumnGroup headerText="Source-Level Attributes" fontWeight="bold" textDecoration="underline">
      <mx:AdvancedDataGridColumn dataField="EFF_DT"
      headerText="
      Eff Dt"
      editable="
      false"
      width="
      75"/>
      <mx:AdvancedDataGridColumn dataField="END_DT"
      headerText="
      End Dt"
      editable="
      false"
      width="
      75"/>
      <mx:AdvancedDataGridColumn dataField="ORD"
      headerText="
      Ovrde Recv Days"
      editable="
      false"
      width="
      75"/>
      <mx:AdvancedDataGridColumn dataField="RECV_WKS"
      headerText="
      Recv Wks"
      editable="
      true"
      width="
      75"/>
      <mx:AdvancedDataGridColumn dataField="LOAD_OFFSET"
      headerText="
      Load Offset"
      editable="
      true"
      width="
      75"/>
      <mx:AdvancedDataGridColumn dataField="TIME_FENCE"
      headerText="
      Time Fence"
      editable="
      true"
      width="
      75"/>
      <mx:AdvancedDataGridColumn dataField="TRANS_LEAD_TM"
      headerText="
      Trans Lead Time"
      sortable="
      false"
      editable="
      true"
      width="
      75"/>
      </mx:groupedColumns>
      </mx:AdvancedDataGrid>
      </s:VGroup>
      </mx:VBox>
        • 1. Re: AdvancedDataGrid selectedItem is null
          ssardar Level 1
          Without implementing your code
          try:
          evt.currentTarget.selectedItem.toString() if your data provider is an arrayCollection of strings, if it contains objects then
          evt.currentTarget.selectedItem.AttributeName.toString()
          • 2. Re: AdvancedDataGrid selectedItem is null
            checker2505 Level 1
            That is exactly what I am doing but evt.currentTarget.selectedItem is null.
            • 3. Re: AdvancedDataGrid selectedItem is null
              ssardar Level 1
              also try using "click" instead of itemClick on
              your advanceddatagrid.
              I wrote a simple example:
              <mx:Application
              xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" >
              <mx:Script>
              <![CDATA[
              import mx.charts.series.ColumnSeries;
              import mx.charts.CategoryAxis;
              import mx.charts.LinearAxis;
              import mx.controls.Alert;
              private function handleClick(evt:Event):void {
              Alert.show(evt.currentTarget.selectedItem.Month.toString());
              Bindable]
              var months = new ArrayCollection( [
              { Month:
              "February", Day:"Tuesday", Year:"2011"},
              { Month:
              "March", Day:"Friday", Year:"2012"},
              { Month:
              "April", Day:"Monday", Year:"2013"}]);
              </mx:Script>
              <mx:AdvancedDataGrid x="155" y="358" id="adg1" designViewDataType="tree" dataProvider="{months}" click="handleClick(event)">
              <mx:columns>
              <mx:AdvancedDataGridColumn width="85" headerText="Column 1" dataField="Month"/>
              <mx:AdvancedDataGridColumn width="35" headerText="Column 2" dataField="Day"/>
              <mx:AdvancedDataGridColumn width="35" headerText="Column 3" dataField="Year"/>
              </mx:columns>
              </mx:Application>
              • 4. Re: AdvancedDataGrid selectedItem is null
                ssardar Level 1
                although itemclick does work in my example too (I'm just in the habit of using click)
                I'll implement your posted code later today if you still don't have it working.
