0 Replies Latest reply on May 4, 2011 1:59 AM by RaviDalal
    Abstract data type in wsdl xml schema
    RaviDalal
      Hi ,
           I have just started using flex and trying to create a client for my web-services. But I am facing problems where I need to pass derived datatypes to my service. Consider following scenario:
      In my XML Schema I have
      DataType A : abstract
      DataType B with <xsd:extension base="A"> so B is a derived type from A.
      now when calling the webservice I am using some thing like
      <A xsi:type="B">
      //content of datatype B
      </A>
      I used flash builder to generate value objects but I could not find any class for B. So I had coded that. and then passed that to my service request. While debugging I found out that my soap request is empty.
      Sorry for not posting actual code. Any help is really appreciated.
      I have been looking into the problem for about 2 days now. I find out the abstract="true" is not supported in flex 3 , could not find any info about flex 4.
      Other solution is write your own encoder which I think I am too new to flex to write.
      Another solution was to hard code and XML object and send it across which will be populated in SOAP:body and passed as such. This approach actually worked.
