Hello Robohelpers,
So here is the issue: I am doing a front page to a webhelp that will basically have a screenshot of the software's front page, with an image map, saying "Please click on an area of the Portal page for more information about that section". This is up and works fine.
However, not all users will be presented with the same Portal page, some will have less options/functionality. I have made the image a UDV so that I can quickly swap in the correct screenshot depending on the output.
The issue then of course is the Image map, which has to change for each of the different images as the screenshot is different. I have tried editing the image map within the UDV Design display, but the Square/Circle/Polygon options are all greyed out (this is RH 9, btw).
Is there a way to make Image Maps for images being used as User Defined Variables? I could have all the images in the one topic and just use Condition tags to control which is outputted but this feels quite messy.
Thanks for any help, really appreciate this forum and the quick replies one tends to get,
cheers,
Paul
Hi Paul
I'm going to suggest a different approach.
Create a different page for each user type. Then use Conditional Build Tags to govern which page is included in the build.
When you think about it, you have to change the variable set and rebuild anyway. So it's not suggesting a more convoluted or more lengthy approach. Just a different way of handling it.
Another possibility would be to have all the different images and image maps in the same topic. Then conditionalize the unwanted ones out. But personally I think it would be simpler to have multiple topics.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
