5 Replies Latest reply on May 6, 2011 11:47 PM by kglad
    XML, CSS, Tabs and unwanted line breaks
    Rich_z7
      I've spent days trying to sort this one out...including many hours trawling the web but to no avail so hopefully some one here can help out.
      I have a site that compiles to Actionscript 2.0 and Flash player 8.  This site utilises XML output from ASP.Net driven database pages.
      The problem I have is basically that where I have some tabstops set,  in certain cases,  where the text starting from the first tab stop is over a certain length an unwanted line break is output just before the last word in the entry.  (I know it's always the last word since if I put another word on the end of the string the word that was originally on the new line is back in it's proper place - so it doesn't appear to be length related).
      Effectively,  what I want is as follows:
      header1:      Descriptive text header 1                                     header2: Description header 2
      header3:      Description header 3                                          header4: header 4 text
      descriptive text here across multiple lines
      What I'm getting is something like this:
      header3:      Description header 3 with a long
      description   header4: header 4 text
      The Xml I am loading is as follows (This has been anonymised and the angle brackets changed to '[]')
      [?xml version="1.0" encoding="utf-8"?]
      [config scrollPosition="right" styleSheet=".\stylesheets\cv.css"]
           [text]
                [textformat tabstops = "50,540,590"]:[tab /]T[tab /]T[tab /]T[tab /]:[br /]
                     [list_by]CV Entries By Date[/list_by]
                     [br /]
                     [headertext]Date:[/headertext]
                     [tab /]
                     [itemheader]Sep 2010 - Mar 2011[/itemheader]
                     [tab /]
                     [headertext]Agency:[/headertext]
                     [tab /]
                     [itemheader][a href="http://www.xxxx.eu/xxxx.cfm" target="_blank"]xxxxx[/a][/itemheader]
                     [br /]
                     [headertext]Role:[/headertext]
                     [tab /]
                     [itemheader]Abap Programmer Application Maintenance SAP ECC 6.0 Finland[/itemheader]
                     [tab /]
                     [headertext]Company:[/headertext]
                     [tab /]
                     [itemheader][a href="http://www.xxxx.com" target="_blank"]xxxxx[/a][/itemheader]
                     [br /]
                     [br /]
      There are appropriate closing tags further down the file.
      The CSS that relates to this is:
      headertext {
         display: inline;
          color: #008000;
      itemheader {
          display: inline;
          color: #FFFFFF;
      list_by {
          font-size: 11pt;
          text-align: center;
      preamble {
          font-family: verdana_italic;
          text-align: justify;
          margin-left: 150px;
          margin-right: 150px;
      sum_title {
          text-align: center;
          font-size: 11pt;
          font-weight: bold;
          color: #FFFF00;
      text {
          font-family: verdana;
          font-size: 9pt;
          color: #FFFFFF;
      And finally the Actionscript code:
                                             content_mc.scroll_txt.setTextFormat = tFormat;
                                             content_mc.scroll_txt.embedFonts    = true;
                                             content_mc.scroll_txt.html          = true;
                                             content_mc.scroll_txt.wordWrap      = true;
                                             content_mc.scroll_txt.multiline     = true;
                                             content_mc.scroll_txt.condenseWhite = true;
                                             content_mc.scroll_txt.styleSheet    = myCSS;
                                             content_mc.scroll_txt.text          = sXml;
      In order to get the CSS to overide the settings of the dynamic text field I use an empty TextFormat object tFormat.  The XML is loaded with ignoreWhite set to true.
      Anybody any ideas ?  Or can I not see the wood for the trees ?
      Regards
      Rich
        • 1. Re: XML, CSS, Tabs and unwanted line breaks
          that's expected behavior.  whether that's a flash "bug" or not, i don't know.  but i do know that using tab stops with text that exceeds a certain length causes havoc to your formatting.
          the only remedy i know is to adjust your tab stops (and sometimes the width of your textfield) so none of the text exceeds the length flash can handle or use multiple textfields instead of tab stops.
          • 2. Re: XML, CSS, Tabs and unwanted line breaks
            Rich_z7 Level 1
            Hi Kglad,
            "that's expected behavior."
            I would of said that's very unexpected.  I would expect that if the length of text output is less than the next tab stop then it should continue on the same line.  If it's more than the next tabstop then a line break would occur.
            I am just wondering if the flash text parser ignores any html that surrounds the output text - that might kind of be a reason since if it doesn't then the length of the text does exceed the next tab stop.  If it does,  the length of the text doesn't exceed the next tab stop.
            In anycase,  thanks for the answer,  I'll code a work around.
            Regards
            Rich
            • 3. Re: XML, CSS, Tabs and unwanted line breaks
              like i said, it may be a bug.
              and "unexpected" wasn't a good choice of words.  i expect it because i'm familiar with the issue but you're correct, i didn't expect it when i first encountered it.
              • 4. Re: XML, CSS, Tabs and unwanted line breaks
                Rich_z7 Level 1
                At least your reply got me moving again.  I've added code to split any long texts into two lines,  whilst keeping the header as 2 by 2 with the extra line as a third line.
                Thanks for your help!
                • 5. Re: XML, CSS, Tabs and unwanted line breaks
                  you're welcome.
