1. Re: Textbox value based on menu list selected value
cfwild May 9, 2011 4:15 PM (in response to molaybusiness@gmail.com)Hi,
Lots of potential options.
1). Keep it simple. Put the information all in the one text box, just like you have it on the posting: Men's Polo Shirt - XL - Red - $29.99.
2). If you have the same item with lots of colors, navigate them to the Men's Polo Shirt page, then you only need XL - Red - $29.99.
3). If you only have a few options and they're going to be fairly static, a javascript script would do a very nice job.
4). If you have a lot of items, I'd suggest using a query to populate the initial select box, then use the "bind" function via a cfc to populate the other two boxes. You'd simply put the ID in the sql WHERE clause as ARGUMENTS.ID then return the fields you need.
select ....
from ...
where ...ID = ARGUMENTS.ID
<cfwild />
2. Re: Textbox value based on menu list selected value
molaybusiness@gmail.com May 9, 2011 8:00 PM (in response to cfwild)Thank you for your help.
Sent from my iPhone
