4 Replies Latest reply on May 5, 2011 6:22 AM by DFBurns
    Bug? Coldfusion Search hangs
    DFBurns Level 1
      Checking out the release of CFB2, I'm having problems with the new ColdFusion Search feature.
      I thought a reasonable use-case would be to do a tag search for cfquery's that contain 'INSERT INTO' and a specific table name. When I ran that, it pegged my CPU at 100%, CFB2's memory usage went from 250MB to 600MB and the progress indicator got stuck at 36%. I had to kill CFB2 and restart it to recover. Anyone else see this?
      db
        • 1. Re: Bug? Coldfusion Search hangs
          Sagar H Ganatra
          I'm not able to see this issue on my build. I've installed CFB 2 as standalone on Win 7. Can you please paste the code that you are using to search for the tag cfquery? Also, let me know the OS and the mode of installation (Standalone or Plug-in) on which you are seeing this issue.
          • 2. Re: Bug? Coldfusion Search hangs
            DFBurns Level 1
            I have a standalone install of version 2.0.0.277745 on WinXP SP3.
            I'm not sure what you mean by 'paste the code' so here is what I enter in the dialog box:
            Scope: Projects
            Project: I check my one open project
            File Extensions: CFM and CFC only
            Search: Tag
            Choose Tag: cfquery
            Match: All of the conditions
              Containing 'Text' where text is INSERT INTO
              Containing 'Text' where text is dbTableName
            Action: Do nothing
            All Options boxes are unchecked.
            It seems to start fine (search results view opens and progress bar is moving) but gets to the 36% point I describe and then hangs. Using the cancel button results in the progress window saying a cancel was requested but that's it. I have not waited longer than 5 minutes to see if anything would happen.
            Please let me know what other info I can provide to you to help diagnose.
            • 3. Re: Bug? Coldfusion Search hangs
              Kiran Sakhare
              Hi
              Some cases ColdFusion tag search takes too long time to parse files which has HTML/CFML code which has some errors. Until the timeout, ColdFusion search seems to be hung while parsing these type of file. What I suggest you is, check in ColdFusion search dialog which file currently it is parsing, skip that folder containing that file or move the file somewhere/rename the file type not same as file extension you specified in search dialog.
              We will look into this issue, If you able to locate the file where search is seems to be hanging, please mail me to  ksakhare@adobe.com.
              Kiran Sakhare
              • 4. Re: Bug? Coldfusion Search hangs
                DFBurns Level 1
                Kiran -
                I've emailed you a file that makes the search hang when I only have CFB search in that file. I'm not 100% convinced that there aren't others since the status bar was not a reliable indicator of what file or files were causing the hang.
                db
