37 Replies Latest reply on May 17, 2017 2:03 PM by johnt58065029
    Acrobat failed to connect to DDE Server
    CMeisinger Level 1
      I have a user who is unable to open any PDF's using Acrobat Reader X he has the latest version and is using Wind
      ows XP SP3.  When he tries to open any PDF he gets the error "Acrobat failed to connect to
      DDE Server" any help with this is much appreciated!
      Chris
        • 1. Re: Acrobat failed to connect to DDE Server
          dave_m_k Adobe Employee
          Good day Chris,
          I'm not sure if you're having diffuculty w/ Acrobat or w/ Reader.  Regardless, this issue is most commonly related to file associations.
          As the user to do the following:
          1. Locate a PDF on the system via Search (any PDF will do)
          2. Hold down the Shift key and right-click the PDF file > Select 'Open with..'
          3. Select either Acrobat or Adobe Reader (depending on which application is actually installed)
          4. Check the box at the bottom of the dialog box that says 'Always open with..'
          If the issue persists after trying this, repair Acrobat or Reader.  This can be done via the Help > Repair menu option.
          Regards,
          David
          Acrobat Community Manager
          Adobe Systems
          • 2. Re: Acrobat failed to connect to DDE Server
            CMeisinger Level 1
            Thanks David,
            I did check the file associations and did a repair and uninstall/re-install and nothing worked but it turned out to be an issue with turning on a security policy in Symantec Endpoint that was causing Adobe to not open so I had to remove that policy in order for Adobe to work again.
            Chris
            • 3. Re: Acrobat failed to connect to DDE Server
              Hi Chris,
              Thanks for letting us know that it's working properly now!  Glad to know the solution.
              David
              Adobe Systems
              • 4. Re: Acrobat failed to connect connect to DDE Server
                rvsoest Level 1
                I have the same problem. Opening a pdf inside a browser doesn't work. Opening a pdf either in Acrobat Reader X or Acrobat 9 Pro. Sometimes a pdf opens after more than 5 min! But even than Acrobat freezes, the top showing "File", "Edit" etc. disapears!  I uninstalled any security programs with firewalls; no changes. Uninstalling and reinstalling doesnt work. Making pdf's with any software is no problem. I use Windows XP running Adobe CS4. Any help?
                • 5. Re: Acrobat failed to connect to DDE Server
                  Florian Wolf Level 1
                  Hi Chris,
                  Are you able to remember what to do with your Endpoint Protection?
                  I'm having exactly the same problem. Perhabs a central exeption would solve this problem?
                  Regards
                  Florian
                  • 6. Re: Acrobat failed to connect to DDE Server
                    peterbbbbb Level 1
                    I started to get  the same problem today.
                    I tried the <shift> "open with..." Doesn't work.
                    I think Adobe should provide an answer immediately. Most of my files are in Acrobat!!
                    • 7. Re: Acrobat failed to connect to DDE Server
                      CMeisinger Level 1
                      It turned out to be a policy
                      in the Symantec Endpoint Secrutiy I think I had tried turning on the NAC and it caused the issue so when I turned the policy off the user was able to open the pdf's again.
                      • 8. Re: Acrobat failed to connect to DDE Server
                        peterbbbbb Level 1
                        Adobe Reader function returned after rebooting - but it came up slowly. Now I'm worried. I've been using Windows 7 for a year with Spyware Doctor without problems. I haven't done anything to the machine and I haven't installed anything new for months.
                        Where did this "Acrobat failed to connect to DDE Server" spring from?
                        • 9. Re: Acrobat failed to connect to DDE Server
                          Disabling the NAC wasn't the solution for my DDE server error.
                          The adobe support hotline told me to have a look at the folder permissions. All looks like it should be at my servers.
                          Anybody else here having another idea?
                          • 10. Re: Acrobat failed to connect to DDE Server
                            peterbbbbb Level 1
                            I just got an Adobe upgrade and the problem has gone. What the...!
                            • 11. Re: Acrobat failed to connect to DDE Server
                              CMeisinger Level 1
                              Was it just the usual upgrades that happen from time to time?  If so then good!
                              • 13. Re: Acrobat failed to connect to DDE Server
                                CMeisinger Level 1
                                Whacky...I will have to try testing with Symantec policies again and see if there's anymore issues.  Thanks for the info.
                                • 14. Re: Acrobat failed to connect to DDE Server
                                  Thank you peter. I also updated the terminal servers and will see what happens next week.
                                  • 15. Re: Acrobat failed to connect to DDE Server
                                    SA TIPSA Level 1
                                    Did the updates solve your problems?
                                    I am also experiencing this on a terminal server,2k8r2. Both acrobat pro and acrobat reader have the latest updates. Reader is set at default for reading pdf files.
                                    The problem occured after installing the latest updates in acrobat pro. There is no symantech or sophos security systems installed, even windows firewall is disabled.
                                    Any sugestions?
                                    • 16. Re: Acrobat failed to connect to DDE Server
                                      peterbbbbb Level 1
                                      The problem disappeared as soon as I loaded the latest (at the time) update.
                                      I don’t use Symantec and Windows Defender was “OFF”.
                                      • 17. Re: Acrobat failed to connect to DDE Server
                                        waltermouse Level 1
                                        I have just today begun having the same problem. Adobe Reader X on Win 7 pro 64bit SP1
                                        Can't be Symantec. I use MS Essentials security.
                                        Can't make any changes via Adobe Reader, either, because it won't open -- even when I try to launch directly from the target EXE file.
                                        This is making a LOT of PDFs unreadable and I am not happy.
                                        • 18. Re: Acrobat failed to connect to DDE Server
                                          waltermouse Level 1
                                          • 19. Re: Acrobat failed to connect to DDE Server
                                            PorterbleC Level 1
                                            I just fixed this on a W2008R2 server.
                                            Copied the files from a working profile to the profile that had a problem
                                            Copied all the adobe acrobat stuff from c:\Users\[workinguser]\appdata\   to c:\users\[userwithproblem]\appdata.
                                            They can now open PDFs without the problem.. Would think that on a workstation you ocould do the same so long as all the versions were the same.
                                            • 20. Re: Acrobat failed to connect to DDE Server
                                              TheShea Level 1
                                              I am getting a similar error - and I wasnt working with a PDF - I was using Filezilla to transfer files and two identical DDE erros pop up seemingly randomly - I will try and figure out how to replicate the error.
                                              I dont seem to have any problem opening a PDF normally tho - I have Reader X and recently installed 9 Pro.
                                              • 21. Re: Acrobat failed to connect to DDE Server
                                                enaygee Level 1
                                                If you just want to read PDFs, try installing a PDF reader like Nitro PDF Reader or Foxit Reader. Both of these read PDF files. Just google their names.
                                                I got the same error using Acrobat Pro 9. I can't figure out why Acrobat needs to connect to a DDE server.
                                                Good luck
                                                • 22. Re: Acrobat failed to connect to DDE Server
                                                  JeffyVinters Level 1
                                                  Take the updates. That should fix the issue.
                                                  • 23. Re: Acrobat failed to connect to DDE Server
                                                    TheShea Level 1
                                                    Been observing the error for a while and I regularly get two of the errors pop up for no seeming reason whatsoever.
                                                    The Error occured durring a spybot rootkit scan.
                                                    eight times
                                                    in the.
                                                    hklm software classes - keys.
                                                    Left the machine alone to watch a movie and eat after that scan - and the error occured 27 times!
                                                    Hasnt been happening so much in the last two weeks.
                                                    I did notice that even tho I ran the 'check for updates' thing and it says there are none - that there are several updates available here at adobe - so I am downloading them and isntalling them manually. I will report if the error recurrs after the updates - seemes to have worked for Peter.
                                                    Check the version of Acrobat you have and it should be 9.5 - if not - something is stoping the update.
                                                    • 24. Re: Acrobat failed to connect to DDE Server
                                                      AllDayDev Adobe Employee
                                                      Hi Shea,
                                                      Note that the 9.5 update is a full installer, which means you could uninstall your existing installation of Acrobat or Reader 9, and then just install 9.5 directly.
                                                      I know there are sometimes issues when you have to install a base version, and then update it (e.g. 9.3 > 9.4 > 9.4.1, etc.), and not having to do so usually mitigates installation-related problems.
                                                      http://www.adobe.com/support/downloads/product.jsp?product=10&platform=Windows
                                                      • 25. Re: Acrobat failed to connect to DDE Server
                                                        ConnieVanceKingery Level 1
                                                        I am having the exact problem. or when I try to open, it goes to the "buy Adobe screen" and will not allow me to open, unless I open in another tab!
                                                        • 26. Re: Acrobat failed to connect to DDE Server
                                                          TheShea Level 1
                                                          Yo Carey! ( guess what I gots - An Acrobat 9 Pro ACE )
                                                          Well, I have reader X installed.. but that is neat to know. So the troubleshooting path here seems to be..
                                                          1. Verify update status of the software.
                                                          2. Verify that active security policies are not interfering with the software.
                                                          3. Check if the problem happens in another user profile.
                                                          Hehe, we have two different scenarios here actually.. in my case the error is simply appearing. I dont have to be using PDFs or have either Reader or Acrobat running - which means the fast laucher / acrotray software is capable of generating the error. In other cases certain PDFs are failing to open, and in others the entire system is not launching..
                                                          Here is a thought - since the DDE naming conventions were changed in the Acrobat X would it be possible that the error is arising from having 'nonsanguine' versions of Acrobat and Reader? Say you have acrobat 8 but you recently installed Reader X - the behind the scenes program naming conventions are now different, but the systems are attempting to use the same resources. Perhaps this is the reason the problem is occuring? Obviously some sort of permissions issue is involved.. or changing security policies wouldnt do anything.
                                                          @All - is anyone experiencing the error with Acrobat X and Reader X installed?
                                                          • 27. Re: Acrobat failed to connect to DDE Server
                                                            KsubZero100 Level 1
                                                            I'm pretty peeved. This "security update" pops up scaring you into installing the update to 9.5, only to find out that a) Adobe Pro doesn't work anymore b) reinstalling this 9.5 update again can't even  select my version of Adobe 9 to update agaain (probably b/c its already updated) c) Adobe version 9 and older owners have to pay extra to chat with somebody to find out what the hell happened.
                                                            I'm running an older Mac 10.4.11  Could this have been the reason that this 'update' can't run on my machine?  I'd just linke to turn back the hands of time.
                                                            • 28. Re: Acrobat failed to connect to DDE Server
                                                              TheShea Level 1
                                                              Something obviously went wrong durring the installation of 9.5 - running an update is certainly not *intended* to stop you from using the product. What the hell happened is there was a permissions or resources issue - or a software conflict on you system when you ran the updarte. That is what the hell happend Ksub
                                                              You could speak with Apple care and they would probably be able to get you through the uninstall and reinstall of the software - which is most likely what will have to happen at this point. You should also ask them about basic preventative system maintenance. I assume you were getting the DDE server error and this is what prompted you to run the update?
                                                              Intruiging.. its happening on both Mac and Win - well - You *were* getting the DDE error prior to or now that you have installed the update?
                                                              Do you have Reader X?
                                                              Message was edited by: TheShea
                                                              • 29. Re: Acrobat failed to connect to DDE Server
        KsubZero100 Level 1
        No I don't have Reader, b/c Acrobat does everything reader can do. I just uninstalled and reinstalled my "older" Acrobat 9.0 so things are back to normal.  I'm going to ignore all call for any "updates" on my Acrobat
        • 30. Re: Acrobat failed to connect to DDE Server
        GDT-IT-Dept Level 1
        We have been getting the "Fatal Error: Acrobat failed to connect to DDE Server." message for quite some time without any consistent way of making the error happen.
        We have six VM Citrix servers running Windows Server 2008 R2 Standard v6.1.7600.1, Microsoft Dynamics SL v7.0 Feature Pack 1 - Professional Version 7.03.40312.01 (7.0.0.0), Adobe Acrobat Standard X v10.1.2.  We use Kaspersky AV 6.0 for Windows Servers for our Endpoint Protection.  Users use Citrix to run Dynamics from their local machine and when creating PDFs with BullZIP PDF, it will open PDFs in Acrobat Standard.
        This was happening when we had Acrobat Standard v9 as well.  We tried uninstalling and reinstalling Acrobat to see if that would fix it, but no joy.  We tried upgrading to Adobe Standard X to see if that would fix it, no joy.
        Reading on these threads, to turning off Protected Mode,  The instructions say to Disable Protected Mode, you go to Edit > Preferences > General and deselecting Enable Protected Mode at startup.  However, when I get to that window, there in no check box for this.
        Any other thoughts?  We're going crazy...
        • 31. Re: Acrobat failed to connect to DDE Server
        Simfunk Level 1
        I can't say for sure this will solve your problems
        But we solved the problem today for a customer, by simply starting the two services on the machine:
        Network DDE DSDM
        Network DDE
        In that order.
        I hope that helps.
        • 32. Re: Acrobat failed to connect to DDE Server
        artank Level 1
        In Adobe Reader XI (probably also in X), the option Enable Protected Mode at startup is located in Edit > Preferences >Security (Enhanced). It seems that in my case it was necessary to untick Enable Enhanced Security to get rid of the error message "Fatal Error: Acrobat failed to connect to DDE Server."
        • 33. Re: Acrobat failed to connect to DDE Server
        kendrickj35800888 Level 1
        Good afternoon,
        I hope all is well. My organization is running into the same issue with us trying to open .pdfs and getting the "Acrobat failed to connect to a DDE server" error message. Our issue is occurring with us using our vendor applications and trying to open the .pdf within that application. We use a Windows 7, 64-bit environment. We also use IE9 and adobe acrobat version 10.1.13. Any help on this issue is greatly appreciated as this is affecting one of our bigger departments and I have troubleshooted the best I could with no good results.
        Kendrick Jones
        • 34. Re: Acrobat failed to connect to DDE Server
        WeiHelen@co.kane.il.us Level 1
        Hi, artan, same issues here. I did repair install, and it still can not open a PDF file.  I use Adobe Acrobat XI Pro. It show an error message as " Adobe failed to connect to a DDE server". Even Adobe "LiveCycle Designer ES4 has the same error message. they all works good before.  The DDE server causes many adobe PDF application not work.  Please help! I have many projects need to be done.
        • 35. Re: Acrobat failed to connect to DDE Server
        GambyBrenda Level 1
        I need help with this as well.  Every time I update, this problem occurs.  I've used a plugin fix before but I can't find what I need online.  Why is this always a problem with updates?
        • 36. Re: Acrobat failed to connect to DDE Server
        BrentZact Level 1
        this worked for me on my fresh first time install of adobe cc on a new machine that included acrobat pro dc
        • 37. Re: Acrobat failed to connect to DDE Server
        johnt58065029 Level 1
        I got a new  computer with Windows 10 in January.  I downloaded my Adobe cS6 with Acrobat 10 Pro.  Since then have had to download to Adobe software 3 times to get Acrobat working.  Randomly, in the middle of a "save as a pdf" from Illustrator, the acrobat quits working and I get a Fatal Error, Failed to connect to DDE server message.  i am not a computer tech, and I can't understand half of what is on this forum, just would like some simple, detailed help in getting the stupid program to work so I can open my files and hopefully avoid uninstalling and then reinstalling the entire CS6 package.  Please.
