1 Reply Latest reply on May 9, 2011 12:41 PM by Haakenlid
    Can script dup Image with photoshop path
    ask4forhelp
      VBscript is preferred, Thankyou.
      I would like script to do because speed is fast.
      duplicate current selection image
      bring to front
      remove all effects
      take photoshop path
      fit to size
      Which on-hand shortcut will be:
      CTRL+ALT+U, 1 {tab} 0 {tab} 0 {tab} {enter}
      CTRL+SHIFT+]
      ALT+O, E, A
      CTRL+ALT+SHIFT+K, ALT+Y, {DNArrow}{DNArrow} {enter}
      ALT+O, F, F
      Manual Step not hard to do, but script make faster.
      If using SendKeys, Need to Sleep few seconds for waiting dialog, but fail to use WSH object to sleep.
        • 1. Re: Can script dup Image with photoshop path
          Haakenlid Level 3
          Don't know VB, but here is how to do it with javascript. Should not be too difficult to convert to VB if you know it.
          var myImage = app.selection[0];
          //duplicate current selection image
          myImage.duplicate();
          // bring to front
          myImage.bringToFront();
          //remove all effects (I do this by applying object style [none])
          myImage.appliedObjectStyle = app.activeDocument.objectStyles.itemByName("[None]");
          myImage.clearObjectStyleOverrides();
          //take photoshop path (I assume there is just one path in the file)
          myImage.images[0].clippingPath.clippingType=ClippingPathType.PHOTOSHOP_PATH;
          //fit to size (I assume you mean "Fit frame to content")
          myImage.fit(FitOptions.FRAME_TO_CONTENT);
