2 Replies Latest reply: May 4, 2011 3:00 PM by Michelle5002 RSS
    dataGrid with itemEditor with DropDownList error
    Michelle5002 Community Member
      I keep getting this error   TypeError: Error #1034: Type Coercion failed: cannot convert  views::EmployeesNonAvailsInnerClass2@3717c29 to  mx.controls.listClasses.IListItemRenderer.  When I select the column  which the dropdownList is suppose to display.  I am using a custom  component which I included the code below.  I am new to Flex and so what  I have so far came out of the book Flex 4 Bible.  My data is coming  from a webservice and returns an array of class ReasonDto and I am  saving the results to a s:ArrayCollection.  I sorta had it working  before the custom dropdownlist when I used mx controls but I keep  getting this when I use s controls.  Any suggestions?
      package components
        import mx.events.FlexEvent;
        import spark.components.DropDownList;
        public class SelectableDropDown extends DropDownList
          public var selectField:String = "";
          public var selectFieldValue:* = null;
          public function SelectableDropDown()
            super();
            this.addEventListener(FlexEvent.CREATION_COMPLETE, creationCompleteHandler);
          private function creationCompleteHandler(event:FlexEvent):void
            updateSelection();
          public function updateSelection():void
            if (selectField != "" && selectFieldValue != null && dataProvider != null)
              var dataObj:Object;
              for (var i:Number=0; i<dataProvider.length; i++)
                dataObj = dataProvider.getItemAt(i);
                if (dataObj[selectField] == selectFieldValue)
                  selectedIndex = i;
                  break;
      Here is the code which calls the component
                  <mx:DataGridColumn headerText="Reason" width="100" dataField="reason.reason" editable="true"
                                     editorDataField="selectedItem">
                      <mx:itemEditor>
                          <fx:Component>
                              <components:SelectableDropDown prompt="Select a Reason"
                                               dataProvider="{parentDocument.reasonsDP}"
                                               labelField="reason.reason"
                                               selectField="reason"
                                               selectFieldValue="reason.reason"/>
                          </fx:Component>
                      </mx:itemEditor>
                  </mx:DataGridColumn>
        • 1. Re: dataGrid with itemEditor with DropDownList error
          The answer was to just add the canvas and that solved it. Still having issues but this is the solution to this problem
          Here is my current code now
                          <mx:itemEditor>
                              <fx:Component>
                                  <mx:Canvas>
                                      <fx:Script>
                                          <![CDATA[
                                              import mx.collections.ArrayCollection;
                                              import mx.rpc.events.ResultEvent;
                                              import mx.controls.Alert;
                                              [Bindable]
                                              public var reasonsDP:ArrayCollection;
                                              protected function sdd_creationCompleteHandler(event:FlexEvent):void
                                                  getReasonsResult.token = personnelBean.getReasons();
                                              public function get selectedItem():ReasonDto
                                                  return selectableDropDown.selectedItem;
                                              public function get prompt():ReasonDto
                                                  return selectableDropDown.selectedItem.reason;
          <!--                                    public override function setFocus():void
                                                  selectableDropDown.setFocus();
                                              protected function getReasonsResult_resultHandler(event:ResultEvent):void
                                                  reasonsDP = getReasonsResult.lastResult;
                                      </fx:Script>
                                      <fx:Declarations>
                                          <personnelbean:PersonnelBean id="personnelBean" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
                                          <s:CallResponder id="getReasonsResult" result="getReasonsResult_resultHandler(event)"/>
                                          <valueObjects:ReasonDto id="reasonDto"/>
                                          <!-- Place non-visual elements (e.g., services, value objects) here -->
                                      </fx:Declarations>
                                      <components:SelectableDropDown id="selectableDropDown"
                                                       dataProvider="{reasonsDP}"
                                                       labelField="reason"
                                                       selectFieldValue="reason"
                                                       creationComplete="sdd_creationCompleteHandler(event)"/>
                                  </mx:Canvas>
                              </fx:Component>
                          </mx:itemEditor>
          • 2. Re: dataGrid with itemEditor with DropDownList error
            See my second post to this question
