12 Replies Latest reply on May 6, 2011 4:39 PM by kglad
    For Loop
    juresti Level 1
      I need this code to apply to holder_mc1-5. Does that make sense?
      Do I need to make an array?
      var j:Number;
      for (j = 0; j < 6; j++) {
      trace(j);
      _root["holder_mc"+j].onPress = function() {
          _root["holder_mc"+j].startDrag(false);
              _root["holder_mc"+j].lineStyle(3,0x000000,100);
              _root["holder_mc"+j].lineTo(_root.myWidth,0);
              _root["holder_mc"+j].lineTo(_root.myWidth,_root.myHeight);
              _root["holder_mc"+j].lineTo(0,_root.myHeight);
              _root["holder_mc"+j].lineTo(0,0);
        • 1. Re: For Loop
          change j=0 to j=1:
          var j:Number;
          for (j = 1; j < 6; j++) {
          trace(j);
          • 2. Re: For Loop
            aneelbakshi Level 1
            I would suggest.
            var j:Number;
            trace(j);
            _root["holder_mc"+j].id=j
                _root["holder_mc"+this.id].startDrag(false);
                    _root["holder_mc"+this.id].lineStyle(3,0x000000,100);
                    _root["holder_mc"+this.id].lineTo(_root.myWidth,0);
                    _root["holder_mc"+this.id].lineTo(_root.myWidth,_root.myHeight);
                    _root["holder_mc"+this.id].lineTo(0,_root.myHeight);
                    _root["holder_mc"+this.id].lineTo(0,0);
            • 3. Re: For Loop
              that should be:
              var j:Number;
              trace(j);
              with(this){
                  startDrag(false);
                     lineTo(0,0);
              • 4. Re: For Loop
                juresti Level 1
                They are both correct. So the way I wrote it the loop just went through and did not populate clips 1-5, only 5 worked. Is that right? The way you guys wrote it, the function worked for all clips.
                • 5. Re: For Loop
                  i wrote it so it works for 1-5.
                  • 6. Re: For Loop
                    aneelbakshi Level 1
                    yes in your case only 5 will work because when u click on i will have the value of  5. Coz when u click loop will be finished his task and i will have the maximum value of loop
                    • 7. Re: For Loop
                      juresti Level 1
                      So when you make the lop var equal to "id" or use the with statement it populates all 1-5?? If you could please give a small explanation I would appreciate it!
                      • 8. Re: For Loop
                        no, this line determines what objects are affected by the code:
                        my for-loop runs through j=1,2,3,4,5, which what you requested.  your for-loop was running through j=0,1,2,3,4,5 (and that other poster is making the same error that you were).
                        • 9. Re: For Loop
                          juresti Level 1
                          I'll have to look more at this.
                          This code is working:
                          var j:Number;
                          for (j = 0; j < 7; j++) {
                          eval("holder_mc"+j).onPress = function() {
                          with(this){
                              startDrag(false);
                                 lineStyle(3,0xcccccc,100);
                                lineTo(myWidth,0);
                                 lineTo(myWidth,myHeight);
                                 lineTo(0,myHeight);
                                 lineTo(0,0);
                          I need through 0-5, the code I had before would only draw the line around the last clip which was 5 but yea I ahd to increase the number to 7 but what I'm saying is it only drew a line around the last clip:
                          var j:Number;
                          trace(j);
                          • 10. Re: For Loop
                            use:
                            var j:Number;
                            this["holder_mc"+j].onPress = function() {
                            with(this){
                                startDrag(false);
                                  lineTo(myWidth,0);
                                   lineTo(0,myHeight);
                                   lineTo(0,0);
                            • 11. Re: For Loop
                              juresti Level 1
                              Yes I understand but I don't know exactly why my code does not work I wish someone could explain it ina way a
                              non programmer could get it. I'll look it over Thank you!!
                              • 12. Re: For Loop
                                use the trace() function to debug your code and decipher what flash is doing:
                                var j:Number;
                                trace(j);  // will trace 0,1,2,3,4,5
                                // when this object is pressed j is 5.  ie, the for-loop has already completed and j is at its last value (5).
                                trace(j); // will trace 5 no matter which object is pressed
                                trace(this); // will trace the pressed object
                                trace(this._name.substring(-1));  // will trace the value of j when the pressed object was created.
