1 Reply Latest reply on May 4, 2011 5:37 PM by Steve Grisetti
    Initializing the user interface
    The Real Chilly-B Level 1
      Since I got the full version of Adobe Premiere Elements 9, I have not been able to open it on my iMAC.  I had the trial installed and it worked fine.  When I installed the full version, I get this error when I try to open or create a new project.  It will load the project and then say in the lower left hand corner "Initializing the user interface..."   When I try to Restore Workspace, it crashes with this error:
      This is what I tried so far.  I reinstalled the program and ran the 9.0.1 patch.  The only way I could use PRE is to creat another user and login to that user to use PRE.  It is a work around, but I'd rather not have to go this route.  I did call adobe and they were the ones who suggest I make the new user.  When that worked, they said it had to do with the Apple permissions.  Anyone have any ideas as to how to fix this?
      This is copied from the crash report.
      Process:         Adobe Premiere Elements [435]
      Path:            /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/Adobe Premiere Elements
      Identifier:      com.adobe.Adobe Premiere Elements.framework
      Version:         N224.10122010.250938 (9.0.1)
      Code Type:       X86 (Native)
      Parent Process:  launchd [106]
      Date/Time:       2011-05-04 19:10:12.352 -0400
      OS Version:      Mac OS X 10.6.7 (10J869)
      Report Version:  6
      Interval Since Last Report:          324342 sec
      Crashes Since Last Report:           29
      Per-App Interval Since Last Report:  7493 sec
      Per-App Crashes Since Last Report:   21
      Anonymous UUID:                      5657DCB7-3849-477D-B102-08A0299A0492
      Exception Type:  EXC_BREAKPOINT (SIGTRAP)
      Exception Codes: 0x0000000000000002, 0x0000000000000000
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   com.adobe.dvacore.framework       0x0018cebc dvacore::utility::ThreadSafeMessageDialog(char const*) + 380
      1   com.adobe.dvacore.framework       0x0009baab dvacore::debug::BreakAfterContractDialog(char const*, char const*, int) + 251
      2   ...adobe.UIFramework.framework    0x010fee20 UIF::DisclosureTriangle::GetState() const + 96
      3   ...HandlerMovieTheme.framework    0x0bab22e4 HandlerMovieTheme::MovieThemeEditOptionsView::GetEditOptionsViewHeight() + 36
      4   ...HandlerMovieTheme.framework    0x0bab3652 HandlerMovieTheme::MovieThemeAllOptionsView::SetScrollParameters(ASL::ParamDimension<int> ) + 34
      5   ...HandlerMovieTheme.framework    0x0bab38be HandlerMovieTheme::MovieThemeAllOptionsView::SetSizeSelf(ASL::ParamDimension<int> const&) + 190
      6   ...adobe.UIFramework.framework    0x011c7785 UIF::WindowImpl::UI_SizeChanged(dvacore::geom::RectT<float> const&) + 53
      7   com.adobe.dvaui.framework         0x005b1391 dvaui::ui::OS_View::UI_HandlePlatformViewSizeChangedEvent() + 97
      8   com.adobe.dvaui.framework         0x005af370 dvaui::ui::DVAMacViewResized(NSView*) + 96
      9   com.adobe.dvacore.framework       0x00075cf9 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 41
      10  com.adobe.dvacore.framework       0x00076088 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(boost::function0<void>*, void*), boost::_bi::list2<boost::_bi::value<boost::function0<void>*>, boost::_bi::value<void*> > >, int>::invoke(boost::detail::function::function_buffer&) + 24
      11  com.adobe.Frontend.framework      0x060c5049 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0 <int>) + 41
      12  com.adobe.dvacore.framework       0x00074c2f void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 159
      13  com.adobe.dvacore.framework       0x00076bac void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 92
      14  com.adobe.dvaui.framework         0x005b98a6 -[DVAMacContainerView viewFrameDidChange:] + 134
      15  com.apple.Foundation              0x988593bf _nsnote_callback + 176
      16  com.apple.CoreFoundation          0x91d6c3c3 __CFXNotificationPost + 947
      17  com.apple.CoreFoundation          0x91d6bdca _CFXNotificationPostNotification + 186
      18  com.apple.Foundation              0x9884e25c -[NSNotificationCenter postNotificationName:object:userInfo:] + 128
      19  com.apple.Foundation              0x9885b669 -[NSNotificationCenter postNotificationName:object:] + 56
      20  com.apple.AppKit                  0x9002d7a1 -[NSView _postFrameChangeNotification] + 193
      21  com.apple.AppKit                  0x900275b6 -[NSView setFrameOrigin:] + 514
      22  com.apple.AppKit                  0x9002734d -[NSView setFrame:] + 228
      23  com.apple.AppKit                  0x900b79eb -[NSView resizeWithOldSuperviewSize:] + 414
      24  com.apple.AppKit                  0x9002d46c -[NSView resizeSubviewsWithOldSize:] + 177
      25  com.apple.AppKit                  0x900278da -[NSView setFrameSize:] + 713
      26  com.apple.AppKit                  0x90052052 -[NSControl setFrameSize:] + 128
      27  com.apple.AppKit                  0x90027385 -[NSView setFrame:] + 284
      28  com.adobe.dvaui.framework         0x005c2aee dvaui::ui::OS_View::UI_SyncPlatformViewToBaseFrame() + 558
      29  com.adobe.dvaui.framework         0x005b4b29 dvaui::ui::OS_View::UI_SetLocalRectF(dvacore::geom::RectT<float> const&) + 73
      30  com.adobe.dvaui.framework         0x005b25c2 dvaui::ui::OS_View::UI_SetLocalRect(dvacore::geom::RectT<int> const&) + 66
      31  ...adobe.UIFramework.framework    0x011dbf7f UIF::OSWindow::SetPositionAndSize(ASL::ParamPoint<int> const&, ASL::ParamDimension<int> const&) + 63
      32  ...adobe.UIFramework.framework    0x0105bbfe UIF::WindowImpl::SetPositionAndSize(ASL::ParamRect<int> const&) + 62
      33  ...HandlerMovieTheme.framework    0x0bade92f HandlerMovieTheme::MovieThemeHandler::CreateNewView() + 431
      34  ...HandlerMovieTheme.framework    0x0badee71 HandlerMovieTheme::MovieThemeHandler::NewView() + 17
      35  ...HandlerMovieTheme.framework    0x0baddf4b HandlerMovieTheme::MovieThemeHandler::AddViewToPane(UIF::Pane*) + 27
      36  ...dobe.EUIFramework.framework    0x06b04b98 UIF::PaneInfo::PopulateSelf(UIF::Pane*, bool, bool) + 1528
      37  ...dobe.EUIFramework.framework    0x06ae266b UIF::MainFrameInfo::PopulateSelf(ASL::ObjectPtr<UIF::PaneContainer, ASL::AtomicValue>, bool, bool) + 171
      38  com.adobe.Frontend.framework      0x060bbe00 FE::Application::ApplyDockingLayout(bool, bool, ASL::ObjectPtr<BE::DataReader, ASL::AtomicValue>) + 2112
      39  com.adobe.Frontend.framework      0x060baf3c FE::Application::LoadLayoutInfo(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool) + 364
      40  com.adobe.Frontend.framework      0x060bb266 FE::Application::LoadSystemDockingLayout(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool) + 70
      41  com.adobe.Frontend.framework      0x06113cab FE::MainFrame::OnRestoreEditingWorkspace(UIF::Command const&) + 123
      42  com.adobe.Frontend.framework      0x0612f7d6 FE::MainFrame::ObeyCommand(UIF::Command const&) + 918
      43  ...adobe.UIFramework.framework    0x010a1e7c UIF::Commander::PostCommand(int) + 60
      44  com.adobe.Frontend.framework      0x0614f255 HandleMenuCommand(NSMenuItem*) + 117
      45  com.adobe.dvacore.framework       0x00075cf9 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 41
      46  com.adobe.dvacore.framework       0x00076088 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(boost::function0<void>*, void*), boost::_bi::list2<boost::_bi::value<boost::function0<void>*>, boost::_bi::value<void*> > >, int>::invoke(boost::detail::function::function_buffer&) + 24
      47  com.adobe.Frontend.framework      0x060c5049 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0 <int>) + 41
      48  com.adobe.dvacore.framework       0x00074c2f void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 159
      49  com.adobe.dvacore.framework       0x00076bac void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 92
      50  com.adobe.Frontend.framework      0x06150590 -[PremiereCocoaMacApplication handleMenuCommand:] + 144
      51  com.apple.AppKit                  0x90089c46 -[NSApplication sendAction:to:from:] + 112
      52  com.apple.AppKit                  0x90089af9 -[NSMenuItem _corePerformAction] + 435
      53  com.apple.AppKit                  0x900897eb -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 174
      54  com.apple.AppKit                  0x900896da -[NSMenu performActionForItemAtIndex:] + 65
      55  com.adobe.dvaui.framework         0x005e160a -[DVAMacMenu performActionForItemAtIndex:] + 58
      56  com.apple.AppKit                  0x9008968d -[NSMenu _internalPerformActionForItemAtIndex:] + 50
      57  com.apple.AppKit                  0x900895f3 -[NSMenuItem _internalPerformActionThroughMenuIfPossible] + 97
      58  com.apple.AppKit                  0x90089537 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 336
      59  com.apple.AppKit                  0x9007dc61 NSSLMMenuEventHandler + 404
      60  com.apple.HIToolbox               0x94b54c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
      61  com.apple.HIToolbox               0x94b53ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      62  com.apple.HIToolbox               0x94b767f3 SendEventToEventTarget + 52
      63  com.apple.HIToolbox               0x94ba2e87 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
      64  com.apple.HIToolbox               0x94bc7b90 SendMenuCommandWithContextAndModifiers + 66
      65  com.apple.HIToolbox               0x94bc7b47 SendMenuItemSelectedEvent + 121
      66  com.apple.HIToolbox               0x94bc7a5d FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
      67  com.apple.HIToolbox               0x94b97160 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 454
      68  com.apple.HIToolbox               0x94b968bb _HandleMenuSelection2 + 465
      69  com.apple.HIToolbox               0x94b966d9 _HandleMenuSelection + 53
      70  com.apple.AppKit                  0x900771a2 _NSHandleCarbonMenuEvent + 285
      71  com.apple.AppKit                  0x9004bd3e _DPSNextEvent + 2304
      72  com.apple.AppKit                  0x9004afce -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
      73  com.apple.AppKit                  0x9000d247 -[NSApplication run] + 821
      74  com.adobe.Frontend.framework      0x0614fe26 FE::MacApplication::RunSelf(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 214
      75  com.adobe.Frontend.framework      0x060b08d7 FE::Application::Run(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 1079
      76  com.adobe.Frontend.framework      0x0615314a AppMain + 298
      77  com.adobe.Startup.framework       0x0633ad30 (anonymous namespace)::LaunchFrontendFramework(ASL::ObjectPtr<ASL::Module, ASL::AtomicValue> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 176
      78  ...Premiere Elements.framework    0x000038c6 (anonymous namespace)::CallStartupFramework(int, char const* const*) + 246
      79  ...Premiere Elements.framework    0x00003e85 main + 229
      80  ...Premiere Elements.framework    0x00003736 start + 54
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib                 0x98bf5922 kevent + 10
      1   libSystem.B.dylib                 0x98bf603c _dispatch_mgr_invoke + 215
      2   libSystem.B.dylib                 0x98bf54f9 _dispatch_queue_invoke + 163
      3   libSystem.B.dylib                 0x98bf529e _dispatch_worker_thread2 + 240
      4   libSystem.B.dylib                 0x98bf4d21 _pthread_wqthread + 390
      5   libSystem.B.dylib                 0x98bf4b66 start_wqthread + 30
      Thread 2:
      0   libSystem.B.dylib                 0x98bfd046 __semwait_signal + 10
      1   libSystem.B.dylib                 0x98bfcd02 _pthread_cond_wait + 1191
      2   libSystem.B.dylib                 0x98bfe998 pthread_cond_wait$UNIX2003 + 73
      3   ...ple.CoreServices.CarbonCore    0x924e248e TSWaitOnCondition + 126
      4   ...ple.CoreServices.CarbonCore    0x924cde15 TSWaitOnConditionTimedRelative + 202
      5   ...ple.CoreServices.CarbonCore    0x924c97e3 MPWaitOnQueue + 250
      6   com.adobe.dvacore.framework       0x000ee3da dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
      7   com.adobe.dvacore.framework       0x000ea26a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      8   com.adobe.dvacore.framework       0x00076c79 boost::function0<void>::operator()() const + 41
      9   com.adobe.dvacore.framework       0x000e6cdd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      10  com.adobe.dvacore.framework       0x000e7bd0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      11  ...obe.boost_threads.framework    0x0002f6ed thread_proxy + 141
      12  libSystem.B.dylib                 0x98bfc7fd _pthread_start + 345
      13  libSystem.B.dylib                 0x98bfc682 thread_start + 34
      Thread 3:
      0   libSystem.B.dylib                 0x98bcf0e2 semaphore_wait_signal_trap + 10
      1   libSystem.B.dylib                 0x98bfcc9c _pthread_cond_wait + 1089
      2   libSystem.B.dylib                 0x98c4545f pthread_cond_wait + 48
      3   com.adobe.amt.services            0x1378e4ba C_AMTUISwitchSuppressUpdates + 16864
      4   com.adobe.amt.services            0x1378749c C_EULA_SetState + 2166
      5   com.adobe.amt.services            0x1378e520 C_AMTUISwitchSuppressUpdates + 16966
      6   libSystem.B.dylib                 0x98bfc7fd _pthread_start + 345
      7   libSystem.B.dylib                 0x98bfc682 thread_start + 34
      Thread 4:
      6   ...e.Frameworks.ASL.Foundation    0x014e364e ASL::(anonymous namespace)::TaskProc(void*) + 94
      7   ...ple.CoreServices.CarbonCore    0x924ad7ca PrivateMPEntryPoint + 68
      8   libSystem.B.dylib                 0x98bfc7fd _pthread_start + 345
      9   libSystem.B.dylib                 0x98bfc682 thread_start + 34
      Thread 5:
      1   libSystem.B.dylib                 0x98c28ec5 nanosleep$UNIX2003 + 188
      2   ScriptLayer                       0x0bf1917b ScObjects::Thread::sleep(unsigned int) + 59
      3   ScriptLayer                       0x0bf01e13 ScObjects::BridgeTalkThread::run() + 163
      4   ScriptLayer                       0x0bf19288 ScObjects::Thread::go(void*) + 168
      5   libSystem.B.dylib                 0x98bfc7fd _pthread_start + 345
      6   libSystem.B.dylib                 0x98bfc682 thread_start + 34
      Thread 6:
      6   AdobeACE                          0x04a196f1 0x49df000 + 239345
      7   AdobeACE                          0x04a190ed 0x49df000 + 237805
      8   ...ple.CoreServices.CarbonCore    0x924ad7ca PrivateMPEntryPoint + 68
      9   libSystem.B.dylib                 0x98bfc7fd _pthread_start + 345
      10  libSystem.B.dylib                 0x98bfc682 thread_start + 34
      Thread 7:
      Thread 8:
      Thread 9:
      Thread 10:
      Thread 11:
      Thread 12:
      Thread 13:
      Thread 14:
      1   ...dobe.dvatransport.framework    0x0167e1e3 boost::asio::detail::kqueue_reactor<false>::run(bool) + 531
      2   ...dobe.dvatransport.framework    0x0167f409 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 489
      3   ...dobe.dvatransport.framework    0x0165b33e SkyConnectionEnv::MainLoop() + 94
      4   ...obe.boost_threads.framework    0x0002f6ed thread_proxy + 141
      Thread 15:
      3   ...dobe.dvatransport.framework    0x0167f6c2 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 1186
      4   ...dobe.dvatransport.framework    0x01680133 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run() + 51
      5   ...dobe.dvatransport.framework    0x01664fa7 asio_detail_posix_thread_function + 23
      Thread 16:
      0   libSystem.B.dylib                 0x98bcf09a mach_msg_trap + 10
      1   libSystem.B.dylib                 0x98bcf807 mach_msg + 68
      2   com.apple.CoreFoundation          0x91d4dfaf __CFRunLoopRun + 2079
      3   com.apple.CoreFoundation          0x91d4d094 CFRunLoopRunSpecific + 452
      4   com.apple.CoreFoundation          0x91d4cec1 CFRunLoopRunInMode + 97
      5   com.apple.audio.CoreAudio         0x933d396e HALRunLoop::OwnThread(void*) + 162
      6   com.apple.audio.CoreAudio         0x933bf4a4 CAPThread::Entry(CAPThread*) + 140
      7   libSystem.B.dylib                 0x98bfc7fd _pthread_start + 345
      8   libSystem.B.dylib                 0x98bfc682 thread_start + 34
      Thread 17:
      0   libSystem.B.dylib                 0x98bcf0fa semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib                 0x98bfcc85 _pthread_cond_wait + 1066
      2   libSystem.B.dylib                 0x98c2baa8 pthread_cond_timedwait_relative_np + 47
      3   ...ple.CoreServices.CarbonCore    0x924cde3d TSWaitOnConditionTimedRelative + 242
      4   ...ple.CoreServices.CarbonCore    0x924c97e3 MPWaitOnQueue + 250
      5   com.adobe.dvacore.framework       0x000ee3da dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
      6   com.adobe.dvacore.framework       0x000ea26a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      7   com.adobe.dvacore.framework       0x00076c79 boost::function0<void>::operator()() const + 41
      8   com.adobe.dvacore.framework       0x000e6cdd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      9   com.adobe.dvacore.framework       0x000e7bd0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      10  ...obe.boost_threads.framework    0x0002f6ed thread_proxy + 141
      11  libSystem.B.dylib                 0x98bfc7fd _pthread_start + 345
      12  libSystem.B.dylib                 0x98bfc682 thread_start + 34
      Thread 18:
      Thread 19:
      Thread 20:
      Thread 21:
      Thread 22:
      6   com.adobe.CameraRaw               0x2df09158 0x2dd08000 + 2101592
      7   com.adobe.CameraRaw               0x2df08a56 0x2dd08000 + 2099798
      Thread 23:
      3   com.adobe.CameraRaw               0x2dd4ddca 0x2dd08000 + 286154
      4   com.adobe.CameraRaw               0x2e073cd4 EntryFM + 894068
      5   com.adobe.CameraRaw               0x2de0e606 0x2dd08000 + 1074694
      Thread 24:
      4   com.apple.CoreFoundation          0x91d52fd4 CFRunLoopRun + 84
      5   com.adobe.dvacore.framework       0x000d9867 dvacore::threads::RunPlatformEventLoop() + 103
      6   com.adobe.dvacore.framework       0x000df24a dvacore::threads::(anonymous namespace)::EventLoopExecutor::EventLoopMain(dvacore::threads::SyncPoint&) + 154
      7   com.adobe.dvacore.framework       0x000def27 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, dvacore::threads::(anonymous namespace)::EventLoopExecutor, dvacore::threads::SyncPoint&>, boost::_bi::list2<boost::_bi::value<dvacore::threads::(anonymous namespace)::EventLoopExecutor*>, boost::reference_wrapper<dvacore::threads::SyncPoint> > >, void>::invoke(boost::detail::function::function_buffer&) + 55
      Thread 25:
      0   libSystem.B.dylib                 0x98bcf0ee semaphore_timedwait_trap + 10
      1   ...ple.CoreServices.CarbonCore    0x924dfbb2 MPWaitOnSemaphore + 125
      2   com.adobe.ols.library             0x31510737 OLSSemaphore::Wait(unsigned int) + 271
      3   com.adobe.ols.library             0x314f0502 OLSWorkerThreadTaskManager::ProcessTasks(OLSTaskThread*) + 1110
      4   com.adobe.ols.library             0x314ef037 OLSTaskThread::Run() + 27
      5   com.adobe.ols.library             0x31511633 OLSThread::ThreadProc(void*) + 29
      6   ...ple.CoreServices.CarbonCore    0x924ad7ca PrivateMPEntryPoint + 68
      Thread 26:
      0   libSystem.B.dylib                 0x98bda3e2 open$UNIX2003 + 10
      1   com.adobe.Frontend.framework      0x060ff506 FE::(anonymous namespace)::waitformsg(void*) + 86
      Thread 27:
      Thread 28:
      3   com.adobe.adobeswfl               0x3464fd5f APXGetHostAPI + 2567887
      4   com.adobe.adobeswfl               0x343f11ef APXGetHostAPI + 82783
      5   com.adobe.adobeswfl               0x3464fe4c APXGetHostAPI + 2568124
      6   com.adobe.adobeswfl               0x3464feb7 APXGetHostAPI + 2568231
      7   com.adobe.adobeswfl               0x3464ff9b APXGetHostAPI + 2568459
      Thread 29:
      Thread 30:
      3   com.adobe.adobeswfl               0x3464fd27 APXGetHostAPI + 2567831
      4   com.adobe.adobeswfl               0x347c50d8 APXGetHostAPI + 4096584
      Thread 31:
      4   com.adobe.adobeswfl               0x3466a6de APXGetHostAPI + 2676814
      Thread 32:
      2   ...ple.CoreServices.CarbonCore    0x92575aac TS_exception_listener_thread + 160
      3   libSystem.B.dylib                 0x98bfc7fd _pthread_start + 345
      4   libSystem.B.dylib                 0x98bfc682 thread_start + 34
      Thread 33:
      0   libSystem.B.dylib                 0x98bee066 select$DARWIN_EXTSN + 10
      1   com.apple.CoreFoundation          0x91d8d80d __CFSocketManager + 1085
      Thread 34:
      3   com.apple.audio.CoreAudio         0x933bf3c7 CAGuard::WaitFor(unsigned long long) + 219
      4   com.apple.audio.CoreAudio         0x933c23f9 CAGuard::WaitUntil(unsigned long long) + 289
      5   com.apple.audio.CoreAudio         0x933bfcf6 HP_IOThread::WorkLoop() + 1892
      6   com.apple.audio.CoreAudio         0x933bf58d HP_IOThread::ThreadEntry(HP_IOThread*) + 17
      7   com.apple.audio.CoreAudio         0x933bf4a4 CAPThread::Entry(CAPThread*) + 140
      Thread 0 crashed with X86 Thread State (32-bit):
        eax: 0x00000001  ebx: 0x0018cd4b  ecx: 0x006a8290  edx: 0x00000001
        edi: 0x001ff648  esi: 0x001ff648  ebp: 0xbfffd2e8  esp: 0xbfffcea0
         ss: 0x0000001f  efl: 0x00000246  eip: 0x0018cebc   cs: 0x00000017
         ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
        cr2: 0x00442000
      Binary Images:
          0x1000 -     0x3ff3 +com.adobe.Adobe Premiere Elements.framework N224.10122010.250938 (9.0.1) <CB8EC92E-5E07-E764-529D-21859A900BF3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/Adobe Premiere Elements
          0xa000 -     0xeffc +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <E6437929-0E69-8A56-E69F-F64305E82DD9> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReport er
         0x15000 -    0x1bfef +com.adobe.boost_date_time.framework boost_date_time version 8.0.0 (8.0.0.0) <16B587FC-3B88-3CAC-EA49-49C8530A2284> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
         0x2d000 -    0x34ff2 +com.adobe.boost_threads.framework boost_threads version 8.0.0 (8.0.0.0) <52458199-9BBE-EA78-70CE-C078622684DE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
         0x44000 -   0x1c1fef +com.adobe.dvacore.framework dvacore version 8.0.0 (8.0.0.0) <DFED1A19-6BB6-A397-64DB-0D803AE2A846> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
        0x343000 -   0x65dff7 +com.adobe.dvaui.framework dvaui version 8.0.0 (8.0.0.0) <84648108-9211-3A28-8B3F-A37CD997DFDF> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
        0x9c3000 -   0xa70fff +com.adobe.dvaworkspace.framework dvaworkspace version 8.0.0 (8.0.0.0) <8F322FAB-F0B4-89C5-5138-F9AD91704D3A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
        0xb43000 -   0xbe8fff +com.adobe.exo.framework exo version 8.0.0 (8.0.0.0) <94AB2A24-AFD5-25DB-EF10-260F1883A98B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/exo.framework/Versions/A/exo
        0xcde000 -   0xdc2fef +com.adobe.dvaeve.framework dvaeve version 8.0.0 (8.0.0.0) <B9C18986-07F5-D9F7-0A6B-1CAA9467E65A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
        0xec5000 -   0xf0efff +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 8.0.0 (8.0.0.0) <0806FC8B-9321-3C1E-4B94-E505FF1BC157> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
        0xf2f000 -   0xf87ff7 +AdobeXMP ??? (???) <73329999-C364-2451-6574-4D0277057D19> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
        0xf96000 -  0x1022fef +AdobeXMPFiles ??? (???) <A72BD678-CAD0-0C2A-0989-11E87B154AB5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
      0x1059000 -  0x124efef +com.adobe.UIFramework.framework ??? (1.0) <3CFEED6B-BFA2-2EEC-E57B-E62C1AD5E2C7> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
      0x1458000 -  0x1479ff7 +com.adobe.dvamediatypes.framework dvamediatypes version 8.0.0 (8.0.0.0) <0FE20B37-7CEE-8FDE-573D-3EA193C705CB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
      0x149a000 -  0x149affb +PRM ??? (???) <383A4352-5FE9-0D73-8E23-06A12D83E7B4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
      0x14a1000 -  0x150bff1 +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0) <72B48D53-00DF-8C82-C7AA-01A9C282EAE0> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
      0x15c9000 -  0x15defff +ASLMessaging ??? (???) <1425780D-FF58-9F45-8357-86E2344A8F7F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
      0x15fd000 -  0x15fefff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <ECBE5E96-AC61-6338-B7D8-80222B691F7E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
      0x1605000 -  0x1615ffd +ASLUnitTesting ??? (???) <1701C314-AEE9-7836-C783-3E8C97E3813E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
      0x162f000 -  0x1630ffb +com.adobe.boost_system.framework boost_system version 8.0.0 (8.0.0.0) <47EE4594-75B3-D887-7E1D-C47921C41436> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
      0x1638000 -  0x16a8fff +com.adobe.dvatransport.framework dvatransport version 8.0.0 (8.0.0.0) <D309BA02-0882-82AE-3B18-171E24E6CE8E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
      0x1728000 -  0x1762ffb +com.adobe.dvamarshal.framework dvamarshal version 8.0.0 (8.0.0.0) <A478730D-8D42-AA39-A941-E9D72DDB9CE5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
      0x17d8000 -  0x199dfe7 +com.adobe.dynamiclink.framework dynamiclink version 8.0.0 (8.0.0.0) <5167C3EA-0399-2029-DA70-9945BB53D9C2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
      0x1ac1000 -  0x1af5fe7 +com.adobe.MediaFoundation ??? (1.0) <60AC246A-218B-87F9-C52F-7C4AD0072191> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
      0x1b37000 -  0x1ba9ff7 +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0) <E042D5B6-B5AD-8CCB-6D91-9F29D2DBC04A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
      0x1c3a000 -  0x2766fe7 +com.adobe.MediaCore.Frameworks.Backend ??? (1.0) <CE69321B-1EE8-2F33-8578-D680197AA066> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
      0x345d000 -  0x35e9ffd +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0) <089DE64B-D83A-2FCE-23C6-C96B0B1B1C04> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
      0x36d6000 -  0x370eff3 +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0) <F8B76FB9-D7BA-67A9-6512-E55CC33BDA17> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
      0x375b000 -  0x37a6ff7 +com.adobe.MediaCore.VideoFrame 1.0 (1.0) <B4B640A4-7579-758A-F8FD-F7E0DE667776> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
      0x37ef000 -  0x3828fff +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0) <CFCE29DC-898E-E846-857D-98362834F4F9> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
      0x3869000 -  0x38a2fff +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0) <2BC72003-AF23-F10E-A351-12288F540EC1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
      0x38f2000 -  0x3937fef +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0) <95B15DAF-E349-7883-B5F2-E779E62D05E3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
      0x3980000 -  0x3982ff3 +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0) <01A20771-3B4B-5B32-B063-CE3B49B1FDC2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
      0x3989000 -  0x39a2ff3 +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0) <5C442959-81F1-F837-5314-4B741851585D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
      0x39c9000 -  0x39fcfef +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0) <2BE91FC6-0427-17B0-A14C-EEE21058AF7D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
      0x3a5b000 -  0x3b74fff +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0) <F9B9115B-4B05-47F7-C4FD-AB4FD2179534> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
      0x3cd8000 -  0x3e71fff +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0) <D5DC90DB-0C0B-C816-7220-E1614B45727A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
      0x401e000 -  0x40eafff +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0) <309D712C-3663-F041-D848-A7C6D38EAECE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
      0x41a0000 -  0x423aff3 +com.adobe.MediaCore.Frameworks.TimeWarpFilter 1.0 (1.0) <E88D632C-8F60-BE3B-1905-4D3C27920E6C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TimeWarpFilter.framework/Versions/A/TimeWarpFilter
      0x429f000 -  0x4363fff +com.adobe.MediaCore.Frameworks.ExporterHost 1.0 (1.0) <6F6A034B-CC8D-718A-2657-F8EB2A2DDF03> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
      0x4473000 -  0x44e8fff +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0) <794A5DD8-FE64-6261-D575-A810CE87E711> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
      0x457b000 -  0x45eaff7 +com.adobe.MediaCore.Frameworks.RecorderHost 1.0 (1.0) <CB8C425E-AD82-BD69-FC27-3DF2FF3E7E5F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
      0x4663000 -  0x466fff7 +com.adobe.MediaCore.Frameworks.ProjectConverterHost 1.0 (1.0) <079087AB-3AAD-C1EC-72DA-08118629F791> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConvert erHost
      0x4682000 -  0x468fff3 +com.adobe.MediaCore.Frameworks.ProjectSupport 1.0 (1.0) <213D4CF3-E724-A46C-B63B-0FEFC9F7526D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
      0x46a3000 -  0x46bafff +com.adobe.AMEAppFoundation.framework ??? (1.0) <E0CCB9E9-76EA-B8AD-FC20-472E14BCB1DB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
      0x46db000 -  0x46fcffd +com.adobe.PostEncodeHost.framework ??? (1.0) <37AA1110-24C5-AC18-1909-26E1B0978560> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
      0x4728000 -  0x4743fff +AdobeBIB ??? (???) <6E3DC6A9-066C-B736-6465-7F91D18860FB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
      0x474d000 -  0x47daff7 +com.adobe.AdobeScCore ScCore 4.1.23 (4.1.23.7471) <491BB523-30A6-E426-1C5D-799578012E33> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
      0x481f000 -  0x48b7fff +com.adobe.AdobeExtendScript ExtendScript 4.1.23 (4.1.23.7471) <ADBFBE50-AFEC-FFFE-B1C2-08EA2B3BE434> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
      0x4916000 -  0x4969ff2 +com.adobe.MediaCore.Frameworks.BravoInitializer 1.0 (1.0) <633C71E4-B4D6-40D9-3DFE-F9C508149808> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
      0x49df000 -  0x4af3fff +AdobeACE ??? (???) <DD291A17-ECF4-FE20-5837-AC1F5BC76940> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
      0x4b16000 -  0x4e25ff7 +AdobeAGM ??? (???) <202752CE-8950-5114-DD17-D5B087297A1F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
      0x4edb000 -  0x51cdff7 +AdobeCoolType ??? (???) <AEC9EB8F-2122-1708-3207-2A8BE3308FFA> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
      0x5255000 -  0x5319fff +AMEWrapper ??? (???) <D78F3EA9-0CBE-0A29-B22C-865792530CE1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
      0x53ce000 -  0x54e0fff +com.adobe.EncoderHost.framework ??? (1.0) <D19AC057-A2B1-D223-F601-9E816AECC162> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
      0x55d8000 -  0x5c1cfff +com.adobe.Mezzanine.framework ??? (1.0) <B44A1811-D89D-0CD9-AAF5-7BE707AFC401> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
      0x60a8000 -  0x61e7ffb +com.adobe.Frontend.framework ??? (1.0) <68D40A3B-6208-55B6-457F-8E7D6A4AEADE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
      0x6336000 -  0x6363fef +com.adobe.Startup.framework ??? (1.0) <FC6A40F0-A58B-38DC-B905-5791B340CF9F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Startup.framework/Versions/A/Startup
      0x6381000 -  0x63c1ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
      0x63da000 -  0x63e4ffd +com.adobe.boost_signals.framework boost_signals version 8.0.0 (8.0.0.0) <39CDA60E-525C-5D5D-F8B5-C0874C9210BF> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
      0x63f7000 -  0x6685fec +libxerces-c-3.0.dylib ??? (???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libxerces-c-3.0.dylib
      0x6808000 -  0x6808ff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
      0x680b000 -  0x6835ff3  com.apple.carbonframeworktemplate 1.0 (1.0) <19F5963C-F6A9-8012-A9DD-E26B1E10AF7C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
      0x6871000 -  0x6898fff +ameproperties ??? (???) <8E495A98-DA0B-DFF1-2FF6-D681C37620C8> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
      0x68d9000 -  0x68faff7 +AdobeBIBUtils ??? (???) <5CD3EBDF-A36B-D8E4-587B-AE297DEB32AA> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
      0x6906000 -  0x6909ffc +com.adobe.AppServices.framework ??? (1.0) <4F73A218-468F-900C-2312-F7CA04DA0945> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
      0x6914000 -  0x696affb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.013) <0AD52D68-CDB5-CB04-2CDD-1FCF5CF6CABE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
      0x69b3000 -  0x6a68fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
      0x6aae000 -  0x6be9fff +com.adobe.EUIFramework.framework ??? (1.0) <974AA901-74E7-833E-A18D-4F8AE5223C13> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/EUIFramework.framework/Versions/A/EUIFramework
      0x6d43000 -  0x6f2dfff +com.adobe.SettingsUI.framework ??? (1.0) <3D9B681B-D5B0-42A5-896D-832C991B423B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
      0x7144000 -  0x7155fff +com.adobe.DVDStructures.framework ??? (1.0) <093FD84B-330C-94B7-989A-936F12297C08> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/DVDStructures.framework/Versions/A/DVDStructures
      0x7172000 -  0x7597fef +com.adobe.AMocWrapper.framework ??? (1.0) <34ECBBFF-68ED-E7A3-F6C6-50A49178D7F6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AMocWrapper.framework/Versions/A/AMocWrapper
      0x77bb000 -  0x77c2ff3 +com.adobe.ContentAnalysisDBCache.framework ??? (1.0) <78003AB9-2CF4-53CB-8EFB-FDDE0F069082> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ContentAnalysisDBCache.framework/Versions/A/ContentAnaly sisDBCache
      0x77ce000 -  0x7811ff3 +com.adobe.ContentAnalysisData.framework ??? (1.0) <BCC67E4C-03C9-D29D-B039-C73FF039A85F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ContentAnalysisData.framework/Versions/A/ContentAnalysis Data
      0x7873000 -  0x78a3fff +com.adobe.ContentAnalysisHost.framework ??? (1.0) <09852D0F-1F7A-DBD4-B2AD-66F66B8444B6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ContentAnalysisHost.framework/Versions/A/ContentAnalysis Host
      0x78d6000 -  0x78dafff +com.adobe.BackendLegacyLib.framework ??? (1.0) <5850830D-48A5-27DA-EAD1-7A5A0E666471> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/BackendLegacyLib.framework/Versions/A/BackendLegacyLib
      0x78e2000 -  0x79fdfff +com.adobe.TitlerCreator.framework ??? (1.0) <F1EEB9A3-9A3D-F5B8-88CE-061EA6630549> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitlerCreator.framework/Versions/A/TitlerCreator
      0x7b82000 -  0x7ecfffb +com.adobe.premiere.TitleLayout 1.0 (1.0) <0CFBA6BD-2A55-FF49-D2A6-53B238E2E931> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
      0x847b000 -  0x8490fff +CAFilterUtils ??? (???) <1815CB67-8E4C-4792-1422-FE381D7AA2DA> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/CAFilterUtils.framework/Versions/A/CAFilterUtils
      0x84a5000 -  0x84abfff +com.adobe.IPLibrary.framework ??? (1.0) <D115D2C7-F6C9-3026-38D4-BC4524E00186> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/IPLibrary.framework/Versions/A/IPLibrary
      0x84b4000 -  0x8565ff3 +com.adobe.Descriptors.framework ??? (1.0) <0954EF40-080C-B04D-5EEC-32F4D8D075E3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Descriptors.framework/Versions/A/Descriptors
      0x85e0000 -  0x85e5ff3 +com.adobe.HeadlightsWrapper.framework ??? (1.0) <6E564A2A-A4E4-67A8-413F-02A34A97E971> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HeadlightsWrapper.framework/Versions/A/HeadlightsWrapper
      0x85ef000 -  0x864afff +com.adobe.dvametadata.framework dvametadata version 8.0.0 (8.0.0.0) <AD79F718-1249-D410-5A37-59E0699390A7> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
      0x86ca000 -  0x8755fff +com.adobe.dvametadataUI.framework dvametadataUI version 8.0.0 (8.0.0.0) <404F7BE8-8D03-35CD-2137-A00FD6CAC071> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
      0x87e9000 -  0x898afcf +AdobeOwl ??? (???) <710491D7-AD6A-47C5-92A0-E90151B60C9A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
      0x89f0000 -  0x8a5fff7 +FileInfo ??? (???) <CED115CA-FEEE-9DEF-5759-72D9B9FEA892> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
      0x8a7c000 -  0x8a7fff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
      0x8a85000 -  0x8bb7fef +com.adobe.premiere.TitleCG 1.0 (1.0) <5D01DF58-EC59-2C00-A788-2C80DAEE889B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
      0x8c7d000 -  0x8cb1fe7 +com.adobe.TitlerUI.framework ??? (1.0) <4CACDAAE-001C-F5A1-898F-2B14D98FFFE3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitlerUI.framework/Versions/A/TitlerUI
      0x8d03000 -  0x8d64fff +com.adobe.premiere.FontEngine 1.0 (1.0) <FB2D387A-0F0E-013F-92E6-2E5E6084F787> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
      0x8def000 -  0x8e1dffd +com.adobe.premiere.TitleLayer 1.0 (1.0) <3D047AD6-39F7-B440-0D39-D316D66B6ED4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
      0x9008000 -  0x90affe0 +com.adobe.premiere.TitleCharacterFactory 1.0 (1.0) <34DB2D94-8F74-7613-16FF-01AE4431BBBF> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacte rFactory
      0x910a000 -  0x9116ffb +com.adobe.premiere.TitleImageManager 1.0 (1.0) <C3F9477B-3A3A-EDEF-E8E3-12B025877DE5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
      0x912d000 -  0x9197ffb +com.adobe.amtlib amtlib 3.5.0.20 (3.5.0.20) <0B8E82C2-3FAA-8E81-CEEA-BBFE29706530> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
      0x91ae000 -  0x9237fff +com.adobe.MediaCore.Frameworks.UI 1.0 (1.0) <0C5E995C-DA90-1F0E-B142-B5C3FC4CC906> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
      0x92ab000 -  0x9890ff7 +com.adobe.premiere-elements.HSL ??? (1.0) <36197EE0-650B-886D-4CE0-07AB5783AE58> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
      0x9dc1000 -  0x9f4fffb +com.adobe.DVDCreator.framework ??? (1.0) <15AE8E2B-A314-28B9-79E4-B2656D9F3ECA> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/DVDCreator.framework/Versions/A/DVDCreator
      0xa0ce000 -  0xa184fff +com.adobe.HandlerAudioMixer.framework ??? (1.0) <A7F0782D-C13D-24C3-21D2-D7BEFBBD0156> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
      0xa24d000 -  0xa270fff +com.adobe.HandlerAudioNarration.framework ??? (1.0) <6E1EC7B8-3DEA-9734-23CC-02C949CB5E21> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerAudioNarration.framework/Versions/A/HandlerAudioN arration
      0xa2aa000 -  0xa3aefff +com.adobe.HandlerCapture.framework ??? (1.0) <ACA5E6D1-8430-F514-3365-0A4A65400480> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
      0xa4c0000 -  0xa7f6ff7 +com.adobe.HandlerEffectControls.framework ??? (1.0) <9378443B-038F-3A05-12CF-7086DFEA6EA4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffect Controls
      0xaaec000 -  0xaafafff +com.adobe.HandlerEvents.framework ??? (1.0) <310A6DF6-0220-DF2C-EC3B-30814F5C9849> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
      0xab15000 -  0xab28ffb +com.adobe.HandlerGetProperties.framework ??? (1.0) <941E8984-CC74-F069-1188-3F05E8B38CB1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetProp erties
      0xab4a000 -  0xab62ff7 +com.adobe.HandlerHistory.framework ??? (1.0) <15E02F92-25A5-2A61-B915-FD9C3A1FA23D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
      0xab8d000 -  0xabc2fff +com.adobe.HandlerInfo.framework ??? (1.0) <FD3317AB-F623-E1A0-C088-CEBBFC58ED41> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
      0xabfa000 -  0xadacff7 +com.adobe.HandlerMonitor.framework ??? (1.0) <9C1F4C2E-57C7-E37B-694F-BF3CFFE569D5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerMonitor.framework/Versions/A/HandlerMonitor
      0xaf59000 -  0xb238ff6 +com.adobe.HandlerProject.framework ??? (1.0) <E22BE716-3E82-5CF0-C62B-9F797BDE9590> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
      0xb55e000 -  0xb7befff +com.adobe.HandlerTimeline.framework ??? (1.0) <1EE62095-F280-6C7A-49CF-94B565A29F1E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
      0xb9e6000 -  0xba3fff7 +com.adobe.HandlerDVDLayout.framework ??? (1.0) <495EEB8D-9C35-927D-DD02-10A9F65E2195> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerDVDLayout.framework/Versions/A/HandlerDVDLayout
      0xbaaf000 -  0xbafffff +com.adobe.HandlerMovieTheme.framework ??? (1.0) <792629C8-A4D8-5187-69A5-E64FC9AC1587> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerMovieTheme.framework/Versions/A/HandlerMovieTheme
      0xbb57000 -  0xbcf3fff +com.adobe.HandlerOrganizer.framework ??? (1.0) <C792AD1B-3F95-AAB6-D471-7F371265999A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerOrganizer.framework/Versions/A/HandlerOrganizer
      0xbe80000 -  0xbe9ffff +com.adobe.HandlerSharingCenter.framework ??? (1.0) <8F4249BC-6E58-615A-D907-C707394E9209> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerSharingCenter.framework/Versions/A/HandlerSharing Center
      0xbecd000 -  0xbf40ffb +ScriptLayer ??? (???) <FFB6FD43-10B0-627D-A717-E5698FF141A6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ScriptLayer.framework/Versions/A/ScriptLayer
      0xbf99000 -  0xbfbbff7 +com.adobe.PreRegistration.framework ??? (1.0) <0EED1A4F-894E-4184-48F7-21535CDDE8DE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PreRegistration.framework/Versions/A/PreRegistration
      0xbfd8000 -  0xc03effb +com.adobe.OLS.framework ??? (1.0) <3E252689-2567-E85F-6F2F-61CC069DBD8A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/OLS.framework/Versions/A/OLS
      0xc096000 -  0xc0acff7 +com.adobe.ARA.framework ??? (1.0) <FBD9EBC7-2A02-3F99-BC04-626A5AA7AD62> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ARA.framework/Versions/A/ARA
      0xc0c8000 -  0xc0dcfff +UpdateManager ??? (???) <116FF8CB-8C96-FA63-F3A2-217093ADB095> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/UpdateManager.framework/Versions/A/UpdateManager
      0xc0e4000 -  0xc0f7ffb +com.adobe.About.framework ??? (1.0) <3FA3BD30-2429-AFF6-0B82-4B40B25D97BD> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/About.framework/Versions/A/About
      0xc117000 -  0xc11fffe +com.adobe.RoyaltyActivation.framework ??? (1.0) <2A936511-3BAD-5996-BEBC-6D41B685AED2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/RoyaltyActivation.framework/Versions/A/RoyaltyActivation
      0xc12e000 -  0xc18bff7 +com.adobe.MediaCore.Frameworks.Utilities.QT32Client 1.0 (1.0) <68E6C383-CD4C-E602-8D48-EB2112D05B96> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
      0xc1f9000 -  0xc21ffff  libssl.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <32607000-7573-6D51-ABC3-420B4A0D6629> /usr/lib/libssl.0.9.7.dylib
      0xc22e000 -  0xc818ff7 +com.sonic.AS_Storage 4.26.7 (compatibility 1.0.0) <025EFB44-885B-5F07-70F2-3E382EE15EA4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AS_Storage.framework/Versions/A/AS_Storage
      0xcb7f000 -  0xdb81fff +com.sonic.AuthorScriptHDMV 7.8.5 (1) <66242DA4-6A78-B73D-DDF8-9696CCF5B66D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AuthorScriptHDMV.framework/Versions/A/AuthorScriptHDMV
      0xf41d000 - 0x10161fff +com.adobe.psl AdobePSL 12.0.0.7524 (12.0.0.7524) <0A73AB2A-D09F-2F18-E2D1-BC35A8EED2A5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
      0x104a0000 - 0x119b9fe3 +com.adobe.AuthorScriptAPI.framework ??? (1.0) <B3F15D32-7B34-2F22-0505-008B74C313F3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AuthorScriptAPI.framework/Versions/A/AuthorScriptAPI
      0x12c11000 - 0x12c37ff6 +AdobeAXE8SharedExpat ??? (???) <62F48740-7712-3F35-BB04-D3B117F7CA64> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8Share dExpat
      0x12c48000 - 0x12d80fe7 +WRServices ??? (???) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
      0x12dc2000 - 0x12e2afcb +libDataCDUtf8.dylib 2.0.1 (compatibility 2.0.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libDataCDUtf8.dylib
      0x12eb5000 - 0x12f36fd3 +libhpCDEUtf8.dylib 2.0.1 (compatibility 2.0.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libhpCDEUtf8.dylib
      0x12fd4000 - 0x13008fd7 +libhpTAPEUtf8.dylib 2.2.1 (compatibility 2.2.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libhpTAPEUtf8.dylib
      0x13061000 - 0x1309ffcf +libVideoDVDUtf8.dylib 2.0.1 (compatibility 2.0.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libVideoDVDUtf8.dylib
      0x130f9000 - 0x13148ff7 +com.adobe.SCCommon.framework ??? (1.0) <043B40C7-A6DA-4CCF-66BC-905500658C59> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCCommon.framework/Versions/A/SCCommon
      0x13197000 - 0x131e3fff +com.adobe.SCFlashDVD.framework ??? (1.0) <3E1C2A14-176C-8E07-E71C-0001C50BED07> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCFlashDVD.framework/Versions/A/SCFlashDVD
      0x1323e000 - 0x13279fff +com.adobe.SCDisc.framework ??? (1.0) <81352B65-189D-01D4-195C-456D71CFE639> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCDisc.framework/Versions/A/SCDisc
      0x132bb000 - 0x132e6ff7 +com.adobe.SCPC.framework ??? (1.0) <2AD4939C-F8E3-DB0D-90B3-7AA8B8CF776C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCPC.framework/Versions/A/SCPC
      0x13312000 - 0x1333bff3 +com.adobe.SCMobile.framework ??? (1.0) <89DD9494-47EA-EDCE-3858-B6F4EAC08E49> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCMobile.framework/Versions/A/SCMobile
      0x13367000 - 0x133c8ff7 +com.adobe.SCWeb.framework ??? (1.0) <A3956DA8-00FD-093E-1D4F-FC3BA4F6A127> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCWeb.framework/Versions/A/SCWeb
      0x1342b000 - 0x13459fff +com.adobe.PresetManager.framework ??? (1.0) <BD52C2A7-3400-1821-EEA7-B122C904CAA1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PresetManager.framework/Versions/A/PresetManager
      0x134fa000 - 0x134fbff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0x1373c000 - 0x13760fe7  GLRendererFloat ??? (???) <0C6A1BCF-97F0-F7D6-C840-2991681BB67C> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
      0x13769000 - 0x137cefe7 +com.adobe.amt.services AMTServices 3.5.0.20 (BuildVersion: 3.5; BuildDate: Fri Jul 23 2010 21:49:00) (3.5.0.20) <9763F77A-D3BB-602B-E9B9-2C664CA32269> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
      0x137ea000 - 0x137f2fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
      0x2593c000 - 0x25ab4fe7  GLEngine ??? (???) <0E1DF3E4-0EEE-9FD8-8F52-FFFCF0DF23A7> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
      0x25ae6000 - 0x25ee4ffb  com.apple.ATIRadeonX2000GLDriver 1.6.26 (6.2.6) <496702B6-1B8D-0FCE-E3DB-707FFA7D5EE0> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLD river
      0x25f14000 - 0x25f84feb +com.adobe.adobe_caps adobe_caps 3.5.4.0 (3.5.4.0) <36D53A2C-0DAB-34C6-48C7-49D2ECF52D0D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
      0x2bdbb000 - 0x2bdc0ff7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <5E6FE5D1-F00A-447D-8F79-E0E09A122E21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
      0x2c258000 - 0x2c25cff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <F402CF88-D96C-42A0-3207-49759F496AE8> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
      0x2c261000 - 0x2c267ffb  com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <82BFF5E9-2B0E-FE8B-8370-445DD94DA434> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
      0x2c450000 - 0x2c474ff1 +com.mainconcept.mc_dec_dv 8.5 (8.5.0.24499) <38CCE568-A850-87C4-E9F7-E58787D658D2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
      0x2c51e000 - 0x2c53fff1 +com.mainconcept.mc_enc_dv 8.5 (8.5.0.24499) <AFB082F8-C0A3-AEF0-795A-602ED161B259> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
      0x2c554000 - 0x2c56efff  com.apple.carbonframeworktemplate 1.0 (1.0) <32C18346-63D3-40A8-CE94-4FC8D0B42759> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VXMLPresetReader.framework/vxmlpresetreader
      0x2c660000 - 0x2c686ff3 +com.adobe.MediaCore.ExporterQuickTimeHost 1.0 (1.0) <ED4D25C9-22EF-C39D-CF9C-229AC6A2A55A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/Exporte rQuickTimeHost
      0x2c6b6000 - 0x2c6d1fff +com.adobe.MediaCore.ImporterPSA 1.0 (1.0) <D513F20E-C7D5-7587-E2B9-FEF7040307D6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ImporterPSA.bundle/Contents/MacOS/ImporterPSA
      0x2ca25000 - 0x2ca5bfff +com.adobe.MediaCore.ImporterQuickTime 1.0 (1.0) <777F7F6D-ED06-AFB5-9463-79B84293920D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ImporterQuickTime.bundle/Contents/MacOS/ImporterQui ckTime
      0x2ca8f000 - 0x2caa5fff +com.adobe.MediaCore.Frameworks.QTParser 1.0 (1.0) <304D1A7D-199A-9D91-8F64-24D34118854B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
      0x2caba000 - 0x2cac0fef +libtbbmalloc.dylib ??? (???) <12F9EB2C-C80A-6170-E088-7DBDE36511E3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libtbbmalloc.dylib
      0x2cacd000 - 0x2cadbfe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <07211458-FD06-9FEF-3DF4-2E5F0304D4BC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
      0x2cc5e000 - 0x2ccd8ff7 +com.adobe.MediaCore.PlayerMediaCore 1.0 (1.0) <51B4B720-6D18-5858-7F3E-24433AAD1A2C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCo re
      0x2ce9c000 - 0x2cf50ffa +com.adobe.PremiereElements.PhotoshopAdapter 1.0 (1.0) <D4D185C2-85C4-89BD-B10A-376EACF31538> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/PSA/Photoshop Adapter.plugin/Contents/MacOS/Photoshop Adapter
      0x2d07b000 - 0x2d0acff2  com.apple.AVCVideoServices 1.0 (42) <8E8CFE8F-9877-45EB-8E6A-A47376F209FD> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
      0x2d0d9000 - 0x2d152fe7 +com.adobe.MediaCore.Frameworks.Display ??? (1.0) <F71E47B3-C7D1-4C41-CED4-6F54439EF979> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Display.framework/Versions/A/Display
      0x2d727000 - 0x2d784fef +aif_core ??? (???) <AF9EC89D-F9B4-E6A6-B55D-D61CE910B3CD> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
      0x2d7a1000 - 0x2d7bbff7 +image_runtime ??? (???) <8D487FD0-02CF-C361-67CB-4D613BE64322> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
      0x2d7d7000 - 0x2d7f2fff +com.adobe.MediaCore.AudioVideoIO 1.0 (1.0) <06DFAEC5-EB7B-0707-59DD-AE6DC73F9DB7> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioVideoIO.framework/Versions/A/AudioVideoIO
      0x2d815000 - 0x2d837ff7 +libtbb.dylib ??? (???) <AAA2AFA2-789A-41B8-D03D-C03861305060> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libtbb.dylib
      0x2d84a000 - 0x2d859fe8 +com.adobe.MediaCore.PremiereFiltersMetaPlugin 1.0 (1.0) <32340239-6068-936B-6D9B-315772F73D51> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/Premi ereFiltersMetaPlugin
      0x2d872000 - 0x2d880fff +BrightnessContrastCAFilter ??? (???) <F4A5859D-E651-4BC2-6D46-5AF0FCE83276> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/BrightnessContrastCAFilter.framework/BrightnessContrastCAFilter
      0x2dd08000 - 0x2e559fe7 +com.adobe.CameraRaw 6.1 (250) (6.1.0f250) <3A299A4B-A870-ED39-01E7-BC3B8CF56198> /Library/Application Support/Adobe/Plug-Ins/Elements 9/File Formats/Camera Raw.plugin/Contents/MacOS/Camera Raw
      0x2e8da000 - 0x2eb0bffb +aif_ogl ??? (???) <A5F168B4-8DCC-37BF-0DA3-D51E0D287360> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
      0x2edf7000 - 0x2ee11ffb +com.adobe.MediaCore.RecorderHDVMac 1.0 (1.0) <A0B52854-01A3-F2BC-40BF-2CE8341F7FC6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/RecorderHDVMac.bundle/Contents/MacOS/RecorderHDVMac
      0x2ee2f000 - 0x2eef5fef +com.adobe.MediaCore.IPPMPEGDecoder 1.0 (1.0) <ACB0B3C1-3B22-D9D7-8F9A-8E20313651ED> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
      0x2ef3b000 - 0x2ef6efff +com.adobe.MediaCore.RecorderQTKit 1.0 (1.0) <60CF5F61-EB52-12B9-2A62-4D6104B5F5EB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/RecorderQTKit.bundle/Contents/MacOS/RecorderQTKit
      0x2ef98000 - 0x2efcdfe3 +com.adobe.MediaCore.RecorderWebCamQTKit 1.0 (1.0) <287BB18E-5C7E-C902-4297-EFCF4EB771BC> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/RecorderWebCamQTKit.bundle/Contents/MacOS/RecorderW ebCamQTKit
      0x2eff9000 - 0x2f00cfe4 +com.adobe.MediaCore.TransitionsMetaPlugin 1.0 (1.0) <F483C239-B9FF-D716-13C4-E61183FE464A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/Transitio nsMetaPlugin
      0x2f02a000 - 0x2f047feb +AudioCAFilter ??? (???) <B1686B6C-01DF-4529-9D6B-E46A8B33ED2A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/AudioCAFilter.framework/AudioCAFilter
      0x2f059000 - 0x2f069fff +BlurCAFilter ??? (???) <F891B2EA-5208-8F6D-F144-78563BBBD59A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/BlurCAFilter.framework/BlurCAFilter
      0x2f07b000 - 0x2f0a7ff7 +FaceDetectionCAFilter ??? (???) <A232DEA3-AD5D-50AF-750F-DFEB84A8BB93> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/FaceDetectionCAFilter.framework/FaceDetectionCAFilter
      0x2f0d7000 - 0x2f17cffb +FaceDetector ??? (???) <1275F007-B8A7-CA23-8F89-570E182FCBA8> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/FaceDetector.framework/Versions/A/FaceDetector
      0x2f29b000 - 0x2f2b1fff +MotionCAFilter ??? (???) <6BD6EE6A-1580-9A9A-2579-D47877ACA255> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/MotionCAFilter.framework/MotionCAFilter
      0x2f2c5000 - 0x2f312fff +ObjTrackCAFilter ??? (???) <2981BC3B-1014-6B92-38AF-37E50435D226> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/ObjTrackCAFilter.framework/ObjTrackCAFilter
      0x2f34e000 - 0x2f361ff7 +ShakeCAFilter ??? (???) <8B112F2F-9FA8-FEC1-DF66-EE530520C976> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/ShakeCAFilter.framework/ShakeCAFilter
      0x2f373000 - 0x2f37fff7 +com.adobe.SceneDetectCAFilter.framework ??? (1.0) <589D349F-7048-8DDA-689A-124D0D6E3779> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/SceneDetectCAFilter.sd/SceneDetectCAFilter
      0x2f42f000 - 0x2f4c0ff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
      0x2f4df000 - 0x2f4f1ff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <8D606435-1A3C-FE0B-824A-1386809FFFF5> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
      0x2f6a1000 - 0x2f6a4fef  com.apple.LiveType.component 2.1.3 (2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
      0x2f6a9000 - 0x2f70efde  com.apple.LiveType.framework 2.1.3 (2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
      0x2fdd3000 - 0x30407feb +com.adobe.PDFL 9.9.0 (9.9.0.7414) <49D6D58A-1EBB-424A-4CB0-8F9691E0991D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobePDFL.framework/AdobePDFL
      0x30533000 - 0x30ee3fff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
      0x3123e000 - 0x3132affb +com.yourcompany.ems 1.0 (1) <2BD7FA47-A217-48B7-4F02-20E86E02A40E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ems.framework/ems
      0x313bb000 - 0x313e8ff3 +libcurl ??? (???) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libcurl.framework/libcurl
      0x313f4000 - 0x3141dfeb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <E0F7666B-921D-C4D6-63B3-E8B445D26892> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
      0x3142d000 - 0x3156ffe7 +com.adobe.ols.library 4.0 (4.0) <4BC1EDD1-F363-2845-36E1-36692B624FCB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeOLS.framework/AdobeOLS
      0x32e87000 - 0x32ec0ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.5.0.13 (1.5.0.13) <4F8229DD-D239-3773-1A53-51ECFA787463> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotific ations
      0x343ad000 - 0x351c6fc3 +com.adobe.adobeswfl ??? (2.0.0.7489) <C954CA64-9B28-A7FA-E391-C1C6524F1639> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/Ado beSWFL
      0x38a7c000 - 0x38a80ff7  com.apple.qldisplay.Generic 2.3 (327.6) <E8DD19EA-7E67-2828-8116-398A3ED6A7F7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/Resources/DisplayBundles/Generic.qldisplay/Contents/MacOS/Generic
      0x3e000000 - 0x3e046ff7  com.apple.glut 3.4.4 (GLUT-3.4.4) <DF15FD36-E1F5-D745-1BF6-DD3AEA2897E4> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
      0x40000000 - 0x400d1fe7 +AdobeJP2K ??? (???) <2ABF10A7-540A-06C8-21FA-186263931DF9> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
      0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
      0x90003000 - 0x908e3ff7  com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x908e4000 - 0x90981fe3  com.apple.LaunchServices 362.2 (362.2) <F3952CAB-322F-A12F-57AF-8B91B1D76DDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x9098a000 - 0x90997ff7  com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x90998000 - 0x909a6fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
      0x909a7000 - 0x909edff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
      0x909ee000 - 0x90af0fef  com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
      0x90af1000 - 0x90af4ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B84D7376-EE9C-2B7F-04FA-D622E2C10CA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
      0x90af5000 - 0x90bc6fe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <41417F73-42C5-FFC3-E7A1-EF94602CDCD6> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
      0x90c0d000 - 0x90c17ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x90c18000 - 0x9104fff3  com.apple.RawCamera.bundle 3.6.4 (561) <DBA5D7C1-CD82-CE7F-5AE5-A0E4E128236F> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x9134a000 - 0x913e2fe7  edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x913e3000 - 0x9149ffff  com.apple.ColorSync 4.6.6 (4.6.6) <D00B95AE-2379-CB8E-B18C-FF5B66741C23> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x914a0000 - 0x914e1ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <95079B56-0B7B-F114-5C43-5220DBE0FBB1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x91533000 - 0x9158dfe7  com.apple.CorePDF 1.3 (1.3) <696ADD5F-C038-A63B-4732-82E4109379D7> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
      0x9158e000 - 0x9158eff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x9158f000 - 0x915a0ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x915a1000 - 0x9189afef  com.apple.QuickTime 7.6.6 (1756.15) <C2567783-4EAC-6803-522B-D701B95C4DAE> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x9189b000 - 0x9189effb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x9189f000 - 0x91a59feb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <C96F11A7-2569-3037-C4C3-0342708FA3CB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x91a5a000 - 0x91a5aff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x91a93000 - 0x91ae4ff7  com.apple.HIServices 1.8.2 (???) <F6EAC2D1-902A-9374-FC4B-43B50E054416> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x91b33000 - 0x91bddfe7  com.apple.CFNetwork 454.11.12 (454.11.12) <BE832CCE-B692-F55F-F5F8-3973649AFEA1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0x91bde000 - 0x91bdeff7  com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x91bdf000 - 0x91c09ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
      0x91c0a000 - 0x91cb7fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
      0x91cd3000 - 0x91cfbff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
      0x91d06000 - 0x91d10fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x91d11000 - 0x91e8bfe3  com.apple.CoreFoundation 6.6.3 (550.29) <00373783-3744-F47D-2191-BEEA658F0C3D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x91e8c000 - 0x922a2ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x922a3000 - 0x922e3ff3  com.apple.securityinterface 4.0.1 (40418) <26D84A83-F5B9-93CF-71BB-0712698181EE> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
      0x922e4000 - 0x9233aff7  com.apple.MeshKitRuntime 1.1 (49.2) <F1EAE9EC-2DA3-BAFD-0A8C-6A3FFC96D728> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
      0x9233b000 - 0x923a9ff7  com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
      0x923aa000 - 0x923abff7  com.apple.audio.units.AudioUnit 1.6.6 (1.6.6) <253E9552-5CEA-0D5A-1EDA-3B8F669B79EA> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x923ac000 - 0x92486ffb  com.apple.DesktopServices 1.5.10 (1.5.10) <2BA08DD4-35A2-A0FF-ADEA-B381F0CEEB81> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x92487000 - 0x927a7ff3  com.apple.CoreServices.CarbonCore 861.34 (861.34) <3DA9098F-B71B-4BDE-5DE5-4B76C49158EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x92b13000 - 0x92b17ff7  IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x92bb7000 - 0x92c52ff7  com.apple.ApplicationServices.ATS 275.15.1 (???) <FD63F92B-8DDE-4DBA-A7A5-0294E3607083> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x92c53000 - 0x92c90ff7  com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x92ca1000 - 0x92ca5ff7  libGFXShared.dylib ??? (???) <4F2199F0-320F-0B59-0380-D3131D644CBA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x92ca6000 - 0x92da7fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <C75F921C-F027-6372-A0A1-EDB8A6234331> /usr/lib/libxml2.2.dylib
      0x92da8000 - 0x92ddefff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
      0x92ddf000 - 0x92defff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
      0x92e9a000 - 0x92fc8fe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x92fc9000 - 0x93094fef  com.apple.CoreServices.OSServices 359 (359) <EC340F74-8192-C9DD-40B3-AE4E519A38D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x93095000 - 0x930c8ff3  libTrueTypeScaler.dylib ??? (???) <E5E16584-870F-CBCD-F861-3BB45324DE16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
      0x932ef000 - 0x93336ffb  com.apple.CoreMediaIOServices 134.0 (1160) <4CD78557-3CDA-A4B5-33CB-BBB876B4463D> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
      0x9337a000 - 0x9339eff7  libJPEG.dylib ??? (???) <A50127EB-C202-0436-E62D-41E2E893E436> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x9339f000 - 0x93419fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <F7C9B01D-45AD-948B-2D26-9736524C1A33> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x9341a000 - 0x9345dff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x9345e000 - 0x93476ff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
      0x93477000 - 0x9352dffb  libFontParser.dylib ??? (???) <D85C1840-0FA8-27A2-54B7-FF336099EBC0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
      0x9352e000 - 0x9359dff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x9359e000 - 0x935b0ff7  com.apple.MultitouchSupport.framework 207.10 (207.10) <E1A6F663-570B-CE54-0F8A-BBCCDECE3B42> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
      0x935b1000 - 0x935b7fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x935b8000 - 0x937b6ff3  com.apple.JavaScriptCore 6533.20 (6533.20.20) <C97A479C-FDF9-3F19-2EE0-80288257C477> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x937b7000 - 0x937d2ff7  libPng.dylib ??? (???) <65E824F7-523A-CC34-ABDD-2A3B12DE1CA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x937d3000 - 0x93810ff7  com.apple.CoreMedia 0.484.20 (484.20) <105DDB24-E45F-5473-99E1-B09FDEAE4500> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
      0x93811000 - 0x93818ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6877F0D8-0DCF-CB98-5304-913667FF50FA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x9381f000 - 0x9383ffe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
      0x938b0000 - 0x93d69ffb  com.apple.VideoToolbox 0.484.20 (484.20) <E7B9F015-2569-43D7-5268-375ED937ECA5> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
      0x93d6a000 - 0x93dc2fe7  com.apple.datadetectorscore 2.0 (80.7) <ADDE04FB-90A7-2132-75AF-C6B19DD0D97E> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
      0x93e64000 - 0x93e67ff7  libCoreVMClient.dylib ??? (???) <12EF6056-7AC7-6691-75A2-BD0675C56A35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x9405c000 - 0x94168ff7  libGLProgrammability.dylib ??? (???) <2D172B4E-432F-D18E-EA99-3BD56DBE7649> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x94169000 - 0x94172ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x94173000 - 0x94179fe7  com.apple.CommerceCore 1.0 (9) <928FCA4F-1366-AE18-CF67-87C79F5DAC21> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
      0x9417a000 - 0x941f5fff  com.apple.AppleVAFramework 4.10.23 (4.10.23) <57B7C626-F344-AB15-8556-00425FA765DE> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
      0x941f6000 - 0x94218fef  com.apple.DirectoryService.Framework 3.6 (621.11) <CA979EAC-9537-43B6-CD69-C144ACB75E09> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x94219000 - 0x94224ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <4560936D-7730-5DD2-BFD7-95270DDC210A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x94225000 - 0x9422aff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x94323000 - 0x943a5ffb  SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x943a6000 - 0x9444effb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x9444f000 - 0x944c8ff7  com.apple.PDFKit 2.5.1 (2.5.1) <CEF13510-F08D-3177-7504-7F8853906DE6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
      0x944c9000 - 0x94834ff7  com.apple.QuartzCore 1.6.3 (227.36) <8E927524-EB0A-D5BA-C2E4-FA26FE4C428A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x94835000 - 0x94892ff7  com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x94893000 - 0x94893ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
      0x94894000 - 0x948ddfe7  libTIFF.dylib ??? (???) <5CE284EC-F637-EDBB-FDB3-61E86407CBB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x948de000 - 0x94922fe7  com.apple.Metadata 10.6.3 (507.15) <A23633F1-E913-66C2-A073-E2B174C09B18> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x94923000 - 0x94966ff7  libGLU.dylib ??? (???) <2C7B2727-26F6-F29D-9D15-33044E87359F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x9497a000 - 0x949fafeb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x94a0b000 - 0x94a0bff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x94a20000 - 0x94b4cffb  com.apple.MediaToolbox 0.484.20 (484.20) <D67788A2-B772-C5DB-B12B-173B2F8EE40B> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
      0x94b4d000 - 0x94e71fef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x94e72000 - 0x94e80ff7  com.apple.opengl 1.6.12 (1.6.12) <81AEF74E-E33A-B021-9CDB-6199104105FF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x94e88000 - 0x94e9dfff  com.apple.ImageCapture 6.0.2 (6.0.2) <E9F4B952-27A1-5BFC-CA8D-DADA055D30E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x94e9e000 - 0x94e9fff7  com.apple.TrustEvaluationAgent 1.1 (1) <FEB55E8C-38A4-CFE9-A737-945F39761B4C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
      0x94f55000 - 0x94fa5ff7  com.apple.framework.familycontrols 2.0.2 (2020) <C96C8A99-A40C-8B9C-1FBA-A0F46AC92F17> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
      0x94fa6000 - 0x95188fff  com.apple.imageKit 2.0.3 (1.0) <B4DB05F7-01C5-35EE-7AB9-41BD9D63F075> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
      0x95189000 - 0x951a5fe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x9529b000 - 0x9541dfe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D375C1CF-C88D-C5F6-3C49-CD429023FBAC> /usr/lib/libicucore.A.dylib
      0x9541e000 - 0x9555aff7  com.apple.audio.toolbox.AudioToolbox 1.6.6 (1.6.6) <781018FB-474B-E09C-D419-5BFF80590A10> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x960e7000 - 0x9622afef  com.apple.QTKit 7.6.6 (1756.15) <32C49374-14BC-53E7-FBFF-E11B42A41F56> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
      0x9622b000 - 0x9626fff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x971f7000 - 0x971f9ff7  libRadiance.dylib ??? (???) <B83179D4-E41C-D2BA-1E4C-A64CB45C15E6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x971fa000 - 0x97200ff7  libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <218EC7C4-0520-2D8C-62EE-AA82D35448FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
      0x97201000 - 0x97202ff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
      0x97203000 - 0x972bcfe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
      0x972bd000 - 0x972f8feb  libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
      0x97318000 - 0x9734bff7  com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x9735a000 - 0x9735cff7  com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x97392000 - 0x973b9ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
      0x973ba000 - 0x977efff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x977f0000 - 0x977f0ff7  com.apple.quartzframework 1.5 (1.5) <4EE8095D-5E47-1EB6-3A8A-6ECE3BEC8647> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
      0x977f1000 - 0x977f1ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x977ff000 - 0x97806ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x97807000 - 0x9783efe7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7DCB5938-3140-E71A-92BD-8C242F30C8F5> /usr/lib/libssl.0.9.8.dylib
      0x97988000 - 0x979e9fe7  com.apple.CoreText 3.151.8 (???) <6F5D6C49-4693-B9B7-6612-832E8F155747> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x979ee000 - 0x979feff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
      0x97a3b000 - 0x97a5cfe7  com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x97a5d000 - 0x97b0bff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x97b0c000 - 0x97b76fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
      0x97b77000 - 0x97bb5ff7  com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x97bb6000 - 0x97de1ff3  com.apple.QuartzComposer 4.2 ({156.28}) <08AF01DC-110D-9443-3916-699DBDED0149> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
      0x97de2000 - 0x97ee6fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
      0x97ee7000 - 0x97ef2ff7  libGL.dylib ??? (???) <4425B9AA-B494-A336-EABB-6BBC9FF4EC4F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x97f15000 - 0x97f4dff7  com.apple.LDAPFramework 2.0 (120.1) <001A70A8-3984-8E19-77A8-758893CC128C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
      0x97f4e000 - 0x981b3feb  com.apple.security 6.1.2 (55002) <7F00A51B-F22A-0EBC-A321-923472D686BD> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x981b4000 - 0x981b8ff7  libGIF.dylib ??? (???) <447BC6E8-4C56-3D5D-983B-6BEA0D26F319> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x98251000 - 0x98289fe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <242954AD-3BE1-29E8-E2E0-08063201F105> /usr/lib/libcurl.4.dylib
      0x9828a000 - 0x982ccff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x982cd000 - 0x982e1ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x982e2000 - 0x98308ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x9830c000 - 0x9830ffe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
      0x98310000 - 0x984ecfe7  libType1Scaler.dylib ??? (???) <CB930F73-3CD3-BF41-645B-470660F57FF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
      0x985f4000 - 0x98671ff7  com.apple.iLifeMediaBrowser 2.5.4 (468.1.1) <3B7F5895-B48D-A2E0-D708-58EC58EB9514> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
      0x987bc000 - 0x987ecff7  com.apple.MeshKit 1.1 (49.2) <ECFBD794-5D36-4405-6184-5568BFF29BF3> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
      0x987f5000 - 0x98842feb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
      0x98843000 - 0x98ab6fe7  com.apple.Foundation 6.6.6 (751.53) <C73FDD37-000B-C505-FD8D-80D1C9D17965> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x98ab7000 - 0x98ac3ff7  libkxld.dylib ??? (???) <F0E915AD-6B32-0D5E-D24B-B188447FDD23> /usr/lib/system/libkxld.dylib
      0x98ac4000 - 0x98ad8fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
      0x98bce000 - 0x98d75ff7  libSystem.B.dylib 125.2.10 (compatibility 1.0.0) <ADF8138B-2384-2FC0-CCBF-C4721B53568A> /usr/lib/libSystem.B.dylib
      0x98e0d000 - 0x98e0dff7  com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x98e0e000 - 0x98e3fff7  libGLImage.dylib ??? (???) <1AF72191-087A-5D75-B3B9-3F537315F635> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x98e40000 - 0x98e48ff7  com.apple.DisplayServicesFW 2.3.0 (283) <48D94761-7340-D029-99E3-9BE0262FAF22> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
      0x98e49000 - 0x98e68ff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x98e69000 - 0x98ea9ff7  com.apple.ImageCaptureCore 1.0.4 (1.0.4) <CE815114-CEFA-4AF4-7365-7908428AB733> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
      0x98ebd000 - 0x98ebdff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x98ebe000 - 0x98f22ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x98f5b000 - 0x9974a557  com.apple.CoreGraphics 1.545.0 (???) <8A4CB0D9-1001-0F62-4DA4-B8AB3B45E226> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x998a1000 - 0x99933fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x999a4000 - 0x999aeff7  com.apple.HelpData 2.0.5 (34.1.1) <A9CF754F-B254-5D40-B8B5-F35414DFD875> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
      0x999af000 - 0x99a8ffe7  com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x99a90000 - 0x99ac9ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <90C5DE81-1BEF-D807-A898-0FC19BDD14EC> /usr/lib/libcups.2.dylib
      0xb0000000 - 0xb0010ff8 +com.adobe.ahclientframework 1.6.0.5 (1.6.0.5) <8F89CE47-10C1-AE43-AB78-7BB2D24BA50B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
      0xba300000 - 0xba301fe7  libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <917C387A-1F4E-F72C-514D-862CF11A822C> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
      0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <B339B85B-1B6D-81D8-1281-7B8C8A517329> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
      0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <EF3E3210-927F-DB9F-4CD4-4039A2AE2F84> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
      0xcc000000 - 0xcc186fef +com.mainconcept.mc_dec_mp2v 8.5 (8.5.0.24499) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/8.5/mc_dec_mp2v
      0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <ADF8138B-2384-2FC0-CCBF-C4721B53568A> /usr/lib/libSystem.B.dylib
      Model: iMac7,1, BootROM IM71.007A.B03, 2 processors, Intel Core 2 Duo, 2.4 GHz, 2 GB, SMC 1.20f4
      Graphics: ATI Radeon HD 2600 Pro, ATI,RadeonHD2600, PCIe, 256 MB
      Memory Module: global_name
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (5.10.131.36.9)
      Bluetooth: Version 2.4.0f1, 2 service, 12 devices, 1 incoming serial ports
      Network Service: Ethernet, Ethernet, en0
      Serial ATA Device: ST3500418ASQ, 465.76 GB
      Parallel ATA Device: MATSHITADVD-R   UJ-85J
      USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd400000
      USB Device: Keyboard Hub, 0x05ac  (Apple Inc.), 0x1006, 0xfd100000
      USB Device: CTE-440-U V4.0-3, 0x056a  (WACOM Co., Ltd.), 0x0015, 0xfd130000
      USB Device: Apple Keyboard, 0x05ac  (Apple Inc.), 0x0220, 0xfd120000
      USB Device: USB2.0 Printer (Hi-speed), 0x04b8  (Seiko Epson Corp.), 0x0007, 0xfa200000
      USB Device: Desktop, 0x0bc2, 0x3300, 0xfa400000
      USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x5d100000
      USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8206, 0x1a100000
